What is 'on delay' and 'off delay'?
irongarment
Post by irongarment »
These are two values you can set when configuring a switch, however, they are not documented in the manual or on the wiki.
Thank you.
emme
Domoticz version: latest
Re: What is 'on delay' and 'off delay'?
Post by emme »
On_Delay = the amount of secs between the switch button and its actual state change from off to on
Off_Delay = the amount of secs between the switch button and its actual state change from On to Off
"We always done this way"
irongarment
Thanks.
What is the purpose? Is it so that the button can be flicked back on (or off) quickly without causing the device to change state? Or another reason?
Thank you.
Jem101
Post by Jem101 »
Well as an example I have a nighttime scene which I trigger by either pressing a button or via the Amazon Echo - what it does is to turn on a light in my hallway (so I can see my way up the stairs), turn off all the lights in my living room and then has a 30 second delay before it turns off the kitchen lights.
That way I can trigger the scene, walk out of my living room, walk into the kitchen to take any plates or cups out and then just go up to bed knowing that the living room lights will all be off and that the kitchen light will turn off after 30 seconds.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
irongarment
Ah, got it. Thanks.
This should be documented, however, the manual is not editable, and the wiki doesn't have an entry for switches. What to do?
AlBundy
Domoticz version: 4.9700
Post by AlBundy »
Using V4.9700 the Off Delay for a light/switch isn't working as described by emme.
Emme wrote: Off_Delay = the amount of secs between the switch button and its actual state change from On to Off
My experiences:
Off Delay is the time in seconds the light/switch says On before it switches back to Off.
When you press the light/switch to On it waits Off Delay seconds before it is switched Off again automatically.
So it is not Off Delay but more like "Stay On for xx seconds"
On Delay for a light/switch works as expected but Off Delay doesn't.
This can't be intended, or is it?
AlBundy
Post by AlBundy »
I would like it to be like emme explained.
This makes sense.
AlBundy
Post by AlBundy »
Using a group and setting a Off Delay works as expected.
So why is Off Delay different between a Light/Switch and a Group?
PaulOckenden
Post by PaulOckenden »
Sorry to resurrect an old topic.
I can't get either on or off delay to work for a (z-wave) switch. If I enter 60 seconds for both the specified actions always run instantly.
I'm running Version 4.10717 (May 9th 2019)
Any ideas?
P.
Decyph
Domoticz version: 11838
Post by Decyph »
I was trying to find out the same thing.
It seems that the on delay and off delay of a switch work different.
The off delay turns the switch off again (if switched to on) after x seconds
But the on delay is x seconds from flipping the switch to on and it actually being on.
To me that seems weird.
Version 4.10833
