Python - How to POST JSON data
Posted: Sunday 14 January 2018 23:50
I have searched and tested for 9 hours now, and i cannot figure out how to make a (seemly simple) JSON POST (not a http url request/get) using Domoticz json.htm url.
I do NOT preffer sending/updating data for bussiness customers over a URL request (GET), like this:
Why? Because data you are sending with this method is visible on the network (tcp/wifi sniffer) and not encoded with an URL request, when using a POST u can use HTTPS, so data is send encoded after the HTTPS TCP tunnel is created.
Now....all i get back is ERR, in the wiki is stated a pass is needed, so setting domoticz config:
name "jan"
pass "1234"
Basic-Auth
But nevertheless i cannot get it to work....maybe i am overlooking something....any ideas?
TESTSCRIPT
#!/usr/bin/python
import subprocess
import time
import os
import urllib2, urllib
import base64
import requests
import json
from requests.auth import HTTPBasicAuth
serverIP = "192.168.1.1:8080"
#serverIP = "localhost:8080"
deviceId = 1
base64string = base64.b64encode('%s:%s' % ("jan", "1234"))
#currentTemp = subprocess.check_output(["/opt/vc/bin/vcgencmd","measure_temp"])
#currentTemp = float(currentTemp.split("=")[1][:-3])
payload = {'type': 'command', 'param': 'udevice', 'idx': '1', 'nvalue': '0', 'svalue': '55'}
headers = {'Content-type': 'application/json', 'Accept': 'text/plain'}
headers64 = {'Content-type': 'application/json', 'Accept': 'text/plain', 'Authorization': 'Basic %s' % base64string}
print 'Authorization: Basic %s' % base64string
r = requests.post("http://" + serverIP + "/json.htm",data={'type':'command', 'param':'udevice', 'idx':1, 'nvalue':0, 'svalue':55}, headers=headers)
print r.status_code, r.reason
print r.text
r = requests.post("http://" + serverIP + "/json.htm", data=payload, headers=headers)
print r.text
r = requests.post("http://192.168.1.1:8080/json.htm", "amFuOkpBTg==", json={'type': 'command', 'param': 'udevice', 'idx': '1', 'nvalue': '0', 'svalue': '55'}, headers=headers)
print r.text
r = requests.post("http://192.168.2.12:8080/json.htm", json={'type': 'command', 'param': 'udevice', 'idx': '1', 'nvalue': '0', 'svalue': '55'}, headers={"Authorization": "Basic amFuOkpBTg=="})
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), data=json.dumps(payload), headers=headers)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), data=json.dumps(payload))
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), data=payload, headers=headers)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), data=payload)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), json=payload)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), json=json.dumps(payload))
print r.text
r = requests.post("http://" + serverIP + "/json.htm", auth=HTTPBasicAuth('jan', '1234'), json=payload, headers=headers)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", json=payload, headers=headers64)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", data=payload, headers=headers64)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", json=json.dumps(payload), headers=headers64)
print r.text
r = requests.post("http://" + serverIP + "/json.htm", data=json.dumps(payload), headers=headers64)
print r.text
RESULT
Authorization: Basic amFuOkpBTg==
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
http://192.168.1.1:8080/json.htm?type=command¶m=udevice&idx=1&nvalue=15Now....all i get back is ERR, in the wiki is stated a pass is needed, so setting domoticz config:
name "jan"
pass "1234"
Basic-Auth
TESTSCRIPT
#!/usr/bin/python
import subprocess
import time
import os
import base64
import requests
import json
deviceId = 1
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
print r.text
RESULT
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
200 OK
"status" : "ERR"
