Using a variable as a setpoint?
Posted: Tuesday 09 January 2018 15:54
by freakshock
I would like to use a Domoticz uservariable as a setpoint for my thermostat.
I can't seem to find the correct syntax for this in the wiki.
Right now my thermostat always changes to the same hardcoded value:
domoticz.devices('Thermostat').updateSetPoint(17)
But I would like it to change to whatever is in the uservariable 'Nighttemp'.
Can anyone help me with the correct syntax for dzVents?
Re: Using a variable as a setpoint?
Posted: Tuesday 09 January 2018 16:06
by dannybloe
variables = { 'MySetpointVar' } -- integer variable
execute = function(domoticz, variable)
domoticz.devices('Thermostat').updateSetPoint(variable.value)
This script will make sure that whenever you edit the variable in the GUI, the setpoint is updated.
Posted: Tuesday 16 January 2018 14:46
by freakshock
Thanks for your suggestion Danny, your script works for when I want the change in the variable to directly change the setpoint.
However, I want to be able to choose the setpoint for the coming night, when my domoticz goes into 'sleep mode'.
Is this also possible?
Posted: Tuesday 16 January 2018 14:51
by dannybloe
I don't know what you mean with 'sleep mode'.
Posted: Tuesday 16 January 2018 15:13
by JuanUil
I am using this in my ICY Thermostat.
-- Temperatuur instellingen
dagtemperatuur = uservariables["dagtemperatuur"]
nachttemperatuur = uservariables["nachttemperatuur"]
vorstbeveiliging = uservariables["vorstbeveiliging"]
-- Dagtemperatuur instellen voor werkdagen en weekend
if (werkweek and dag ~= 'Sun'and uur==7 and min>=0 and min<2 and setpoint<dagtemperatuur) then
setpoint=dagtemperatuur
set = "6|0|" .. setpoint
commandArray ['UpdateDevice']= '6|0|' .. setpoint
elseif ((weekend or dag=='Sun')and uur==8 and min>=0 and min<2 and setpoint<dagtemperatuur) then
Posted: Tuesday 16 January 2018 15:23
by CeesCKS
Did you consider to use the "Timers" option from the Thermostat device to change the setpoint value at a given time stamp without programming any code.
Cees
Posted: Tuesday 16 January 2018 20:27
by freakshock
@ Danny,
Sleep mode is just a simple dummy switch I use to switch off my devices for the night, and also to lower the thermostat setpoint.
What I want to be able to do in this case, is to set a variable setpoint, so I can choose the setpoint setting for the coming night in advance.
This is part of my current script for my 'sleep mode':
devices = {
'Sleepmode'},
execute = function(domoticz)
if (domoticz.devices('Sleepmode').state == 'On' then
domoticz.devices('LivingRoomLight').switchOff()
domoticz.devices('Thermostaat').updateSetPoint(17) --[b] I want to set this to a uservariable 'Night_temp[/b]'
How would that look like in dzVents code? Thanks for your patience !
Posted: Wednesday 17 January 2018 8:55
by dannybloe
Then it's probably something like this:
devices = { 'Sleepmode' },
local nightTimeSetpoint = domoticz.variables('Night_temp').value
domoticz.devices('Thermostaat').updateSetPoint(nightTimeSetpoint)
Posted: Friday 19 January 2018 10:52
by freakshock
Great that works! Thanks Danny
