Same devices - different 433 messages???
Posted: Monday 15 January 2018 22:35
by binbo
I've said in my previous thread - I've got about 20 MD-2018R vibration glass sensors:
(https://www.amazon.co.uk/AtlanticS-MD-2 ... B00FGSG1X6)
MOST of them are picked up like this:
Meiantech/Atlantic/Aidebao:
Packettype    = Security1
subtype       = Meiantech/Atlantic/Aidebao
Sequence nbr  = 0
id1-3         = CD81AA decimal:13468074
status        = Motion
battery level = OK
Signal level  = 8  -56dBm
Strange - but 4 of them will only show up in RFXmngr when undecoded is on - and are like this:
Visonic PowerCode motion:
Packettype        = UNDECODED RF Message
UNDECODED VISONIC:12A91240
They are found in domoticz only when VISONIC is the only mode turned on - you have to turn all others off.
They dont function like the other sensors either when they are added.
Do you think this could be a setting that has been changed by the way the battery was put in/taken out sequence - or does anyone have any ideas why identical devices could be sening out different messages?
Thank you.
Re: Same devices - different 433 messages???
Posted: Tuesday 16 January 2018 18:21
by SweetPants
Are you sure they use the same hardware inside?
Posted: Tuesday 16 January 2018 21:39
by binbo
Hardware is 100% identical - I've made an example - device on left will not work, device on right works.
Device on the left just sends a bad message.
Does anyone think this could be fixed? With maybe a sequence of battery removals or something?
(The switches just control sensitivity of device.)
Thank you!
Posted: Tuesday 16 January 2018 21:53
by binbo
Thanks to b_weijenberg for showing me - that when Meiantech/Atlantic ONLY is enabled in mode - the device is sending out the correct message:
Sequence nbr  = 0
id1-3         = 5581AA decimal:5603754
status        = Motion
battery level = OK
So does that mean this device has the same ID as one of my lightwave devices or something?
And all others work ok because they have different ids?
Thank you!
Posted: Friday 26 January 2018 19:09
by binbo
Sorry, just updating post - when "undecoded and Meiantech/Atlantic/Aidebao" mode is set - the message is:
UNDECODED VISONIC:236303548860
Sequence nbr  = 122
id1-3         = B181AA decimal:11633066
status        = Motion
battery level = OK
