Help needed - Blocky Humidity Ventilation and Light Switch Combination
Posted: Sunday 14 January 2018 12:51
by Quinternet
I'm trying to create the following scenario:
* I want my ventilation system to switch on when my humidity sensor in the bathroom is above 65% and swithed off when it's below 64%.
* I also want the ventilation system to switch on for 15 minutes when one of the toilet lights are switched on
* When one of the toilet lights is switched off I want the ventilation system to run for 5 minutes and then automatically switch off
In the event I created, the ventilation system switches on and off based on the humidity sensor. That's great. But when I switch the toilet light on and/or off and the humidity sensor is still below 64% the ventilation system is sent the 'on' command by my event, but immediatly switches off again because of the humidity value. Which probably is logical, but now I have no idea how to reach my goal.
Translation of the devices in the event:
* Cresta Badkamer = Humidity sensor in the bathroom
* Warmte Terugwin Unit = Ventilation System
* Toilet BG - Fan Switch = Light switch in the ground floor toilet
* Toilet 1e - Fan Switch = Light switch in the first floow toilet
I'm sorry if this seems dumb, I'm a beginner and certainly not a programmer, but really want this to work and I'm working on this for weeks now.
I hope someone can help me realize my wish.
Re: Help needed - Blocky Humidity Ventilation and Light Switch Combination
Posted: Sunday 14 January 2018 13:32
by Eddiever
I wouldn't do this in just one blocky. I suggest you could do it with three blocky's. One for the humidity, one for the lightswithc in toilet 1 and the last one for toilet BG.
Posted: Sunday 14 January 2018 13:55
by Quinternet
Eddiever wrote: Sunday 14 January 2018 13:32
Thanks for your fast reply!
That's what I started with, but had the exact same problem.
Posted: Sunday 14 January 2018 14:19
by Eddiever
And what if you just use If switch is on do Warmte Terugwin Unit = on for 15 minutes. Leave the option of the switch = off etc.
Posted: Sunday 14 January 2018 14:28
by Quinternet
Eddiever wrote: Sunday 14 January 2018 14:19
Then the same problem occurs. The humidity sensor is still below 64% and tells the ventilation system to go off
Posted: Sunday 14 January 2018 14:39
by StanHD
Below is my blockly that has been working nicely for over a year now. It has more complexity because it copes with 2 fan speeds on the humidity, as well as 3 position manual override, using a selector switch. Also it is conditional on occupancy.
The whole thing works due to the use of a variable that is set according to each scenario.
The top part is probably where you may find what your'e looking for.
Hope it may offer some help.
Posted: Sunday 14 January 2018 14:57
by Quinternet
StanHD wrote: Sunday 14 January 2018 14:39
Hi StanHD,
Thanks for your suggestion. Within your event my solution is probably present, but this is too complex for me in order to translate your example to my situation. Also I'm puzzled by how you were able to embed multiple 'And/or' arguments.... Sorry
Posted: Sunday 14 January 2018 15:47
by StanHD
If you right click the And/Or block you will see some options. Select "External Inputs".
(You would use 2 different devices for WC Light, but shown is just for reference to illustrate the And / Or scenarios.)
Sorry for the complexity, however, I have had a quick go at it and perhaps you can modify / work something from this:-
Posted: Sunday 14 January 2018 15:55
by Quinternet
StanHD wrote: Sunday 14 January 2018 15:47
Ok, that makes sense a bit more... Can you give me a little translation of what your event does? Which device is what and what it does?
Posted: Sunday 14 January 2018 19:51
by StanHD
Ok:-
WC - Light = Your Light switches (2 Yes?)
ExtractFan = Integer Variable
Extract Fan = Extract Fan
WC Light On.
"If" looks for either light switch to turn on. It also checks the value of the variable. If it's 0 then the fan is stopped and can therefore be turned on. When turned on the variable is updated to 1
WC Light Overrun
"Else if" checks for change of both light switches from on to off, it also checks that the fan is not being used for dehum, by checking the variable. (Not = 2). Then keeps fan running for 15 minutes.
High Humidity
"Else if" checks humidity, and checks variable is 0. This means fan is not running or on overrun from WC Light switches.
Low Humidity
"Else if" checks humidity, and the variable. ( think I made a mistake this should be "not=0"), and stops the fan.
To be honest as I said above this was a quick thrown together Blockly that Will probably need some more work. Playing with the variable values etc.
I needed to make adjustments to my original Blockly a few times, but it works well.
Posted: Sunday 14 January 2018 21:01
by Quinternet
StanHD wrote: Sunday 14 January 2018 19:51
Ok:-
WC Light On.
WC Light Overrun
High Humidity
Low Humidity
Ok, fantastic!! Thanks!
I think I got it. I'm still testing, but this is the result, what do you think?:
Posted: Sunday 14 January 2018 21:13
by StanHD
Looking good. The fan switches off may need to be "and" instead of "or", but that's just an opinion. If it works how you want it to then its all good.
It may be worth checking the log to make sure there are no loops or excessive entries.
Posted: Sunday 14 January 2018 21:36
by Quinternet
I spoke too soon.... The Toilet switches seem to work, and when the humidity sensor is above 65%, the ventilation goes on and the variable changes to '2'. But when it drops below 64%, the ventilation stays on and the variable doesn't change back to ''0'
