Page 1 of 2
A little Small Lua Telegram Library
Posted: Tuesday 02 January 2018 22:57
by emme
Ciao,
I use to send notifications via Telegram in 3 different scenarios:
- myself
- in a group where the BOT is included
- to my wife
all these 3 scenarios does not fit the actual notification system in Domoticz that just handle one ID
so I use to run a brunch of os.execute and curl to send locally (within the script) all the notification I want.... but I dont like to put the bot Token everywhere...
SO... I finally wrote a small library to include in all scripts (dzVents included) that is able to send both messages and tvcc snapshot and would like to share with you.
It only runs under Linux....
save the following code to a file named
Telegram.lua and put it in
/home/pi/domoticz/scripts/lua
local teleTok = 'Enter your Bot Token here'
local snapFile = '/home/pi/domoticzSnap'
local domoReq = 'http://localhost:8080/camsnapshot.jpg?idx='
local tgAb = {}
tgAb['myName1'] = 222222222
tgAb['myName2'] = 111111111
tgAb['myGroup'] = -00000000
local telegram ={};
function telegram.getId(nome)
return tgAb[nome]
function telegram.sendText(chatId, message)
return os.execute('curl --data chat_id='..chatId..' --data parse_mode=Markdown --data-urlencode "text='..message..'" "https://api.telegram.org/bot'..teleTok..'/sendMessage" ')
function telegram.sendImage(chatId, camChannel)
os.execute('wget -O "'..snapFile..camChannel..'.jpg" "'..domoReq..camChannel..'"')
return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendPhoto?chat_id='..chatId..'" -F photo="@'..snapFile..camChannel..'.jpg"')
function telegram.sendDoc(chatId, filePath)
return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendDocument?chat_id='..chatId..'" -F document="@'..filePath..'"')
return telegram
then in your code add the reference library.
Please note that the library returns a boolean value for the success or not of the operation, so store it somewhere (in the example I put the result in the log)
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
local telegram = require('Telegram')
Actually I only included few option:
Send a text Message (Markdown formatting supported)
usage:
telegram.sendText(chatId, Message)
example
result = telegram.sendText(123456789, 'This is a *TEST* Message')
Send a Camera SnapShot
usage:
telegram.sendImage(chatId, Camera Channel IDX)
example
result = telegram.sendImage(123456789, 1)
Send a document (useful to send animated GIF also!!)
usage:
telegram.sendDoc(chatId, full_file_path_and_name)
example
result = telegram.sendImage(123456789, '/home/pi/domoticz/domoticz.db')
AddressBook
le local array tgAb can be filled with the chatId and referred to a person/group
compile (and add raw if needed) using the syntax: tgAb['name you want to use to identify the chat'] = chatid
then, in your script use it like:
local chatid = telegram.getId('name you want to use to identify the chat')
or, use it straight in the sendText function:
telegram.sendText(telegram.getId('name you want to use to identify the chat'), 'This is a Message')
I hope you like it
ciao
M
Re: A little Small Lua Telegram Library
Posted: Wednesday 03 January 2018 14:27
by bigpea
Great idea and great script.
It works very well, thanks!
Posted: Monday 08 January 2018 21:46
by emme
added function to send docs and a chatid addressbook to fast references in your code
Posted: Monday 09 April 2018 10:48
by wlevels
Thanks @emme just what I was looking for!
Posted: Sunday 27 January 2019 23:27
by EdddieN
emme wrote: Monday 08 January 2018 21:46
How do you use
tgAb['myName1'] on the triggers script inside Domoticz?
Posted: Monday 28 January 2019 8:02
by emme
that a part of the addressbook function...
tgAb['Marco'] = 222222222
return tgAb[nome]
the ab contains only the chatid... is a better way to remeber the right addresses
then in the script I would use telegram.getId('Marco') to get 222222222
Posted: Sunday 10 March 2019 12:59
by hoeby
do you also know how to do the command
sendMediaGroup?
This works in a bash file. But prefer it to have in dzvents. Then al scripts are in the same place, when wanting to view them
curl -s \
-X POST "https://api.telegram.org/bot"$token"/sendMediaGroup" \
-F chat_id=$SendMsgTo \
-F media='[{"type":"photo","media":"attach://photo_1","caption":"Camera Voordeur en Oprit"},{"type":"photo","media":"attach://photo_2","caption":"Camera Voordeur en Oprit"}]' \
-F photo_1="@$SnapFile1" \
-F photo_2="@$SnapFile2"
The part i am stuck with, it the info behind
media=
It looks like DZvents is not accepting that row
Posted: Sunday 10 March 2019 13:12
by waaren
hoeby wrote: Sunday 10 March 2019 12:59
sendMediaGroup?
media=
dzVents or Lua should not have a problem with the string behind Media, except for the trailing \
local media='[{"type":"photo","media":"attach://photo_1","caption":"Camera Voordeur en Oprit"},{"type":"photo","media":"attach://photo_2","caption":"Camera Voordeur en Oprit"}]'
logWrite(media)
gives
2019-03-10 13:09:00.476 Status: dzVents: Debug: media Test: [{"type":"photo","media":"attach://photo_1","caption":"Camera Voor deur en Oprit"},{"type":"photo","media":"attach://photo_2","caption":"Camera Voordeur en Oprit"}]
in the log
Posted: Sunday 10 March 2019 13:58
by hoeby
When i try it, it gives a nil value on the logWrite(mediaurl)
devices = {'Camera voordeur'},
if(device.state == 'On') then
local teleTok = 'xxxxxxxxxxxxxxxx'
local chatId = 'xxxxxxxxxxxxxxxx'
local snapFile = '/home/pi/domoticz/scripts/camera_'
local domoReq1 = 'http://192.168.178.246/jpg/1/image.jpg'
local domoReq2 = 'http://192.168.178.246/jpg/1/image.jpg'
local camName1 = 'Voordeur'
local camName2 = 'Oprit'
local mediaurl = '[{"type":"photo","media":"attach://photo_1","caption":"Camera Voordeur en Oprit"},{"type":"photo","media":"attach://photo_2","caption":"Camera Voordeur en Oprit"}]'
logWrite(mediaurl)
os.execute('wget -O "'..snapFile..camName1..'.jpg" "'..domoReq1..'"')
os.execute('wget -O "'..snapFile..camName2..'.jpg" "'..domoReq2..'"')
os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendMediaGroup?chat_id='..chatId..'" -F media="..mediaurl.." -F photo1="@'..snapFile..camName1..'.jpg" -F photo2="@'..snapFile..camName2..'.jpg"')
os.execute("rm " ..snapFile..camName1..'.jpg')
os.execute("rm " ..snapFile..camName2..'.jpg')
Posted: Monday 11 March 2019 8:17
by waaren
hoeby wrote: Sunday 10 March 2019 13:58
That's because you have no function logWrite in your code. You can copy it from my example or use the standard dzVents domoticz.log function.
your os.execute for the curl command is not correct
You have
This should be changed to
os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendMediaGroup?chat_id='..chatId..'" -F media="'..mediaurl..'" -F photo1="@'..snapFile..camName1..'.jpg" -F photo2="@'..snapFile..camName2..'.jpg"')
(Single quotes needed around ..mediaurl.. )
Please be aware that using these os.execute command from dzVents can cause a block. The wget or curl command can take some seconds and as the domoticz event system is single threaded all other eventhandlers will be blocked until this script has finished.
Posted: Monday 11 March 2019 8:26
by emme
Sorry folks to be so missing on this....
unfortunately I'm out of internet connection at home (hopefully this should be the week they would fix it) so I have poor time to implement it
but if you're able to do this, please share the code!
ciao
M
Posted: Monday 11 March 2019 20:27
by hoeby
I don't get it to work in domoticz dzvents.
Don't know what i am doing wrong
Copied the codes from Waaren, but still getting a nil value response.
Added the single quotes needed around ..mediaurl..
But it didn't matter. I stopped research on it, because it works in .sh
Maybe somebody could get it to work, but i don't know how to debug the rigth way, with those os.execute commands to telegram
Posted: Tuesday 12 March 2019 8:03
by emme
having a look to the sendMediaGroup docs it looks files cannot be sent as -F <filepath> but it has to be a JSON array of Media from 2 to 10:
[{ type: 'photo', media: attach://home/pi/temp/snap1.jpg },{ type: 'photo', media: attach://home/pi/temp/snap2.jpg }]
so the curl line should be like
local mediaurl = [{ type: 'photo', media: attach://home/pi/temp/snap1.jpg },{ type: 'photo', media: attach://home/pi/temp/snap2.jpg }]
os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendMediaGroup?chat_id='..chatId..'"&media="..mediaurl)
can you try it?
Posted: Wednesday 13 March 2019 7:34
by hoeby
I tried your script part, but get an nil value error
Status: dzVents: Error (2.4.6): An error occured when calling event handler Camera voordeur snapshot3
Status: dzVents: Error (2.4.6): .../dzVents/generated_scripts/Camera voordeur snapshot3.lua:22: attempt to call global 'photo' (a nil value)
Used this code, some little code parts where forgotten in your code
And changed the location of my .jpg files
local mediaurl = '[{ type: 'photo', media: attach://home/pi/domoticz/scripts/camera_Voordeur.jpg },{ type: 'photo', media: attach://home/pi/domoticz/scripts/camera_Oprit.jpg }]'
os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendMediaGroup?chat_id='..chatId..'"&media="..mediaurl')
I think the nil value is because of
'photo', this searches for a local function, but there is non
Posted: Wednesday 13 March 2019 8:31
by emme
ok.. I'm able to sendMediaGroup for internet images....
I'm still trying to work on local uploadable files.... stay tuned
Ok... got the issue!
local file paths cannot be written directly in the JSON array media key... they have to be specified in a data variable, encoded, uploaded and then referenced in the array
still need some work on this as soon as I have time
Posted: Wednesday 13 March 2019 11:09
by emme
The solution is here
https://www.domoticz.com/forum/viewtopi ... 88#p185288
but I cannot having working under windows....
Posted: Wednesday 13 March 2019 14:53
by hoeby
I have it working with the .sh file, where to link points to.
But would liked to have it working in DZvents.
The .sh file is only possible to change when logging in with a pc.
But working from a tablet this doesn't work. Therefor the prefer for dzvents.
Posted: Wednesday 13 March 2019 15:06
by emme
this evening I'll try to adapt it...
it would be difficult to implement the number of files to send (from 2 to 10...) but I'll figure out how...
most probably the JSON array must be provided instead of providing just the file names... this way you can choos to use optionals options (like caption) that otherwise you should provide as parameters....
it will be something like telegram.sendMediaGroup(chat_id, <mediaJson>)
ciao
M
Posted: Wednesday 13 March 2019 22:07
by emme
Ok folks... got it!!!
first... edit the Telegram.lua library and add the following code befor the last line "return telegram":
function telegram.sendMG(chatId, arrPic)
local strMedia = ''
local strPics = ''
if type(arrPic) == 'table' then
for idx = 1, #arrPic do
if arrPic[idx][2]:sub(1,9) == "attach://" then -- Local file
strPics = strPics..' -F '..arrPic[idx][1]..'_'..idx..'=@'..arrPic[idx][2]:sub(10)
strMedia = strMedia..'{"type":"'..arrPic[idx][1]..'","media":"attach://'..arrPic[idx][1]..'_'..idx..'","caption":"'..arrPic[idx][3]..'","parse_mode":"'..arrPic[idx][4]..'"}'
strMedia = strMedia..'{"type":"'..arrPic[idx][1]..'","media":"'..arrPic[idx][2]..'","caption":"'..arrPic[idx][3]..'","parse_mode":"'..arrPic[idx][4]..'"}'
if idx ~= #arrPic then
strMedia = strMedia..','
return os.execute('curl -X POST https://api.telegram.org/bot'..teleTok..'/sendMediaGroup?chat_id='..chatId..' '..strPics..' -F media=\'['..strMedia..']\'')
dz.log(strPics..' / '..strMedia)
save it
next..
to use it in your code you have to provide a neasted table to the function:
local arrPic = {{'photo', 'attach:///home/pi/snap1.jpg', 'Test', 'Markdown'},{'photo', 'attach:///home/pi/temp/snap.jpg', 'Test', 'Markdown'}}
the keys are:
1. Type (photo or media)
2. File (prefix attach:// and then the full path from root) or url ( prefix http://)
3. Caption
4. Caption format (Markdown or HTML)
each record is closed betweeb { } records are separated by , ALL in closed between { }
remember you can do from 2 to 10 pics...
How to gain such table is up to your code... (it's time you start working with lua tables
now you can call them using: telegram.sendMG(chat_id, arrPic) where chat_id you already know what is, and arrPic is your table
the function will care about generating the right URL and execute it!
...btw... how many of you are using this library right now?.... did you enjoy it?
ciao
M
Posted: Saturday 16 March 2019 8:57
by zicht
Hi folks
Just see this nice script right now, good job ! Less complex then what i was using before. (I use telegram a lot to send foto's from security script.) Works great !
Some things to keep in mind with os.execute and possible sollutions :
There is some experience with this curl, and you can slow down domoticz a lot when doing it for LUA.
The first sign will be a error line in the log "Script running for more than 10 seconds"
Its happens not to often but in my case when it happens it will be a lot of times in a row. Probably due to some issues on telegram side ...
The slow down is realy noticable.
I solved it with adding " --connect-timeout 5 --max-time 6 " to the curl command. (still a slow down but under control)
Then i do not use os.execute but io.popen...
function os.capture(cmd, raw) -- os.command uitvoeren en resultaat daarvan lezen in string
local f=assert(io.popen(cmd, 'r'))
local s=assert(f:read('*a'))
f:close()
if raw then return s end
s=string.gsub(s, '^%s+', '')
s=string.gsub(s, '%s+$', '')
s=string.gsub(s, '[\n\r]+', ' ')
return s
var s will contain the return from the curl. So you can check if telegram received the command by evalutation of variable s
If you want to use it from windows. Install a curl,exe (haxx.se) in you domoticz folder and call it via powershell like 'start /b /realtime curl.exe --connect-timeout 5 --max-time 9' ..cmd This also give the shell some priority within the windows system. again not os,execute but io.popen to catch return values.
I am not a coder at all, all was found on the forum during my "domoticz time". feel free to comment, use, optimize and share.
