Issue with persistent data
Ric68
Post by Ric68 »
I have been struggling to get persistent data to work without success.
I am running RPI3, Raspian Stretch Lite 2017-11-29 updated and upgraded recently with domoticz V3.8799
What I am trying to accomplish is to increase a lamp to 100% if there is a motion detected and once the motion is off again, revert to the level the lamp had before, in this case 33%
The script is really simple, but I get 'nil' when I am trying to run it.
Any ideas?
	active = true,
		devices = { 'Trapphus Innerdörr' },
		timer = {},
		variables = {}
	data = { OldLevel = {initial=0} },
	logger = {},
	execute = function(domoticz, device, info)
		-- code
	    if (device.state == 'Open') then
	        OldLevel = domoticz.devices('Kök Fönsterlampa').level
	        domoticz.log('Level at ON = ' .. tostring(OldLevel), domoticz.LOG_INFO)
	        domoticz.devices('Kök Fönsterlampa').dimTo(100)
	        domoticz.devices('Kök Fönsterlampa').dimTo(OldLevel)
	        domoticz.log('Level at OFF = ' .. tostring(OldLevel), domoticz.LOG_INFO)
2018-01-09 01:44:20.487 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 01:44:20.487 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 01:44:20.488 dzVents: Info: Level at ON = 33
2018-01-09 01:44:20.489 dzVents: Info: ------ Finished Test
2018-01-09 01:44:20.490 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 01:44:25.132 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 01:44:25.133 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 01:44:25.134 dzVents: Info: Level at OFF = nil
2018-01-09 01:44:25.134 dzVents: Info: ------ Finished Test
2018-01-09 01:44:25.135 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Re: Issue with persistent data
Not sure if this is the best solution but you can try changing "OldLevel" to "domoticz.data.OldLevel" within the if/else construct
emme
Domoticz version: latest
Post by emme »
waaren wrote: Tuesday 09 January 2018 9:46 Not sure if this is the best solution but you can try changing "OldLevel" to "domoticz.data.OldLevel" within the if/else construct
you HAVE to ;)
"We always done this way"
Ric68
Post by Ric68 »
Thank you!
I obviously had missed that detail.
But I still do not get it to work. The persistent data is still nil when I enter the else case.
	active = true,
		timer = {},
		variables = { OldLevel = {initial=0} }
	data = {},
	logger = {},
		-- code
            local Level = domoticz.devices('Kök Fönsterlampa').level
	        domoticz.data.OldLevel = Level
	        domoticz.log('Level at ON = ' .. tostring(Level), domoticz.LOG_INFO)
	        domoticz.log('OldLevel persistent at ON = ' .. tostring(domoticz.data.OldLevel), domoticz.LOG_INFO)
            local Level = domoticz.data.OldLevel
	        domoticz.devices('Kök Fönsterlampa').dimTo(Level)
	        domoticz.log('Level at OFF = ' .. tostring(Level), domoticz.LOG_INFO)
	        domoticz.log('OldLevel persistent at OFF = ' .. tostring(domoticz.data.OldLevel), domoticz.LOG_INFO)
The respons is
2018-01-09 12:04:47.018 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 12:04:47.018 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 12:04:47.019 dzVents: Info: Level at ON = 20
2018-01-09 12:04:47.019 dzVents: Info: OldLevel persistent at ON = 20
2018-01-09 12:04:47.020 dzVents: Info: ------ Finished Test
2018-01-09 12:04:47.020 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 12:05:12.372 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 12:05:12.372 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 12:05:12.374 dzVents: Info: Level at OFF = nil
2018-01-09 12:05:12.374 dzVents: Info: OldLevel persistent at OFF = nil
2018-01-09 12:05:12.374 dzVents: Info: ------ Finished Test
2018-01-09 12:05:12.375 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
dannybloe
Post by dannybloe »
But now you have emptied the data section in your code.
Try this one...
	active = true,
	execute = function(domoticz, TriggerDevice, info)
		DimmableDevice = domoticz.devices('Kök Fönsterlampa')
	  if (TriggerDevice.state == 'Open') then
	        domoticz.data.OldLevel = DimmableDevice.level
	        domoticz.log('Level at ON = ' .. tostring(domoticz.data.OldLevel), domoticz.LOG_INFO)
	        DimmableDevice.dimTo(100)
	        DimmableDevice.dimTo(domoticz.data.OldLevel)
	        domoticz.log('Level at OFF = ' .. tostring(domoticz.data.OldLevel), domoticz.LOG_INFO)
Ric68
Post by Ric68 »
Thank you again, sorry for the confusion with the missing data-segment, but I tried basically everything without getting it to work, so ignore the last post.
So now it work, but I found another problem. Don't know if it is due to Domoticz or dzVents, but there seems to be some kind of rounding somewhere as the level decreases by 6-7 % until it gets fixed at an even decade.
The lamp is a IKEA Trådfri E27 WS opal 980lm with SW 1.2.217 running via Philips Hue Bridge
This is ok if I am at 86% and land at 80%, but I had a case where I started at 13% and the next step was then 0%.
Starting at 86%
2018-01-09 15:06:14.100 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:33.470 dzVents: Info: Handling events for: "Sovrum Rörelse", value: "On"
2018-01-09 15:06:33.470 dzVents: Info: ------ Start internal script: Altan: Device: "Sovrum Rörelse (RfxTrx)", Index: 290
2018-01-09 15:06:33.474 dzVents: Info: Level On = 100
2018-01-09 15:06:33.475 dzVents: Info: ------ Finished Altan
2018-01-09 15:06:33.477 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:41.389 dzVents: Info: Handling events for: "Sovrum Rörelse", value: "Off"
2018-01-09 15:06:41.389 dzVents: Info: ------ Start internal script: Altan: Device: "Sovrum Rörelse (RfxTrx)", Index: 290
2018-01-09 15:06:41.391 dzVents: Info: Level Off = 100
2018-01-09 15:06:41.391 dzVents: Info: ------ Finished Altan
2018-01-09 15:06:41.392 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:41.761 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 15:06:41.761 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:06:41.762 dzVents: Info: Level at ON = 86
2018-01-09 15:06:41.763 dzVents: Info: ------ Finished Test
2018-01-09 15:06:41.764 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:44.587 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 15:06:44.587 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:06:44.588 dzVents: Info: Level at OFF = 86
2018-01-09 15:06:44.589 dzVents: Info: ------ Finished Test
2018-01-09 15:06:44.590 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:46.312 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 15:06:46.312 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:06:46.314 dzVents: Info: Level at ON = 80
2018-01-09 15:06:46.315 dzVents: Info: ------ Finished Test
2018-01-09 15:06:46.316 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:06:48.549 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 15:06:48.549 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:06:48.550 dzVents: Info: Level at OFF = 80
2018-01-09 15:06:48.551 dzVents: Info: ------ Finished Test
Starting at 13%. The first time I close the door, the lamp is still lit, but the second time it is dark and in domoticz I can see that it is not active, i.e. not 6%
2018-01-09 15:16:18.398 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 15:16:18.398 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:16:18.400 dzVents: Info: Level at ON = 13
2018-01-09 15:16:18.400 dzVents: Info: ------ Finished Test
2018-01-09 15:16:18.402 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:16:21.464 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 15:16:21.464 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:16:21.466 dzVents: Info: Level at OFF = 13
2018-01-09 15:16:21.467 dzVents: Info: ------ Finished Test
2018-01-09 15:16:21.469 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:16:24.387 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Open"
2018-01-09 15:16:24.387 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:16:24.388 dzVents: Info: Level at ON = 6
2018-01-09 15:16:24.388 dzVents: Info: ------ Finished Test
2018-01-09 15:16:24.389 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-09 15:16:27.312 dzVents: Info: Handling events for: "Trapphus Innerdörr", value: "Closed"
2018-01-09 15:16:27.312 dzVents: Info: ------ Start internal script: Test: Device: "Trapphus Innerdörr (Zwave)", Index: 318
2018-01-09 15:16:27.314 dzVents: Info: Level at OFF = 6
2018-01-09 15:16:27.317 dzVents: Info: ------ Finished Test
Probably not the optimal solution but sets the dim values back to multiples of 20 (20,40,60,80 or 100)
	active = true,
		function SpecialRound(n)
            		return  math.min(math.max((20 * math.floor(n/20 + 0.5)),20),100)
        	RoundedValue = SpecialRound(domoticz.data.OldLevel)
	        DimmableDevice.dimTo(RoundedValue)
	        domoticz.log('Level at OFF = ' .. tostring(RoundedValue), domoticz.LOG_INFO)
