Convert Lua to dzvents
Posted: Monday 08 January 2018 20:25
by anasazi
I have for some days trying to convert my Lua script to a dzVents script which I use to control my light at home based on time and lux.
Have been trying with all possible combination but I can't figure out how to solve it.
Is there someone who know how to re-write this Lua code into dzvents code?
time                = os.date('%H:%M')
lowLightValue       = tonumber(otherdevices['Luxsensor'])
lowLightSetPoint    = 12
offTime             = 'Off AFTER 1800'
--============================== Köksfönster ==============================--
if (time == '05:30' and lowLightValue < lowLightSetPoint and uservariables['Weekend'] == 'False') then
	commandArray['Köksfönstret']='On'
elseif (time == '07:30' and lowLightValue < lowLightSetPoint and uservariables['Weekend'] == 'True') then
elseif (lowLightValue > lowLightSetPoint and uservariables['lowLightKöksfönster'] == '0' and time > '05:30' and time < '22:30') then
	commandArray['Köksfönstret']=offTime
	commandArray['Variable:lowLightKöksfönster'] = '1'
elseif (lowLightValue < lowLightSetPoint and uservariables['lowLightKöksfönster'] == '1' and time > '05:30' and time < '22:30') then
    commandArray['Variable:lowLightKöksfönster'] = '0'
elseif (time == '22:30') then
   commandArray['Köksfönstret']='Off'
Re: Convert Lua to dzvents
Posted: Monday 08 January 2018 21:37
by emme
try with:
local timer1 = 'at 05:30'
local timer2 = 'at 07:30'
local timer3 = 'between 05:30 and 22:30'
local timer4 = 'at 22:30'
local offTime = 1800
local lowLightSetPoint = 12
	    timer = {
	                timer1,
	                timer2,
	                timer3,
	                timer4
    execute = function(dz,devNil,trgInfo)
        local lowLightValue = dz.devices('Luxsensor')
        if trgInfo.trigger == timer1 and lowLightValue < lowLightSetPoint and dz.variables('Weekend') == 'False' then
            dz.devices('Köksfönstret').switchOn().checkFirst()
        elseif trgInfo.trigger == timer2 and lowLightValue < lowLightSetPoint and dz.variables('Weekend') == 'True' then
            dz.devices('Köksfönstret').switchOff().checkFirst()
        elseif trgInfo.trigger == timer3
            if (lowLightValue > lowLightSetPoint and dz.variables('lowLightKöksfönster') == '0') then
                dz.devices('Köksfönstret').switchOff().afterSec(offTime)  --better to convert 1800 secs to mins and use .afterMin(offTime)
	        dz.variables('lowLightKöksfönster').set('1') -- if variable is a number/integer, remove the ' '
	    elseif (lowLightValue < lowLightSetPoint and dz.variables('lowLightKöksfönster')  == '1' then
	         dz.variables('lowLightKöksfönster').set('0') -- if variable is a number/integer, remove the ' '
	elseif trgInfo.trigger == timer4 then
a note: I use timern because I prefer to put the timer string just once... in case you want to reschedule you just need to edit 1 row
ciao
M
Posted: Tuesday 09 January 2018 8:07
by anasazi
Thank you so much, I will try this later today! :)
