PI suggest that Domoticz version number, maybe also time/date (even if time/date can be read from file properties), should be inserted in the Backup filename (both automatic and manual backup).
If restoring a backup you only restore the database therefore it is important to know what version you had it running on to avoid possible database issues?
Domoticz Backup filename
