How can I get dzVents 2.3 in domoticz?
Posted: Thursday 04 January 2018 14:04
by Timmiej93
So I'm completely new to dzVents, have been messing with it for a little bit, and seems to be exactly what I need. Unfortunately, I want to run a script based on state changes of a scene, so I need dzVents 2.3 (if I understood correctly).
Now, I've seen some posts from October / November saying that you need the beta version for that, but also posts saying that updating to the beta version isn't working, etc.
I tried updating to the beta (running updatebeta in the domoticz folder on my Pi), which is at v3.8798 at the moment. For some reason though, I'm not getting the beta UI (which I have had before when I was messing with switching between the beta and stable versions), and dzVents still seems to be at 2.2 (I'm basing this on the version number shown in Setup > Settings > Other > dzVents (2.2.0)).
What I'd like to know:
What do I need to do to get dzVents 2.3 running in domoticz? If it comes down to building from source from github, I'd really appreciate some more detailed instructions, since I'm completely unaware of how to do such a thing.
Tim
Re: How can I get dzVents 2.3 in domoticz?
Posted: Thursday 04 January 2018 15:50
by emme
3.8798 brings dzVents 2.3
I do not see any version number under Setup/Settings/Other/dzVents
Posted: Thursday 04 January 2018 15:55
by Timmiej93
Well that's odd. Any suggestions on forcing a reinstall of the latest beta version?
Posted: Thursday 04 January 2018 16:03
by McMelloW
Here http://www.domoticz.com/wiki/DzVents:_n ... _scripting and here https://www.youtube.com/watch?v=Y5JB8Vgz4fI you can find everythig to get started. Watch the video and have a lot of fun with dzVents
Posted: Thursday 04 January 2018 16:12
by Timmiej93
Thanks for the reply McMelloW, but I think you may have misunderstood my question. I'm asking what I need to do to get dzVents 2.3 into domoticz, since the stable version currently has v2.2, and (for me) the beta version also seems to have v2.2. I require version v2.3 for what I'm trying to do.
Posted: Thursday 04 January 2018 16:29
by McMelloW
In that case you have to go to the Domoticz beta version or wait until it is in the next stable version. I understood that's the only way, correct me if I am wrong
Posted: Thursday 04 January 2018 16:36
by emme
I remember I had a version problem once...
I had to manual copy the dzVents folder from the github repository
...make a backup of your /domoticz folder, then download from github and overwrite the /domoticz/dzvents folder, restart your server and have a try
ciao
M
Posted: Thursday 04 January 2018 16:43
by Timmiej93
Is there any way I can do this from the commandline emme? Software like WinSCP have been giving me grief with permissions unfortunately.
Posted: Thursday 04 January 2018 16:59
by emme
first MAKE A BACKUP of you domoticz folder.. I'm not strongly familiar with command line so I could make an error and would not to mess up your installation!!
these instruction should works on a raspberry system:
sudo systemctl stop domoticz
cd /home/pi
mkdir dzTemp
cd dzTemp
git clone https://github.com/domoticz/domoticz.git domoticz
cd domoticz
cp -ar ./dzVents/. /home/pi/domoticz/dzVents
sudo systemctl start domoticz
this should work
Posted: Thursday 04 January 2018 17:14
by Timmiej93
Well, Setup > Settings > Other still shows dzVents 2.2.0, but scenes and groups now work as a trigger, which is all I needed, thanks guys!
Posted: Friday 05 January 2018 8:51
by Doler
For version info on dzVents you should look in Domoticz Settings -> About.
Posted: Friday 05 January 2018 10:42
by Timmiej93
In Setup > About, I can only find version info about Domoticz itself, not about dzVents, or anything else.
Posted: Friday 05 January 2018 13:58
by dannybloe
Then you have stable. Only in the beta version there is 2.3 and in the beta the version info is moved from the setup page to the about page. You cannot use 2.3 with the Domoticz stable (3.8153) unfortunately.
Posted: Friday 05 January 2018 14:10
by Timmiej93
Do you mean that the beta version should contain 2.3? So calling updatebeta should install 2.3? If so, I don't know why I had to manually put 2.3 in after updating to the beta.
Posted: Friday 05 January 2018 14:19
by dannybloe
You surely should not move folders around when you install the latest beta. In stable there is no dzVents folder inside the root of the install dir (dzVents 2.2 can be found in /path/to/domoticz/script/dzVents) but in beta there is. And if you start beta it will remove the 2.2 runtime files from /path/to/domoticz/scripts/dzVents.
