Dashboard
Posted: Tuesday 16 January 2018 15:46
by BugBlaster
Hi All,
Is there a way to bring a user variable to the dashboard so it can be modified, for example a "required temperature" variable so i can compare to "current temperature" and switch the boiler on and off accordingly,
some sort of dial that would update the User variable would be good or up and down arrows with the variable shown in between
Thanks in advance Bug
Re: Dashboard
Posted: Thursday 25 January 2018 11:06
by BugBlaster
Ok i have found the instructions for Smart Virtual Thermostat, But having problems when i install it.
After i have installed it and tried to add a new hardware of the SVT Domoticz becomes corrupt.
does anyone know what is causing this??
Re: Dashboard
Posted: Thursday 25 January 2018 15:56
by BugBlaster
this video show working S20 plug and esp easy temperature sensor
https://youtu.be/Omnt3y_2JPU
then i install SmartVirtualThermostat
Re: Dashboard
Posted: Monday 19 February 2018 22:01
by Domosapiens
Use Dummy hardware.
Create Virtual Sensor
Select Thermostat Setpoint
This Setpoint can be used in Blockly to compare with a temperature sensor and take action.
