enable/disable thermostat timers
jimicek
Post by jimicek »
Tried to disable timers via script - this goes well using /json.htm?type=command&param=disabletimer&idx=timerID
However this doesnot work for thermostat timers. What command modification is needed?
From following timers listing is clear, that thermostats have own timerIDs and the command should somehow mark, that dealing with thermostat timers and not standard switch timers
result
0
Active	"true"
Date	""
Days	128
DevName	"Cirkulace"
DeviceRowID	113
Hue	0
IsThermostat	"false"
Level	100
MDay	0
Month	0
Occurence	0
Randomness	"false"
ScheduleDate	"2018-01-12 07:30:00"
Time	"07:30"
TimerCmd	0
TimerID	1
TimerType	2
TimerTypeStr	"On Time"
Type	"Device"
1	{…}
2
Active	"true"
Date	""
Days	128
DevName	"Nastaveni Hostovsky Ventil"
DeviceRowID	107
IsThermostat	"true"
MDay	0
Month	0
Occurence	0
ScheduleDate	"2018-01-12 07:25:00"
Temperature	"22.5"
Time	"07:25"
TimerID	1
TimerType	2
Type	"Device"
3	{…}
status	"OK"
title	"Schedules"
jimicek
Re: enable/disable thermostat timers
Post by jimicek »
answering myself : following command makes the needed timer modification for termostat:
/json.htm?type=command&param=enablesetpointtimer&idx=SetpointTimerIDX
StratosHF
Domoticz version: 2025.1
Post by StratosHF »
Hi y jimicek,
Thanks for posting this, I got stuck in a hole trying to get:
/json.htm?type=command&param=enabletimer&idx=timerID
but it turned out
was what I needed. Thanks.
