EvoHome stopped working
Posted: Thursday 11 January 2018 12:45
by hans66
I did "install" EvoHome Web API, and all worked fine, till ~Nov 18 2017; since then, I get
Error: (EvoHome) HTTP client error at login!
I am running Domoticz in a docker container, and it gets updated every week to latest git release, hence, one of the changes is an updated Domoticz.
I left poll interface at 60seconds; it did work for one month...till ~ Nov 18.
Any clues?
I noticed that in the code there is still a reference to rs.alarmnet.com, while my understanding is that it should be replaced by tccna.honeywell.com; I did change this, and did a rebuild, it did not help.
Cheers
Hans
Re: EvoHome stopped working
Posted: Thursday 11 January 2018 19:24
by hans66
Any suggestions how to get more debug info?
I did test my access in a shell, but I believe this is the old API, while domoticz uses the new API
curl -X POST -H "Content-Type: application/json" -d '{
"username": "**********",
"password": "***********",
"ApplicationId": "91db1612-73fd-4500-91b2-e63b069b185c"
}' 'https://tccna.honeywell.com/WebAPI/api/Session'
does results in a valid response.
What would be the V2 version of above?
Posted: Friday 12 January 2018 12:49
by waaren
@gordonb3,
forum rule prevents me from attaching dump files created on my PI-3 so I add them as text in code box. I created them with
tcpdump -A -XX -v host 199.62.84.94 -i  eth0
first one is from a domoticz version 8627 (obtained via ./updatebeta) with this version my evohome hardware and devices are OK in domoticz
10:59:20.802024 IP (tos 0x0, ttl 64, id 39015, offset 0, flags [DF], proto TCP (6), length 60)
    PI-1.58432 > 199.62.84.94.https: Flags [S], cksum 0x9ca7 (incorrect -> 0xa687), seq 2226410303, win 29200, options [mss 1460,sackOK,TS val 161991512 ecr 0,nop,wscale 7], length 0
	0x0000:  20d5 bfba ab16 b827 eb09 c1c2 0800 4500  .......'......E.
	0x0010:  003c 9867 4000 4006 05dc c0a8 c033 c73e  .<.g@[email protected].>
	0x0020:  545e e440 01bb 84b4 533f 0000 0000 a002  T^[email protected]?......
	0x0030:  7210 9ca7 0000 0204 05b4 0402 080a 09a7  r...............
	0x0040:  cb58 0000 0000 0103 0307                 .X........
10:59:20.930952 IP (tos 0x0, ttl 244, id 52978, offset 0, flags [DF], proto TCP (6), length 48)
    199.62.84.94.https > PI-1.58432: Flags [S.], cksum 0x210a (correct), seq 1060022735, ack 2226410304, win 8190, options [mss 1360,nop,wscale 4], length 0
	0x0000:  b827 eb09 c1c2 20d5 bfba ab16 0800 4500  .'............E.
	0x0010:  0030 cef2 4000 f406 1b5c c73e 545e c0a8  .0..@....\.>T^..
	0x0020:  c033 01bb e440 3f2e a9cf 84b4 5340 7012  .3...@?.....S@p.
	0x0030:  1ffe 210a 0000 0204 0550 0103 0304       ..!......P....
10:59:20.931015 IP (tos 0x0, ttl 64, id 39016, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.58432 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x6b87), ack 1, win 229, length 0
	0x0010:  0028 9868 4000 4006 05ef c0a8 c033 c73e  .(.h@[email protected].>
	0x0020:  545e e440 01bb 84b4 5340 3f2e a9d0 5010  T^[email protected]@?...P.
	0x0030:  00e5 9c93 0000                           ......
10:59:20.987793 IP (tos 0x0, ttl 64, id 39017, offset 0, flags [DF], proto TCP (6), length 557)
    PI-1.58432 > 199.62.84.94.https: Flags [P.], cksum 0x9e98 (incorrect -> 0x7713), seq 1:518, ack 1, win 229, length 517
	0x0010:  022d 9869 4000 4006 03e9 c0a8 c033 c73e  .-.i@[email protected].>
	0x0020:  545e e440 01bb 84b4 5340 3f2e a9d0 5018  T^[email protected]@?...P.
	0x0030:  00e5 9e98 0000 1603 0102 0001 0001 fc03  ................
	0x0040:  03d2 34ae 9503 8656 c873 7805 9ee1 a043  ..4....V.sx....C
	0x0050:  6847 3484 5784 0253 77ac 1f35 fba2 c2e7  hG4.W..Sw..5....
	0x0060:  2600 008c c030 c02c c028 c024 c014 c00a  &....0.,.(.$....
	0x0070:  00a5 00a3 00a1 009f 006b 006a 0069 0068  .........k.j.i.h
	0x0080:  0039 0038 0037 0036 0088 0087 0086 0085  .9.8.7.6........
	0x0090:  c032 c02e c02a c026 c00f c005 009d 003d  .2...*.&.......=
	0x00a0:  0035 0084 c02f c02b c027 c023 c013 c009  .5.../.+.'.#....
	0x00b0:  00a4 00a2 00a0 009e 0067 0040 003f 003e  .........g.@.?.>
	0x00c0:  0033 0032 0031 0030 009a 0099 0098 0097  .3.2.1.0........
	0x00d0:  0045 0044 0043 0042 c031 c02d c029 c025  .E.D.C.B.1.-.).%
	0x00e0:  c00e c004 009c 003c 002f 0096 0041 00ff  .......<./...A..
	0x00f0:  0100 0147 0000 0018 0016 0000 1374 6363  ...G.........tcc
	0x0100:  6e61 2e68 6f6e 6579 7765 6c6c 2e63 6f6d  na.honeywell.com
	0x0110:  000b 0004 0300 0102 000a 001c 001a 0017  ................
	0x0120:  0019 001c 001b 0018 001a 0016 000e 000d  ................
	0x0130:  000b 000c 0009 000a 000d 0020 001e 0601  ................
	0x0140:  0602 0603 0501 0502 0503 0401 0402 0403  ................
	0x0150:  0301 0302 0303 0201 0202 0203 000f 0001  ................
	0x0160:  0133 7400 0000 1000 0b00 0908 6874 7470  .3t.........http
	0x0170:  2f31 2e31 0015 00c3 0000 0000 0000 0000  /1.1............
	0x0180:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x0190:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01a0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01b0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01c0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01d0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01e0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x01f0:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x0200:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x0210:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x0220:  0000 0000 0000 0000 0000 0000 0000 0000  ................
	0x0230:  0000 0000 0000 0000 0000 00              ...........
10:59:21.116112 IP (tos 0x0, ttl 244, id 52980, offset 0, flags [DF], proto TCP (6), length 1400)
    199.62.84.94.https > PI-1.58432: Flags [P.], cksum 0x2ca0 (correct), seq 1:1361, ack 518, win 2166, length 1360
	0x0010:  0578 cef4 4000 f406 1612 c73e 545e c0a8  .x..@......>T^..
	0x0020:  c033 01bb e440 3f2e a9d0 84b4 5545 5018  .3...@?.....UEP.
	0x0030:  0876 2ca0 0000 1603 030e db02 0000 5c03  .v,...........\.
	0x0040:  035a 588e 32c2 e0a4 f806 3d69 7f76 4c14  .ZX.2.....=i.vL.
	0x0050:  b03a fb17 b652 ac71 0f67 1ee9 e9ff 6aa8  .:...R.q.g....j.
	0x0060:  5320 e148 3936 e2e4 612f a4b6 427c 0e1c  S..H96..a/..B|..
	0x0070:  8de3 e3b5 a067 f2eb 836e d994 5154 d517  .....g...n..QT..
	0x0080:  7e15 0035 0000 14ff 0100 0100 0010 000b  ~..5............
	0x0090:  0009 0868 7474 702f 312e 310b 000e 7300  ...http/1.1...s.
	0x00a0:  0e70 0005 e930 8205 e530 8204 cda0 0302  .p...0...0......
	0x00b0:  0102 0210 077a 5889 84fd 1127 c433 f2cb  .....zX....'.3..
	0x00c0:  65ed c0fd 300d 0609 2a86 4886 f70d 0101  e...0...*.H.....
	0x00d0:  0b05 0030 7031 0b30 0906 0355 0406 1302  ...0p1.0...U....
	0x00e0:  5553 3115 3013 0603 5504 0a13 0c44 6967  US1.0...U....Dig
	0x00f0:  6943 6572 7420 496e 6331 1930 1706 0355  iCert.Inc1.0...U
	0x0100:  040b 1310 7777 772e 6469 6769 6365 7274  ....www.digicert
	0x0110:  2e63 6f6d 312f 302d 0603 5504 0313 2644  .com1/0-..U...&D
	0x0120:  6967 6943 6572 7420 5348 4132 2048 6967  igiCert.SHA2.Hig
	0x0130:  6820 4173 7375 7261 6e63 6520 5365 7276  h.Assurance.Serv
	0x0140:  6572 2043 4130 1e17 0d31 3730 3932 3530  er.CA0...1709250
	0x0150:  3030 3030 305a 170d 3138 3131 3031 3132  00000Z..18110112
	0x0160:  3030 3030 5a30 818d 310b 3009 0603 5504  0000Z0..1.0...U.
	0x0170:  0613 0255 5331 1330 1106 0355 0408 130a  ...US1.0...U....
	0x0180:  4e65 7720 4a65 7273 6579 3116 3014 0603  New.Jersey1.0...
	0x0190:  5504 0713 0d4d 6f72 7269 7320 506c 6169  U....Morris.Plai
	0x01a0:  6e73 3125 3023 0603 5504 0a13 1c48 6f6e  ns1%0#..U....Hon
	0x01b0:  6579 7765 6c6c 2049 6e74 6572 6e61 7469  eywell.Internati
	0x01c0:  6f6e 616c 2049 6e63 2e31 0c30 0a06 0355  onal.Inc.1.0...U
	0x01d0:  040b 1303 4543 4331 1c30 1a06 0355 0403  ....ECC1.0...U..
	0x01e0:  1313 5443 434e 412e 686f 6e65 7977 656c  ..TCCNA.honeywel
	0x01f0:  6c2e 636f 6d30 8201 2230 0d06 092a 8648  l.com0.."0...*.H
	0x0200:  86f7 0d01 0101 0500 0382 010f 0030 8201  .............0..
	0x0210:  0a02 8201 0100 b5d8 bd39 075d 12bb dae1  .........9.]....
	0x0220:  b91a e9c8 9f90 48fd 6898 eacf 0fd9 5d82  ......H.h.....].
	0x0230:  09c2 de4a d24e 8540 a706 2bd7 7a6d 33df  ...J.N.@..+.zm3.
	0x0240:  2872 9d25 2ebd 0282 4686 58ef 166c 50b1  (r.%....F.X..lP.
	0x0250:  31ed b96c a5df cb57 0a82 b7c7 51fb 16ac  1..l...W....Q...
	0x0260:  e32e 91f9 4c81 73ae 88f5 d7bb 000e 9c9c  ....L.s.........
	0x0270:  1f32 4b8a af2e 38e6 ec7a 1d16 73bf 1922  .2K...8..z..s.."
	0x0280:  c7ea 143c 6fdc 635a 736a 4db4 d673 d063  ...<o.cZsjM..s.c
	0x0290:  a2dc fcea e886 5041 af5a 7f39 3e20 95fb  ......PA.Z.9>...
	0x02a0:  92c7 3802 260f 824e e1e7 f2ea 84bf 7c5e  ..8.&..N......|^
	0x02b0:  b871 9ccd e6ee 69c9 3b45 a0a1 5bff 5319  .q....i.;E..[.S.
	0x02c0:  c5eb da0d 4da1 b11c 8e63 0193 8dc6 1faa  ....M....c......
	0x02d0:  7745 9316 8b5c a63b e46d b01d b5db b014  wE...\.;.m......
	0x02e0:  70f1 1e12 9da7 8fe5 dd56 e98a 5582 2a7b  p........V..U.*{
	0x02f0:  53aa 1508 c4d8 d2df 62ec d1c3 c1c0 644c  S.......b.....dL
	0x0300:  35b2 d966 e768 0de7 2b76 16de a338 137b  5..f.h..+v...8.{
	0x0310:  1cc1 bb53 a7d1 0203 0100 01a3 8202 5b30  ...S..........[0
	0x0320:  8202 5730 1f06 0355 1d23 0418 3016 8014  ..W0...U.#..0...
	0x0330:  5168 ff90 af02 0775 3ccc d965 6462 a212  Qh.....u<..edb..
	0x0340:  b859 723b 301d 0603 551d 0e04 1604 14ed  .Yr;0...U.......
	0x0350:  3516 2295 816a 5e6f 3ba6 9061 51fe b20d  5."..j^o;..aQ...
	0x0360:  4e2f a130 818c 0603 551d 1104 8184 3081  N/.0....U.....0.
	0x0370:  8182 1354 4343 4e41 2e68 6f6e 6579 7765  ...TCCNA.honeywe
	0x0380:  6c6c 2e63 6f6d 8213 5443 4345 552e 686f  ll.com..TCCEU.ho
	0x0390:  6e65 7977 656c 6c2e 636f 6d82 1354 4343  neywell.com..TCC
	0x03a0:  4150 2e68 6f6e 6579 7765 6c6c 2e63 6f6d  AP.honeywell.com
	0x03b0:  8214 5443 434e 4153 2e68 6f6e 6579 7765  ..TCCNAS.honeywe
	0x03c0:  6c6c 2e63 6f6d 8214 5443 4345 5553 2e68  ll.com..TCCEUS.h
	0x03d0:  6f6e 6579 7765 6c6c 2e63 6f6d 8214 5443  oneywell.com..TC
	0x03e0:  4341 5053 2e68 6f6e 6579 7765 6c6c 2e63  CAPS.honeywell.c
	0x03f0:  6f6d 300e 0603 551d 0f01 01ff 0404 0302  om0...U.........
	0x0400:  05a0 301d 0603 551d 2504 1630 1406 082b  ..0...U.%..0...+
	0x0410:  0601 0505 0703 0106 082b 0601 0505 0703  .........+......
	0x0420:  0230 7506 0355 1d1f 046e 306c 3034 a032  .0u..U...n0l04.2
	0x0430:  a030 862e 6874 7470 3a2f 2f63 726c 332e  .0..http://crl3.
	0x0440:  6469 6769 6365 7274 2e63 6f6d 2f73 6861  digicert.com/sha
	0x0450:  322d 6861 2d73 6572 7665 722d 6731 2e63  2-ha-server-g1.c
	0x0460:  726c 3034 a032 a030 862e 6874 7470 3a2f  rl04.2.0..http:/
	0x0470:  2f63 726c 342e 6469 6769 6365 7274 2e63  /crl4.digicert.c
	0x0480:  6f6d 2f73 6861 322d 6861 2d73 6572 7665  om/sha2-ha-serve
	0x0490:  722d 6731 2e63 726c 304c 0603 551d 2004  r-g1.crl0L..U...
	0x04a0:  4530 4330 3706 0960 8648 0186 fd6c 0101  E0C07..`.H...l..
	0x04b0:  302a 3028 0608 2b06 0105 0507 0201 161c  0*0(..+.........
	0x04c0:  6874 7470 733a 2f2f 7777 772e 6469 6769  https://www.digi
	0x04d0:  6365 7274 2e63 6f6d 2f43 5053 3008 0606  cert.com/CPS0...
	0x04e0:  6781 0c01 0202 3081 8306 082b 0601 0505  g.....0....+....
	0x04f0:  0701 0104 7730 7530 2406 082b 0601 0505  ....w0u0$..+....
	0x0500:  0730 0186 1868 7474 703a 2f2f 6f63 7370  .0...http://ocsp
	0x0510:  2e64 6967 6963 6572 742e 636f 6d30 4d06  .digicert.com0M.
	0x0520:  082b 0601 0505 0730 0286 4168 7474 703a  .+.....0..Ahttp:
	0x0530:  2f2f 6361 6365 7274 732e 6469 6769 6365  //cacerts.digice
	0x0540:  7274 2e63 6f6d 2f44 6967 6943 6572 7453  rt.com/DigiCertS
	0x0550:  4841 3248 6967 6841 7373 7572 616e 6365  HA2HighAssurance
	0x0560:  5365 7276 6572 4341 2e63 7274 300c 0603  ServerCA.crt0...
	0x0570:  551d 1301 01ff 0402 3000 300d 0609 2a86  U.......0.0...*.
	0x0580:  4886 f70d 0101                           H.....
10:59:21.116218 IP (tos 0x0, ttl 64, id 39018, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.58432 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x641d), ack 1361, win 250, length 0
	0x0010:  0028 986a 4000 4006 05ed c0a8 c033 c73e  .(.j@[email protected].>
	0x0020:  545e e440 01bb 84b4 5545 3f2e af20 5010  T^[email protected]?...P.
	0x0030:  00fa 9c93 0000
	etc.....
2nd one is from domoticz version 8799 compiled from source (because ./updatebeta versions gives me fatal errors on my Python plugins ) with this version I see "Error: (Evohome) HTTP client error at login!"in my logfile
11:09:57.016460 IP (tos 0x0, ttl 64, id 44829, offset 0, flags [DF], proto TCP (6), length 60)
    PI-1.59196 > 199.62.84.94.https: Flags [S], cksum 0x9ca7 (incorrect -> 0x9050), seq 2246339779, win 29200, options [mss 1460,sackOK,TS val 162055134 ecr 0,nop,wscale 7], length 0
	0x0010:  003c af1d 4000 4006 ef25 c0a8 c033 c73e  .<..@.@..%...3.>
	0x0020:  545e e73c 01bb 85e4 6cc3 0000 0000 a002  T^.<....l.......
	0x0030:  7210 9ca7 0000 0204 05b4 0402 080a 09a8  r...............
	0x0040:  c3de 0000 0000 0103 0307                 ..........
11:09:57.145261 IP (tos 0x0, ttl 244, id 42338, offset 0, flags [DF], proto TCP (6), length 48)
    199.62.84.94.https > PI-1.59196: Flags [S.], cksum 0x0a77 (correct), seq 1546880429, ack 2246339780, win 8190, options [mss 1360,nop,wscale 4], length 0
	0x0010:  0030 a562 4000 f406 44ec c73e 545e c0a8  [email protected]..>T^..
	0x0020:  c033 01bb e73c 5c33 85ad 85e4 6cc4 7012  .3...<\3....l.p.
	0x0030:  1ffe 0a77 0000 0204 0550 0103 0304       ...w.....P....
11:09:57.145368 IP (tos 0x0, ttl 64, id 44830, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59196 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x54f4), ack 1, win 229, length 0
	0x0010:  0028 af1e 4000 4006 ef38 c0a8 c033 c73e  .(..@[email protected].>
	0x0020:  545e e73c 01bb 85e4 6cc4 5c33 85ae 5010  T^.<....l.\3..P.
11:09:57.145661 IP (tos 0x0, ttl 64, id 44831, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59196 > 199.62.84.94.https: Flags [F.], cksum 0x9c93 (incorrect -> 0x54f3), seq 1, ack 1, win 229, length 0
	0x0010:  0028 af1f 4000 4006 ef37 c0a8 c033 c73e  .(..@[email protected].>
	0x0020:  545e e73c 01bb 85e4 6cc4 5c33 85ae 5011  T^.<....l.\3..P.
11:09:57.275372 IP (tos 0x0, ttl 244, id 42340, offset 0, flags [DF], proto TCP (6), length 40)
    199.62.84.94.https > PI-1.59196: Flags [F.], cksum 0x4d20 (correct), seq 1, ack 2, win 2231, length 0
	0x0010:  0028 a564 4000 f406 44f2 c73e 545e c0a8  .([email protected]..>T^..
	0x0020:  c033 01bb e73c 5c33 85ae 85e4 6cc5 5011  .3...<\3....l.P.
	0x0030:  08b7 4d20 0000 0000 0000 0000            ..M.........
11:09:57.275520 IP (tos 0x0, ttl 64, id 44832, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59196 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x54f2), ack 2, win 229, length 0
	0x0010:  0028 af20 4000 4006 ef36 c0a8 c033 c73e  .(..@[email protected].>
	0x0020:  545e e73c 01bb 85e4 6cc5 5c33 85af 5010  T^.<....l.\3..P.
11:10:57.188168 IP (tos 0x0, ttl 64, id 58170, offset 0, flags [DF], proto TCP (6), length 60)
    PI-1.59296 > 199.62.84.94.https: Flags [S], cksum 0x9ca7 (incorrect -> 0x7468), seq 3192207461, win 29200, options [mss 1460,sackOK,TS val 162061151 ecr 0,nop,wscale 7], length 0
	0x0010:  003c e33a 4000 4006 bb08 c0a8 c033 c73e  .<.:@[email protected].>
	0x0020:  545e e7a0 01bb be45 3865 0000 0000 a002  T^.....E8e......
	0x0040:  db5f 0000 0000 0103 0307                 ._........
11:10:57.316661 IP (tos 0x0, ttl 244, id 21547, offset 0, flags [DF], proto TCP (6), length 48)
    199.62.84.94.https > PI-1.59296: Flags [S.], cksum 0xb9a8 (correct), seq 3213061828, ack 3192207462, win 8190, options [mss 1360,nop,wscale 4], length 0
	0x0010:  0030 542b 4000 f406 9623 c73e 545e c0a8  .0T+@....#.>T^..
	0x0020:  c033 01bb e7a0 bf83 6ec4 be45 3866 7012  .3......n..E8fp.
	0x0030:  1ffe b9a8 0000 0204 0550 0103 0304       .........P....
11:10:57.316784 IP (tos 0x0, ttl 64, id 58171, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59296 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x0426), ack 1, win 229, length 0
	0x0010:  0028 e33b 4000 4006 bb1b c0a8 c033 c73e  .(.;@[email protected].>
	0x0020:  545e e7a0 01bb be45 3866 bf83 6ec5 5010  T^.....E8f..n.P.
11:10:57.317075 IP (tos 0x0, ttl 64, id 58172, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59296 > 199.62.84.94.https: Flags [F.], cksum 0x9c93 (incorrect -> 0x0425), seq 1, ack 1, win 229, length 0
	0x0010:  0028 e33c 4000 4006 bb1a c0a8 c033 c73e  .(.<@[email protected].>
	0x0020:  545e e7a0 01bb be45 3866 bf83 6ec5 5011  T^.....E8f..n.P.
11:10:57.447324 IP (tos 0x0, ttl 244, id 21551, offset 0, flags [DF], proto TCP (6), length 40)
    199.62.84.94.https > PI-1.59296: Flags [F.], cksum 0xfc51 (correct), seq 1, ack 2, win 2231, length 0
	0x0010:  0028 542f 4000 f406 9627 c73e 545e c0a8  .(T/@....'.>T^..
	0x0020:  c033 01bb e7a0 bf83 6ec5 be45 3867 5011  .3......n..E8gP.
	0x0030:  08b7 fc51 0000 0000 0000 0000            ...Q........
11:10:57.447416 IP (tos 0x0, ttl 64, id 58173, offset 0, flags [DF], proto TCP (6), length 40)
    PI-1.59296 > 199.62.84.94.https: Flags [.], cksum 0x9c93 (incorrect -> 0x0424), ack 2, win 229, length 0
	0x0010:  0028 e33d 4000 4006 bb19 c0a8 c033 c73e  .(.=@[email protected].>
	0x0020:  545e e7a0 01bb be45 3867 bf83 6ec6 5010  T^.....E8g..n.P.
Hope you can help
Posted: Friday 12 January 2018 19:46
by waaren
@Gordonb3,
many thanks for your advice !
I recompiled domoticz 8805 on my test PI-3 after a complete refresh from git using.
git clone https://github.com/domoticz/domoticz.git domoticz
cd domoticz
cmake -DUSE_OPENSSL_STATIC="NO" -DCMAKE_BUILD_TYPE=Beta CMakeLists.txt  // this came back with a strange version number
git pull
make -j3 1>make.log 2>make.error        // Stopped in error at the link step because of memory shortage
/sbin/dphys-swapfile setup
/sbin/dphys-swapfile start
/sbin/dphys-swapfile swapon
/sbin/dphys-swapfile status
sysctl vm.swappiness=100
make                  // now successful result domoticz V3.8805  (-rwxr-xr-x 1 root root 27708448 Jan 12 19:10 domoticz)
result is a working domoticz with Evohome via Web API and working Python plugins. (I still see packages from PI to tccna.honeywell.com with incorrect checksums but honeywell is not complaining so why should I :D )
I assume that using -DUSE_OPENSSL_STATIC="NO" results in dynamic linking of the openssl library.
Does this mean that the library in use at https://github.com/domoticz/domoticz is not fit for this purpose ?
Posted: Saturday 27 January 2018 14:33
by hans66
Hi, I got a step closer. I hope someone can still help.
I run Domoticz in a X64 based docker container; works great for me; I build the docker image from scratch, based on an official debian image.
With debian:jessie as base image, all works fine. In Nov, I "upgraded" the Dockerfile to baseimage debian:stretch. When I "downgrade" to jessie, EvoHome works fine again. (note, the packages included for stretch are slightly different from jessie, Dockerfile requires a bit of tinkering).
Building the stretch based Dockerfile does not result in any warnings or errors. Domoticz does work for Hue, WU, and a few other things. Only EvoHome authentication fails....
I can post the stretch based Dockerfile if that helps.
Any clues?
