Display Z-Wave max kbps device speed in web interface
ben53252642
Post by ben53252642 »
It's possible to see the maximum speed for a Z-Wave device (according to openzwave) in:
cat domoticzfolder/Config/zwcfg_ZWAVEHOMEID.xml | grep 'max_baud_rate'
Example:
<Node id="30" name="Main Bedroom Wa" location="" basic="4" generic="15" specific="1" roletype="5" devicetype="6912" nodetype="0" type="Basic Repeater Slave" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
max_baud_rate="40000" = 40kbps
There are 3 speeds Z-Wave devices can operate at (depending on hardware):
1) 9.6 kbps
2) 40kbps
3) 100kbps (Z-Wave Plus)
I think we should have the speeds visible in the Domoticz GUI, it would help users identify older devices or devices not operating at their peak performance that might be a bottleneck / slowing down their systems.
Also could we highlight security enabled devices in a difference color, dark blue (on the openzwave hardware page)?
Mostly for my own reference, this command displays z-wave device names that have been included as secure devices:
cat domoticzfolder/Config/zwcfg_ZWAVEHOMEID.xml | grep 'secured' | grep -o -P '(?<=name=).*(?=location)'
Also its possible to get a list of devices supporting Z-Wave beaming with:
cat domoticzfolder/Config/zwcfg_ZWAVEHOMEID.xml | grep 'beaming="true"' | grep -o -P '(?<=name=).*(?=location)'
This is all info that should be probably be accessible in the web GUI somewhere.
Egregius
Domoticz version: v2024.7
Re: Display Z-Wave max kbps device speed in web interface
Post by Egregius »
Not sure why you would need this...
For example my device list:
2	Aeotec DSA03202 Minimote
1	Aeotec ZW090 Z-Stick Gen5 EU
3	Danfoss Z Thermostat 014G0013
6	FIBARO System FGK101 Door Opening Sensor
5	FIBARO System FGMS001 Motion Sensor
9	FIBARO System FGRM222 Roller Shutter Controller 2
1	FIBARO System FGS212 Switch 3kW
4	FIBARO System FGS222 Double Relay Switch 2x1.5kW
6	FIBARO System FGSD002 Smoke Sensor
6	FIBARO System FGWPE/F Wall Plug
1	GreenWave PowerNode 6 port
1	Horstmann ASR-ZW Thermostat Receiver
2	Neo CoolCam Power plug 12A
1	Philio Technology Corporation PH-PSE02.eu Zipato Indoor Siren
6	Qubino ZMNHBA2 Flush 2 Relays
1	Qubino ZMNHCDx Flush Shutter
4	Qubino ZMNHDA2 Flush Dimmer
1	Qubino ZMNHDD1 Flush Dimmer
1	Qubino ZMNHND1 Flush 1D relay
According to OZWCP 12 devices are Zwave plus.
But when I search in the zwcfg xml file all of them have a speed of 40000.
Also, I think you want the 'listening' tag instead of 'beaming'.
Beaming is true on all my devices. The listening tag seems to follow battery or main powered devices:
max_baud_rate	listening	beaming	Device
40000	true	true	Aeotec ZW090 Z-Stick Gen5 EU
40000	true	true	Qubino ZMNHDA2 Flush Dimmer
40000	true	true	Qubino ZMNHBA2 Flush 2 Relays
40000	true	true	GreenWave PowerNode 6 port
40000	true	true	Qubino ZMNHDD1 Flush Dimmer
40000	true	true	Horstmann ASR-ZW Thermostat Receiver
40000	true	true	Qubino ZMNHCDx Flush Shutter
40000	true	true	FIBARO System FGWPE/F Wall Plug
40000	true	true	FIBARO System FGS212 Switch 3kW
40000	false	true	FIBARO System FGK101 Door Opening Sensor
40000	false	true	Danfoss Z Thermostat 014G0013
40000	true	true	FIBARO System FGS222 Double Relay Switch 2x1.5kW
40000	false	true	FIBARO System FGSD002 Smoke Sensor
40000	false	true	FIBARO System FGMS001 Motion Sensor
40000	false	true	Aeotec DSA03202 Minimote
40000	true	true	Philio Technology Corporation PH-PSE02.eu Zipato Indoor Siren
40000	true	true	Neo CoolCam Power plug 12A
40000	true	true	FIBARO System FGRM222 Roller Shutter Controller 2
40000	true	true	Qubino ZMNHND1 Flush 1D relay
ben53252642
Egregius I'm seeing the same thing RE 40000 (40kbps) for all my devices, I've spent the last two hours trying to figure out if my network is really operating at Z-Wave plus speeds (I know many of my devices support 100kbps).
I've logged an issue on the openzwave github page:
https://github.com/OpenZWave/open-zwave/issues/1414
