Sensors in Neo Coolcam PIR pd01z
Posted: Tuesday 16 January 2018 14:54
At the startup of Domoticz I see from one of my PIR sensors the output as below.
I am using OpenZWave USB Version: 1.4-2886-gb0b0912-dirty
Any one any idea about the sensors Velocity, Direction, etc....
Are those sensors real???
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: General, Instance: 2
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Velocity, Instance: 6
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Direction, Instance: 7
OpenZWave: Value_Added: Unhandled Label: Direction, Unit:
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Atmospheric Pressure, Instance: 8
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Dew Point, Instance: 11
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR MULTILEVEL, Label: Rain Rate, Instance: 12
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Burglar, Instance: 1
OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: BATTERY, Label: Battery Level, Instance:1
