Fibaro FGFS101 with no settings
Posted: Monday 22 January 2018 8:54
by emme
Ciao,
Got an issue with a Flood sensors by Fibaro FGFS101 ZW+
It is correctly configured in the zwave stick (aeotec G2) but I see no parameters in the zwave device table except the sleep window
The device is correctly addressed to the fgfs101zw5.xml that contains settings and other stuff... but there is no way to have them in domoticz...
how can I fix this?
shall I try to remove and include it back into the network?
thanks
ciao
M
Re: Fibaro FGFS101 with no settings
Posted: Monday 22 January 2018 10:44
by bbqkees
Remove and re-include.
The time to try that first was probably less than asking on the forum and waiting for someone to reply :-)
Posted: Monday 22 January 2018 11:01
by emme
you talk like this just because you don't know where the device is :D :D
inside the kitchen, behind the trashcan, under the furniture :D :D :D :D
I have to make my way and fight with garbage, detergents and other unknow substances :lol:
thanks ;)
Posted: Monday 22 January 2018 12:23
by bbqkees
Well that changes things but you might be able to use the Z-stick with the button inclusion method if you are near the device.
(make sure you turn off the Pi first before removing the stick otherwise expect Domoticz to crash).
I have the same stick and an older Fibaro water detector and I believe it took 2 or 3 inclusions before it was correctly recognized.
Posted: Friday 26 January 2018 10:49
by emme
got the time to dive under my sink :P:P
the device has to be paired in secure mode to gets parameters.....
by your opinion... is this something that should be addressed to OpenZWave group?
Posted: Friday 26 January 2018 11:01
by bbqkees
In my case no secure pairing had to be done, maybe in your situation this was just a coincidence.
