Issue reading dimmer level
Posted: Tuesday 23 January 2018 21:27
I have problems reading the dimmer level using dzVents. It seems that domoticz is working as intended, but not dzVents. It works sometimes, but after some changes, either from the domoticz control panel or directly in the Philips Hue app, the level becomes incorrect when reading it in dzVents.
I have changed the level to 40% but dzVents reports 20%.
The JSON output shows correct value
Pct_Level = domoticz.devices('Hall Taklampa').level
domoticz.log('PCT_LEVEL = ' .. tostring(Pct_Level), domoticz.LOG_INFO)
2018-01-23 21:24:00.443 dzVents: Info: PCT_LEVEL = 20
"ActTime" : 1516739109,
"AstrTwilightEnd" : "18:08",
"AstrTwilightStart" : "05:46",
"CivTwilightEnd" : "16:27",
"CivTwilightStart" : "07:27",
"DayLength" : "07:22",
"NautTwilightEnd" : "17:19",
"NautTwilightStart" : "06:35",
"ServerTime" : "2018-01-23 21:25:09",
"SunAtSouth" : "11:05",
"Sunrise" : "08:16",
"Sunset" : "15:38",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Set Level: 40 %",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 3,
"HardwareName" : "PhilipsHue",
"HardwareType" : "Philips Hue Bridge",
"HardwareTypeVal" : 38,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0000008",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2018-01-23 21:11:19",
"Level" : 39,
"LevelInt" : 6,
"MaxDimLevel" : 15,
"Name" : "Hall Taklampa",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Set Level: 40 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "8"
"status" : "OK",
"title" : "Devices"
