Domoticz doesn't show total kWh anymore
Posted: Wednesday 24 January 2018 12:41
by naitsirhc
Recently I discovered that my Domoticz doesn't show the total amount of kWh pruduced by my solar panels. I don't know when it happened and I'm not sure if it's my fault
When I look in devices, I do see the total amount of kWh, But when I look at utility I see "live" value and total of today.
Someone knows the trick? Thanks in advance
Re: Domoticz doesn't show total kWh anymore
Posted: Wednesday 24 January 2018 19:26
by blauwebuis
There was a change in data output recently. I also noticed that an old power value was no longer coming through. This might be the same issue.
Posted: Friday 26 January 2018 10:18
by Dexter
That was the issue in my case. Thanks!
Posted: Sunday 04 February 2018 21:27
by naitsirhc
I have been thinking. When I create a dummy device which shows the total amount, I would be satisfied.
When I type:
http://10.0.0.170:8080/json.htm?type=devices&rid=47
The device returns some values:
CounterToday "6.936 kWh"
CustomImage 0
Data "6427.55 kWh"
And more....
Probably it is possible to create a device which shows the data...?
Unfotunatly I don't have the skills to create the device with the proper code.
Can anyone help me?
Kind regards...
Posted: Sunday 18 March 2018 8:51
by naitsirhc
Nobody???
Posted: Sunday 18 March 2018 13:08
by McMelloW
naitsirhc wrote: Sunday 18 March 2018 8:51Nobody???
There are a number of other topics on the same issue.
Missing value at Energy Sensor
Solar panels not showing overall totals
Electric (instant+counter) - Domoticz doesn't compute Energy
Also there is an issue #2196 opened about it at github. But so far there is hardly any response on this matter.
It is not a lua or dzVents issue, so it seems to be a Domoticz issue.
Posted: Sunday 18 March 2018 13:56
by SweetPants
GizMoCuz already answered this question on GitHub "This is intended by a recent change to cleanup all sensors
Anyway, this is an always increasing value and you can display this in the report view"
Posted: Friday 17 January 2020 10:43
by Sasquatch
So only feature i have build KWh sensor for is now hidden behind 4 clicks and not accessible on mobile app.
don't know anyone that needs daily kwh usage instead of total.
rant over
is there any way to undo this change manually on my install?
