Code for Energenie LAN Powerstrip
Posted: Sunday 30 March 2014 22:01
by whiteduck
All,
Not implemented this yet but wanted to share something that could be useful:
https://energenie4u.co.uk/index.php/cat ... ct/ENER019
Found it cheapest at:
http://www.hitari.co.uk/energenie-lan-p ... ystem.html
You don't need this if you have RFXCom as I've seen elsewhere on this forum that you can control a cheaper unit via 433MHz RF.
However to control over the LAN from Linux the HOWTO states:
To login:
$ wget --post-data 'pw=smartlab' 'http://nn.nn.nn.nn/login.html' -O foo.html --delete-after
To switch Socket3 ON:
$ wget --post-data 'cte1=&cte2=&cte3=1&cte4=' 'http://nn.nn.nn.nn' -O foo.html --delete-after
To switch Socket3 OFF:
$ wget --post-data 'cte1=&cte2=&cte3=0&cte4=' 'http://nn.nn.nn.nn' -O foo.html --delete-after
To logout:
$ wget 'http://nn.nn.nn.nn/login.html' -O foo.html –-delete-after
Best regards
Ian
Re: Code for Energenie LAN Powerstrip
Posted: Monday 31 March 2014 16:56
by SweetPants
UK only?
Posted: Monday 31 March 2014 23:59
by whiteduck
Posted: Wednesday 02 April 2014 18:49
by SweetPants
Great, I ordered one, arrives in 2-3 days
Posted: Saturday 05 April 2014 14:19
by whiteduck
Cool - let me know how you get on. I guess we should also poll the device to ensure Domoticz shows current status.
Posted: Saturday 05 April 2014 16:10
by SweetPants
Damn, received the LAN Powerstrip unit today, but it does not show any signs of live on the LAN interface. it looks like it is DOA. Will ask for a new one next week.
Posted: Saturday 05 April 2014 17:39
by whiteduck
Did you try resetting it - also may be the cable as the RJ45 is quite tight on this one - needs a straight through cable.
Posted: Saturday 05 April 2014 17:51
by whiteduck
I have written a (basic) Bash script to control this - feel free to use and modify at your own risk
Note: I assume wget is in default path and do no error checks...
Firstly you need to define 4 dummy switches in Domoticz. I called mine Ener1,2,3,4
I then have four lua scripts - ener1,2,3,4 - the example below is for the first - just change the parameters for 2,3,4 - but I guess you could use a single script.
I put my installation under /root so modify this for your own setup.
script_device_ener1.lua
if (devicechanged['Ener1'] == 'On') then
os.execute('/root/domoticz/scripts/energenie 1 on')
if (devicechanged['Ener1'] == 'Off') then
os.execute('/root/domoticz/scripts/energenie 1 off')
Then the Bash code looks like this -
note this doesn't do any error checking!
#!/bin/bash
exec > /dev/null 2>&1 # Redirect all output to null
IP=192.168.0.254
URL=http://$IP
SOCK=$1
CMD=$2
PASS=yourpass
if [ "$CMD" = "on" ]
then
ACTION=1
ACTION=0
fi
# Login first
wget --post-data pw=$PASS $URL/login.html -O foo.html --delete-after
# Send command
case $SOCK in
"1" ) wget --post-data "cte1=$ACTION&cte2=&cte3=&cte4=" $URL -O foo.html --delete-after ;;
"2" ) wget --post-data "cte1=&cte2=$ACTION&cte3=&cte4=" $URL -O foo.html --delete-after ;;
"3" ) wget --post-data "cte1=&cte2=&cte3=$ACTION&cte4=" $URL -O foo.html --delete-after ;;
"4" ) wget --post-data "cte1=&cte2=&cte3=&cte4=$ACTION" $URL -O foo.html --delete-after ;;
esac
# Logout
wget ${URL}/login.html -O foo.html --delete-after
exit 0;
Something to do would be to check the status of the sockets and update Domoticz if something else changes them to on or off.
Good luck!
Posted: Monday 28 April 2014 16:45
by SweetPants
whiteduck wrote:Did you try resetting it - also may be the cable as the RJ45 is quite tight on this one - needs a straight through cable.
It was broken, received another one today. This one is working
Posted: Monday 28 April 2014 17:04
by SweetPants
whiteduck wrote:I have written a (basic) Bash script to control this - feel free to use and modify at your own risk
Great, this works fine for now, thanks.
Posted: Thursday 26 November 2015 21:54
by JohnS
My system runs on a Raspberry Pi 2. I have one of these Energenie LAN controlled adapters and here is another way of controlling it in Linux, using a utility I found.
1. Download and install the egctl utility written by unterwulf
cd ~
git clone https://github.com/unterwulf/egctl.git
cd egctl
make
sudo make install
2. Create the config file:
enter one line for each device you have, in the format
devicename protocol ipaddress port password
for example:
4way pms21 192.168.1.56 5000 pa55w0rd
Now ctrl-X and write the file.
3. Check it works
The response will indicate the current status of the switches
4. Using in Domoticz
You must always provide instructions for each of the switches 1 to 4
on = turn switch on regardless
off = turn switch off regardless
left = leave switch as is
toggle = change switch to the opposite state
eg: egctl 4way on off on toggle
In domoticz, create a dummy hardware device.
Create a dummy switch
In the "on action" or "off action" fields enter for example
script:///home/pi/egctl/egctl 4way on left left left
Hope that helps!
Posted: Tuesday 17 January 2017 12:18
by FxWork
Great, it works very well.
Thanks 4 that
