I have a rfxtrx433e - and while it is very good - offers lots of modes - I want something that just "learns"
I have a cheap 433mhz alarm panel - to make it "learn" a new device - I just click "learn" - and set the sensor off - and then it works.
Most of the time - that's exactly how my domoticz and my rfxtrx433e work. I just look in "Devices" and "Not used" and there they are.
But sometimes - my cheap alarm panel finds things rfxtrx433e/domoticz doesn't.
Like the problem I had with the window sensors - 4 wouldn't work with rfxtrx433e/domoticz -- But my alarm panel uses them all fine.
And my Beam breakers - rfxtrx433e/domoticz cannot even see the signal - even on "undecoded" -- but my cheap alarm panel - just click "learn" and it picks them up fantastic. I get "ding dong" when someone goes through my beams.
(http://www.topnics.com/index.php?ac=art ... d&did=2961)
But rfxtrx433e/domoticz could be so much more powerful if i could get it working! I could have it if anyone goes through beams at night - it turns my lightwave outside lights on. And in the day - it just rings my 1byone Easy Chime. The possibilities are amazing.
But i want something that just picks up any 433mhz signal - and lets me use it!
Can anyone reommend anything i could try?
Most compatible 433mhz hardware???
b_weijenberg
- Target OS: -
Re: Most compatible 433mhz hardware???
It looks the same as the supported Aidebao security beam
https://aidebao.en.alibaba.com/product/ ... ector.html
Check with RFXmngr with only Meiantech/Atlantic enabled.
Or contact support rfxcom.com
RFX-433, RFX-433EMC, RFX-868
kimot
- Domoticz version: v3.8153
RFlink
http://www.rflink.nl/blog2/
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
blauwebuis
- Domoticz version: current
Good timing. I just created a python plugin that does exactly this.
Have a look here:
https://www.domoticz.com/wiki/Plugins/RFSwitches
Wait no, it doesn't do that. It learns, but only to then transmit codes. Sorry.
Have a look here:
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
