For those who look for the same thing, i found the script in the French Domoticz Web site:
1. You have to enter your emoncms write API key to local API_KEY
2. The commandArray line at the end works for Synology. In your case if it doesn't work, comment out this line and uncomment the os.execute line.
3. If you don't have accented characters in your language, you can comment out sans_accent function and the calls to sans_comment function inside the script.
--[[script_time_export_emoncms.lua
auteur : papoo
maj : 23/04/2017
date : 18/05/2016
Principle:
export the meter data, temperatures, etc. on the website https://emoncms.org/
The script is read every minute but only exports the data every 2 minutes
http://easydomoticz.com/forum/viewtopic.php?f=17&t=2017
------------ Variables à éditer ------------
local nom_script = "export emoncms"
local version = "2.01"
local debugging = false -- true to see the logs in the console log Dz or false to not see them
local url_emoncms = 'http://emoncms.org/api/'
local API_key = 'YOU EMONCMS KEY' -- create a string variable containing your 32-character Write KEY emoncms API code
local les_devices = {}; -- no more than 11 devices
-- if you want to go up the values of a device which has several of them (ex: temperature and external hygrometry)
--process the name of the value to be raised (from the second value) and the order number in the channel (see examples below les_devices [9] and les_devices [17])
les_devices[1] = {device="Home Watt", nom="", canal=""} -- 1er compteur
les_devices[2] = {device="kWh Meter", nom="", canal=""} -- 2eme compteur
les_devices[3] = {device="Voltage", nom="", canal=""}-- 3eme compteur
-- les_devices[4] = {device="Counter Taken", nom="", canal=""}
-- les_devices[5] = {device="Lights Counter", nom="", canal=""}
--les_devices[6] = {device="Technical Counter", nom="", canal=""}
--les_devices[7] = {device="DJU", nom="", canal=""}
--les_devices[8] = {device="Temperature exterieure", nom="", canal=""}
--les_devices[8] = {device="External Temperature", nom="Humidité", canal=2}
--les_devices[9] = {device="Salon Temperature", nom="", canal=""}
--les_devices[10] = {device="1st floor corridor", nom="", canal=""}
--les_devices[11] = {device="Icing point", nom="", canal=""}
--les_devices[12] = {device="Dew point", nom="", canal=""}
--les_devices[13] = {device="Temp départ chauffage", nom="", canal=""}
--les_devices[14] = {device="Temp retour chauffage", nom="", canal=""}
--les_devices[16] = {device="Temp Parents", nom="", canal=""}
--les_devices[17] = {device="anémometre", nom="direction", canal=2}
local fields =""
----------- Fin variables à éditer ---------
---------------- Fonctions -----------------
function voir_les_logs (s)
if (debugging) then
print ("<font color='#f3031d'>".. s .."</font>");
function sans_accent(str)
if (str) then
str = string.gsub (str,"Ç", "C")
str = string.gsub (str,"ç", "c")
str = string.gsub (str,"Ö", "O")
str = string.gsub (str,"ö", "o")
str = string.gsub (str,"Ğ", "G")
str = string.gsub (str,"ğ", "g")
str = string.gsub (str,"Ü", "U")
str = string.gsub (str,"ü", "u")
str = string.gsub (str,"Ş", "S")
str = string.gsub (str,"ş", "s")
str = string.gsub (str,"İ", "I")
str = string.gsub (str,"ı", "i")
return (str)
function split(inputstr, sep)
if sep == nil then
sep = "%s"
local t={} ; i=1
for str in string.gmatch(inputstr, "([^"..sep.."]+)") do
t[i] = str
i = i + 1
return t
end -- usage : valeurs = split(variable,";")
function urlencode(str)
if (str) then
str = string.gsub (str, "\n", "\r\n")
str = string.gsub (str, "([^%w ])",
function (c) return string.format ("%%%02X", string.byte(c)) end)
str = string.gsub (str, " ", "+")
return str
-------------- Fin Fonctions ---------------
time=os.date("*t")
if time.min % 2 == 0 then -- export des données toutes les 2 minutes
voir_les_logs("=========== ".. nom_script .." (v".. version ..") ===========",debugging)
voir_les_logs("--- --- --- Export vers emoncms : "..time.hour.. ":" ..time.min,debugging)
for i,d in ipairs(les_devices) do
v=otherdevices[d.device]
c=tonumber(d.canal)
voir_les_logs("--- --- --- ".. sans_accent(d.device) .." = "..(v or "nil"),debugging)
voir_les_logs("--- --- --- canal = "..(c or "nil"),debugging)
if v~= nil then v,nbCommas=string.gsub(v,";",";") end-- verification of the presence of one or more semicolon => multiple values
if nbCommas > 1 and c ~= nil then
voir_les_logs("--- --- --- valeurs multiples dans ".. sans_accent(d.device) .." = ".. v,debugging)
voir_les_logs("--- --- --- Nb de point virgule = "..(nbCommas or "nil"),debugging)
local valeurs = split(v,";")
voir_les_logs("--- --- --- valeur 1 = "..(valeurs[1] or "nil"),debugging)
voir_les_logs("--- --- --- valeur 2 = "..(valeurs[2] or "nil"),debugging)
voir_les_logs("--- --- --- valeur 3 = "..(valeurs[3] or "nil"),debugging)
voir_les_logs("--- --- --- valeur 4 = "..(valeurs[4] or "nil"),debugging)
fields = fields .. '{'.. d.nom .. ':' .. valeurs[c] .. '},'
fields = fields .. '{'.. d.device .. ':' .. v .. '},'
fields = string.gsub (fields, ",$", "") -- deleting the last comma
fields = urlencode(sans_accent(fields)) -- deleting accented characters
voir_les_logs("--- --- --- ".. url_emoncms ..'post?apikey=' .. API_key .. '&json=' .. fields ,debugging)
commandArray[1]={['OpenURL']=url_emoncms ..'post?apikey=' .. API_key .. '&json=' .. fields }
--os.execute('curl -m5 "'..url_emoncms ..'post?apikey=' .. API_key .. '&json=' .. fields)
voir_les_logs("========= Fin ".. nom_script .." (v".. version ..") =========",debugging)
end -- if time
