Volumio Connector for Domoticz
emme
Domoticz version: latest
Post by emme »
Ciao,
I finally found my way to connecto Volumio2 to my Domoticz
Iwas thinking to create a plugin, but I'm not so skilled, so I choose a Python servicewhich connect via socketIO and keep Domoticz updated, while Domoticz can control Volumio using the http REST API
...if.. for any reason... someone would like toconvert it into a plugin it would be really appreciated!!
here is how it works:
Unfortunately it works only unde linux
in domoticz you need to create 3 dummy devices:
SWITCH DIMMER that will act as volume and mute/unmute
SWITCH SELECTOR that will act as basic controls (PLAY/STOP/PREV/NEXT)
TEXT DEVICEthat will act as a display
Create those 3 and keep note of their IDX
Device Configuration (edit them)
SWITCH DIMMER
  • Name: Volumio Volume (you can use whatever you want, but we will is it later)
  • Switch Type: Dimmer
  • Icon: Speaker
  • Save
SWITCH SELECTOR
  • Switch Type: Selector
  • Icon: Amplifier
  • Level 0 Name: off (cannot change)
  • Level 10 Name:◄◄
  • Level 20 Name: ►
  • Level 30 Name: ►►
  • Level 0 Action : http://<volumio_IP>/api/v1/commands/?cmd=stop
  • Level 10 Action: http://<volumio_IP>/api/v1/commands/?cmd=prev
  • Level 20 Action: http://<volumio_IP>/api/v1/commands/?cmd=play
  • Level 30 Action: http://<volumio_IP>/api/v1/commands/?cmd=next
  • Save
other levels can be used to access playlist... if so the level action to call a playlist will be
http://<volumio_IP>/api/v1/commands/?cmd=playplaylist&name=<playlist Name>
The TEXT DEVICE does not need any special configuration except its name
now you need to create a dzVents Script in which you can copy/paste the following:
   active = true,
   on = { devices = {'Volumio Volume'} },-- NUse the same name as setted in the Volume device
   execute = function(dz, devVol)
      local volumio = '<volumio_IP>'
      if devVol.state == 'Off' then
         os.execute('curl "http://'..volumio ..'/api/v1/commands/?cmd=volume&volume=mute"')
         os.execute('curl "http://'..volumio ..'/api/v1/commands/?cmd=volume&volume='..devVol.level..'"')
save it and be sure to enable it...
now save the attached file in a folder into your linux system
Connect in Telnet/SSH to your linux system
be sure you have SocketIO installed by issuing
sudo pip3 install SocketIO-client
move to the folder where you placed the file and edit it to fill the needed information:
VOLUIP = '<Volumio_IP>'
DEVIDX    = '000'  # VOLUME CONTROL
DEVTXT    = '000'  # DISPLAY CONTROL
DEVCTL    = '000'  # DEVICE CONTROL
save the file
now let's create the service (these instruction works under Raspberry, other systems may need an adjustment:
sudo nano /lib/systemd/system/dzVol.service
copy and paste the following code:
[Unit]
Description=Volumio connector for Domoticz
After=multi-user.target
[Service]
User=root
Type=idle
ExecStart= /home/pi/utility/dzVol.py
[Install]
WantedBy=multi-user.target
enter the full path where the file is at line ExecStart (in my case is /home/pi/utility/dzVol.py) save it as dzVol.service (press CTRL-X and enter the file name)
now some other command to complete the installation:
sudo chmod +x /home/pi/utility/dzVol.py
sudo chmod +x /lib/systemd/system/dzVol.service
sudo systectl daemon-reload
sudo systemctl enable dzVol.service
sudo systemctl start dzVol.service
sudo systemctl status dzVol.service
you should see the service in active (running) mode
...that's all... you should be now able to change volume and use command on both domoticz and volumio UI to have the other side updated
hope you enjoy it
let me know what you think about it :P
ciao
M
dzVol.py.txt
Remove .txt extension
(3.75 KiB) Downloaded 289 times
"We always done this way"
EdwinK
Re: Volumio Connector for Domoticz
Post by EdwinK »
looks great, I think. Now if only someone would make such a nice thing for Max2Play
jppmedia
Post by jppmedia »
It's really a very good idea! I am not familiar with the code, script, etc .... So if a passionate Volumio and music, was kind, nice to make a plugin, it will be really fanstastic! There must be a great person on this forum!
Thank you very much.
jp
(I'm French, this is translated with google, I know but nobody is perfect!)
emme
Post by emme »
after few month in whitch I tested the connector I would start moving to something else.
The service experienced hangs, disconnections and a wired loop while changing volume...
So.. I start interesting in MQTT, and NodeRed and I found a way by which the service is much more stable with less scripting, and use the MPD server on volumio instead of socketIO.
The result is that it works like a charm with no script at all!!!.
So...
trow away the python, lua/dzVents script and use MQTT and Node-Red instead.
User MPD control to gather info in realtime and MQTT do send/receive Domoticz command
The presents (playlist and play controls) will run as HTTP actions while the Volume slider will be used by the MQTT interface.
I'll update the nodered flow soon (mine uses a dashboard UI also.... so I would like to duplicate it in a clean way)
MQTT is a REALLY good solution and widely open to almost everything!!!
ciao
M
Ries
Domoticz version: 2022.1
Post by Ries »
emme wrote: Friday 22 June 2018 10:17 )MQTT is a REALLY good solution and widely open to almost everything!!!
I am really interested in your detailed approach!
Version 3.9639
Platform: Jessie lite
Hardware: Raspberry pi 3B; RFXCOM; Weather Underground; Dummy; OpenZwave USB; Fritzbox Callmonitor via LAN interface; System Alive Checker (Ping); Philips Hue Bridge; Atag One Thermostat
emme
Post by emme »
Ciao,
here it is...
please note you have to configure:
MPD in and MPD out with the IP:port (6600) of your volumio device
domoticz/out and domoticz/in with the IP and topicz of your mosquitto server (could be the same as Domoticz box)
in dzSetVolume - set the ID for the custom device for volume control (a dimmer)
in dzSetArtistInfo - set the ID for the custom device for text (act as a display)
in getVolumeSet - set the ID for the custom device for volume control (a dimmer) - the same as per dzSetVolume
here is how it woks:
MPD.in is activated at any chanage in the volumio state
getVolume acquire the volume status and then dzSetVolume convert it into the json formatted command for MQTT, rbe is used to ensure no duplicated values are sent and finally it goes through MQTT to domoticz
dzSetArtist convert Artist Name and song Title into a json formatted command for MQTT rbe is used to ensure no duplicated values are sent and finally it goes through MQTT to domoticz
in the meantime, domoticz/out push ALL status form domoticz, so it gets converted into a JSON and then getVolumeSet intercept the volume device and update volumio via MPD
getVolume and dzSetVolume could be merged into a single function, but I have a dashboard also, so, my layout is quite different (i've created this one only for this post :P :P )
here is the nodeRed flow to import from clipboard
[{"id":"e3c13c75.d0dcb","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"71c0613f.05d81","type":"mpd in","z":"e3c13c75.d0dcb","name":"","topic":"","server":"3ce54245.d0712e","x":87,"y":78,"wires":[["32c5f555.1475ca","e8d09e01.5c04f","564017f4.cfdfa8"]]},{"id":"32c5f555.1475ca","type":"debug","z":"e3c13c75.d0dcb","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":285.4753112792969,"y":35.587188720703125,"wires":[]},{"id":"35032ee8.133e22","type":"catch","z":"e3c13c75.d0dcb","name":"","scope":null,"x":97.1201171875,"y":36.587188720703125,"wires":[["32c5f555.1475ca"]]},{"id":"e8d09e01.5c04f","type":"function","z":"e3c13c75.d0dcb","name":"getVolume","func":"\nmsg.payload = msg.payload.status.volume;\n\nreturn msg;","outputs":1,"noerr":0,"x":293.57464599609375,"y":82.6781005859375,"wires":[["4ae356ac.60e838"]],"outputLabels":["Volume"]},{"id":"4ae356ac.60e838","type":"function","z":"e3c13c75.d0dcb","name":"dzSetVolume","func":"msg.payload = {\"command\": \"switchlight\", \"idx\": 1031, \"switchcmd\": \"Set Level\", \"level\": msg.payload};\n\nreturn msg;","outputs":1,"noerr":0,"x":465.1201171875,"y":116.587158203125,"wires":[["3f675acf.e26506"]]},{"id":"564017f4.cfdfa8","type":"function","z":"e3c13c75.d0dcb","name":"dzSetArtistInfo","func":"if (msg.payload.status.state == \"play\") {\n    msg.payload = {\"command\": \"udevice\", \"idx\": 1071, \"svalue\": msg.payload.currentsong.Name + \" ~ \" + msg.payload.currentsong.Title};\n}\nelse {\n    msg.payload = {\"command\": \"udevice\", \"idx\": 1071, \"svalue\": \"STOP\"};\n}\nreturn msg;","outputs":1,"noerr":0,"x":317.1201171875,"y":161.587158203125,"wires":[["45ea63df.fdf7cc"]]},{"id":"3f675acf.e26506","type":"rbe","z":"e3c13c75.d0dcb","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":640.1201171875,"y":130.587158203125,"wires":[["1362ebc8.cc0f44"]]},{"id":"45ea63df.fdf7cc","type":"rbe","z":"e3c13c75.d0dcb","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":506.1201171875,"y":163.587158203125,"wires":[["1362ebc8.cc0f44"]]},{"id":"1362ebc8.cc0f44","type":"mqtt out","z":"e3c13c75.d0dcb","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"e29315fb.89af68","x":802,"y":152,"wires":[]},{"id":"511a0b29.b96c44","type":"mpd out","z":"e3c13c75.d0dcb","name":"","topic":"","server":"3ce54245.d0712e","x":622.5,"y":250,"wires":[[]]},{"id":"b2a058cb.56fb38","type":"mqtt in","z":"e3c13c75.d0dcb","name":"","topic":"domoticz/out","qos":"2","broker":"e29315fb.89af68","x":98,"y":215,"wires":[["3f69c946.af4a56"]]},{"id":"3f69c946.af4a56","type":"json","z":"e3c13c75.d0dcb","name":"","property":"payload","action":"obj","pretty":true,"x":258.77272033691406,"y":237,"wires":[["4c9f9d89.aaef54"]]},{"id":"4c9f9d89.aaef54","type":"function","z":"e3c13c75.d0dcb","name":"getVolumeSet","func":"if (msg.payload.idx == 1031) {\n    msg.payload = \"setvol \" + msg.payload.Level\n    return msg;\n}\n","outputs":1,"noerr":0,"x":435.5,"y":215,"wires":[["511a0b29.b96c44"]],"outputLabels":["msg object"]},{"id":"3ce54245.d0712e","type":"mpd-server","z":"","host":"192.168.0.15","port":"6600"},{"id":"e29315fb.89af68","type":"mqtt-broker","z":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
Ciao
M
WilliamB
Post by WilliamB »
Hi Emme,
Thanks for your flow!
I've installed Node-RED and MQTT and imported your flow. Thereafter I've put in al the right variables and I got the notification 'connected' on MPD and domoticz, but no signs go to Domoticz. I ain't see anything in the log.
Did I forgot something? Do I have to do extra settings on Volumio? Hopefully you can help me into the right direction.
WilliamB
Post by WilliamB »
I don't know what happened but it is working now. Unfortunately, I do not know the cause ..
But thanks again for the flow. Works great!
