P1 Smart Meter hardware (x) thread seems to have ended unexpectedly
Posted: Tuesday 23 January 2018 12:28
I've built a P1 Smart Meter gateway, using an ESP8266 with ESP Easy. It seems to work well, as I can see neatly formatted telegrams when I connect in serial. Also when I connect the device in the Domoticz, it will work well for some time, sending the Power output, Voltage and Gas usage.
However, after some time (usually a few hours), Domoticz will stop receiving the data correctly. In the log I keep getting these errors:
When I go to 'Setup', 'Hardware' and update the P1 Smart Meter settings (without changing any setting) Domoticz connects to the ESP again, and it will work for a few hours once again. I've tried using different rate limits, but this doesn't seem to help.
What could be the problem? Can I see some more information in the logs why the the P1 Smart Meter thread crashes? Does it receive malformed data or something; is it possible to see the actual data that Domoticz received from the ESP?
P.S. I'm running Domoticz version 3.8153 on my Synology NAS.
P1 Smart Meter hardware (4) thread seems to have ended unexpectedlyWhat could be the problem? Can I see some more information in the logs why the the P1 Smart Meter thread crashes? Does it receive malformed data or something; is it possible to see the actual data that Domoticz received from the ESP?
