Page 1 of 2
Fetching and processing SolarEdge JSON data with 2.4
Posted: Thursday 25 January 2018 16:38
by dannybloe
Hi folks,
While developing and testing dzVents 2.4 I used this script to read my SolarEdge solar panels. So instead of using the hardware plugin (which is kind of inefficient if you have multiple converters) I use the new asynchronous http call functionality to fetch some json data from SolarEdge's API and stream the results into two virtual devices:
- SolarEdge (Electric (Instant/Counter, set to type 'Return', energy read from 'device'))
- SolarEdge: revenue (Custom, axis label 'Euros').
Assuming you have activated and retrieved your API key and Site ID, this is the code:
local KEY = 'your api key'
local SITE_ID = 'your site id'
timer = { 'every 5 minutes at daytime' },
httpResponses = { 'SolarEdge' } -- matches callback string below
execute = function(domoticz, triggerItem)
if (triggerItem.isTimer) then
-- get data from SolarEdge
domoticz.openURL({
url = 'https://monitoringapi.solaredge.com/site/' .. SITE_ID .. '/overview?api_key=' .. KEY,
method = 'GET',
callback = 'SolarEdge'
elseif (triggerItem.isHTTPResponse) then
-- we got data, let's update our devices
local response = triggerItem
if (response.ok and response.isJSON) then
local lifeTime = response.json.overview.lifeTimeData.energy
local current = response.json.overview.currentPower.power
local revenue = response.json.overview.lifeTimeData.revenue
domoticz.devices('SolarEdge').updateElectricity(current, lifeTime)
domoticz.devices('SolarEdge: revenue').updateCustomSensor(revenue)
-- oops
domoticz.log('Error fetching SolarEdge data', domoticz.LOG_ERROR)
domoticz.log(response.data, domoticz.LOG_ERROR)
API docs can be found
here (look for Overview p.19 as of this date)
Re: Fetching and processing SolarEdge JSON data with 2.4
Posted: Thursday 25 January 2018 17:26
by elmortero
This will help me convert my current scripts to 2.4(1)
Posted: Thursday 25 January 2018 17:43
by McMelloW
Thanks Danny,
Will check this out to see how this works for me.
Actually, I am trying to read my SolarEdge via the local ip and Modbus TCP/LAN according to this
document
Posted: Friday 26 January 2018 10:49
by McMelloW
@dannybloe
To my surprise the result of the HTTP call is finally put in respone.json .. and not in a temporary file. Very nice. See the picture for the comparison of the hardware (Actueel Vermogen) and your script (SolarEgde)
The hardware don't shows the total produced power, but the total of todays produced power on the second line. Nice example of the new asynchronous http call functionality.
Posted: Friday 26 January 2018 10:52
by dannybloe
You generate quite some power!
Posted: Friday 26 January 2018 12:20
by McMelloW
dannybloe wrote: Friday 26 January 2018 10:52
Yeah it is a top day with this cloudy weather
Posted: Saturday 27 January 2018 23:16
by McMelloW
Finally, I have a working solution to get data direct from my SolarEdge The
Sunspec-Monitor Although it is a Perl script it works OK. Next step is to get it running every 5 minutes within Domoticz.
It reads the complete registers and this is the output
INVERTER:
Model: SolarEdge SE3500
Firmware version: 3.2173
Serial Number: 73xxxxxx
Status: SLEEPING
Power Output (AC): 0 W
Power Input (DC): 0 W
Efficiency: 0.00 %
Total Production: 165.755 kWh
Voltage (AC): 234.30 V (50.01 Hz)
Current (AC): 0.00 A
Voltage (DC): 0.50 V
Current (DC): 0.00 A
Temperature: 30.95 C (heatsink)
I think this is more like it, instead of being depended on the SolarEdge website
Posted: Saturday 17 February 2018 10:28
by florisi
McMelloW wrote: Friday 26 January 2018 10:49
@dannybloe
Is it possible to get the revenue rounded at two decimals?
Posted: Saturday 17 February 2018 12:03
by elmortero
[/quote]
[/quote]
You can use the dzVents round function
Posted: Saturday 17 February 2018 12:07
by florisi
I've tried, but can't get it to work
Posted: Saturday 17 February 2018 13:04
by freijn
thanks for sharing. will give it a go later this weekend!
Posted: Saturday 17 February 2018 14:27
by McMelloW
florisi wrote: Saturday 17 February 2018 10:28
Try this:
domoticz.devices('SolarEdge: revenue').updateCustomSensor(domoticz.utils.round(revenue,2))
Also look at the dzVents wiki page, that's where I found it.
Posted: Saturday 17 February 2018 14:46
by florisi
it works.
I did forget the Domoticz.utils part in the code.
thanks
Posted: Saturday 17 February 2018 15:06
by McMelloW
florisi wrote: Saturday 17 February 2018 14:46
it works.
thanks
Yes, I found it too not easy and clear how to use these attributes and methods. But if you do, then it is simple and it works great.
Posted: Saturday 10 March 2018 8:21
by florisi
I've reinstalled Domoticz.
Now I have an error:
Error: dzVents: Error: An error occured when calling event handler SolarEdge
2018-03-10 08:20:01.265 Error: dzVents: Error: ...domoticz/scripts/dzVents/generated_scripts/SolarEdge.lua:11: attempt to index local 'triggerItem' (a nil value)
Any idea how to solve?
Posted: Saturday 10 March 2018 8:32
by dannybloe
You need dzVents 2.4. Use the latest beta.
Posted: Saturday 10 March 2018 8:38
by florisi
How to update to latest beta?
I'm running Domoticz v3.8153 on a raspberry pi 3
Posted: Saturday 10 March 2018 8:48
by dannybloe
You can download it from the website.
Posted: Saturday 10 March 2018 9:11
by florisi
works like a charm
Posted: Sunday 11 March 2018 7:36
by florisi
It stopped yesterday at 14:20, no clue why.
