<html>
<head>
<meta charset="utf-8">
<title>Temperatures and power from Domoticz</title>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js"></script>
<script src="jquery.csv.min.js"></script>
<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>
<script type="text/javascript"> // load the visualisation API
google.charts.load('current', { packages: ['corechart','gauge'] });
google.charts.setOnLoadCallback(drawTemps);
google.charts.setOnLoadCallback(drawPower);
function drawTemps() {
$.get("temps_daily.csv", function(csvString) {
// transform the CSV string into a 2-dimensional array
var arrayData = $.csv.toArrays(csvString, {onParseValue: $.csv.hooks.castToScalar});
// this new DataTable object holds all the data
var data = new google.visualization.arrayToDataTable(arrayData);
// get min, max outside temp
var range = data.getColumnRange(3);
var options = {
explorer: {},
title: 'Temperatures for last 24 hours',
titleTextStyle: {color: 'grey', fontSize: 16},
hAxis: {title: 'Time', titleTextStyle: {bold: false, italic: false, color: 'grey'}, slantedTextAngle: 90, textStyle: {fontSize: 12}},
vAxis: {title: 'Degrees (C)', titleTextStyle: {bold: false, italic: false, color: 'grey'}},
seriesType: 'line',
series: {5: {type: 'area'}},
interpolateNulls: true,
var chart = new google.visualization.LineChart(document.getElementById('temps_div'));
chart.draw(data, options);
var columns = [];
var series = {};
for (var i = 0; i < data.getNumberOfColumns(); i++) {
columns.push(i);
if (i > 0) {
series[i - 1] = {};
google.visualization.events.addListener(chart, 'select', function () {
var sel = chart.getSelection();
// if selection length is 0, we deselected an element
if (sel.length > 0) {
// if row is undefined, we clicked on the legend
if (sel[0].row === null) {
var col = sel[0].column;
if (columns[col] == col) {
// hide the data series
columns[col] = {
label: data.getColumnLabel(col),
type: data.getColumnType(col),
calc: function () {
return null;
// grey out the legend entry
series[col - 1].color = '#CCCCCC';
else {
// show the data series
columns[col] = col;
series[col - 1].color = null;
var view = new google.visualization.DataView(data);
view.setColumns(columns);
chart.draw(view, options);
var gauge_min_data = google.visualization.arrayToDataTable([
['Label', 'Value'],
['min', range.min]
var formatter = new google.visualization.NumberFormat(
{suffix: 'C', pattern: '##.#'}
formatter.format(gauge_min_data,1);
var gauge_min_options = {
width: 120, height: 120,
min: -5, max: 35,
redFrom: -5, redTo: 5,
greenFrom: 15, greenTo: 25,
yellowFrom: 25, yellowTo: 35,
minorTicks: 5
var chart1 = new google.visualization.Gauge(document.getElementById('gauge_min_div'));
chart1.draw(gauge_min_data, gauge_min_options);
var gauge_max_data = google.visualization.arrayToDataTable([
['Label', 'Value'],
['max', range.max]
formatter.format(gauge_max_data,1);
var gauge_max_options = {
min: -5, max: 35,
minorTicks: 5
var chart2 = new google.visualization.Gauge(document.getElementById('gauge_max_div'));
chart2.draw(gauge_max_data, gauge_max_options);
},'text');
function drawPower() {
$.get("power_daily.csv", function(csvString) {
// get last values
var n = data.getNumberOfRows() - 1;
var kWh = data.getValue(n, 2);
var cost = kWh * 13.9;
var options = {
title: 'Power for last 24 hours',
legend: {position: 'top'},
series: {
0: {targetAxisIndex: 0},
1: {targetAxisIndex: 1}
vAxes: {
0: {title: 'Power (W)', titleTextStyle: {bold: false, italic: false, color: 'grey'}},
1: {title: 'Cum. power (kWh)', titleTextStyle: {bold: false, italic: false, color: 'grey'}}
seriesType: 'line',
var chart = new google.visualization.LineChart(document.getElementById('power_div'));
var gauge_kWh_data = google.visualization.arrayToDataTable([
['Label', 'Value'],
['kWh', kWh]
var gauge_kWh_options = {
max: 20,
yellowFrom:12, yellowTo: 15,
redFrom: 15, redTo: 20,
minorTicks: 5
var chart = new google.visualization.Gauge(document.getElementById('gauge_kWh_div'));
chart.draw(gauge_kWh_data, gauge_kWh_options);
var gauge_cost_data = google.visualization.arrayToDataTable([
['Label', 'Value'],
['cost', cost]
{suffix: 'p', pattern: '####.#'}
formatter.format(gauge_cost_data,1);
var gauge_cost_options = {
max: 300,
yellowFrom: 150, yellowTo: 200,
redFrom: 200, redTo: 300,
minorTicks: 5
var chart = new google.visualization.Gauge(document.getElementById('gauge_cost_div'));
chart.draw(gauge_cost_data, gauge_cost_options);
},'text');
function GetClock(){
var d=new Date();
var nmonth=d.getMonth(),ndate=d.getDate(),nyear=d.getFullYear();
var nhour=d.getHours(),nmin=d.getMinutes(),ap;
if(nhour==0){ap=" AM";nhour=12;}
else if(nhour<12){ap=" AM";}
else if(nhour==12){ap=" PM";}
else if(nhour>12){ap=" PM";nhour-=12;}
if(nmin<=9) nmin="0"+nmin;
document.getElementById('clockbox').innerHTML=""+ndate+"/"+(nmonth+1)+"/"+nyear+" "+nhour+":"+nmin+ap+"";
window.onload=function(){
GetClock();
setInterval(GetClock,1000);
setInterval(drawTemps, 60000);
setInterval(drawPower, 60000);
</script>
<style>
table, th, td {
border: 2px solid #ccc;
border-collapse: collapse;
font-family: verdana;
font-size: 16px
th, td {
padding: 5px;
text-align: center;
td {
font-size: 12px
.graph {
width: 1000;
height: 400;
.meter {
padding: 15px;
width: 130;
height: 150;
font-size: 14px;
</style>
</head>
<body>
<table>
<tr>
<th>Temperatures and power from Domoticz</td>
<td><div id="clockbox" style="font-size: 100%"></div></td>
</tr>
<tr>
<td rowspan = "2"><div id="temps_div" class="graph"></div></td>
<td>Outside<div id="gauge_min_div" class="meter"></div></td>
</tr>
<tr>
<td><div id="gauge_max_div" class="meter"></div></td>
</tr>
<tr>
<td rowspan = "2"><div id="power_div" class="graph"></div></td>
<td>Cum. power<div id="gauge_kWh_div" class="meter"></div></td>
</tr>
<tr>
<td>Cost<div id="gauge_cost_div" class="meter"></div></td>
</tr>
</table>
</body>
</html>
