How check the power absorbed?
Posted: Saturday 30 December 2017 22:04
by acaonweb
I’d like to check if my washer has finished to wash.
My xiaomi plug give me back the power in Watt that I’m consuming
During the washing cycle the power can go to zero sometimes for few minutes and then rise up depending what the washer is doing.
When the washer finish the power goes to zero.
There is a way in dzevents to control something like
If power is =0 in the last 10 minutes then switch of
Thanx in advance
FABRIZIO
Re: How check the power absorbed?
Posted: Sunday 31 December 2017 9:20
by SweetPants
Yes, this should be possible, maybe not as easy as you suggest, but it's possible. See wiki
https://www.domoticz.com/wiki/DzVents:_ ... _scripting for more information
Posted: Sunday 31 December 2017 9:33
by acaonweb
Ive already had a look there but I’m not able. I need suggestion
Posted: Sunday 31 December 2017 10:17
by SweetPants
Have you tried something already?
Posted: Sunday 31 December 2017 20:10
by acaonweb
No, i’ve written scripts in dzevents but in this case I don’t know how start
Posted: Wednesday 03 January 2018 16:21
by acaonweb
any ideas? There someone that trigger when a washer has finished?
Posted: Wednesday 03 January 2018 16:31
by emme
I've just realized a script for that....
it works in this way:
a Watt consumption treshold above which it start the monitoring process and under whitch it start counting a specific amount of minutes after whitch is consider the cycle ended.
you will need an integer user variable (mine is called cycleMonit) to initialize to 0
here is the script:
local delay = 20 -- minutes to wait to consider the duty cycle ended
local trig = 80 -- WATT below treshold
devices = {'WAT_Lavatrice'},
timer = {'every minute'}
logging = {
level = domoticz.LOG_INFO,
marker = "[MonitCycle: LAVATRICE]"
execute = function(dz, devWat, tgInfo)
local cycleMonit = dz.variables('cycleMonit')
if tgInfo.type == dz.EVENT_TYPE_TIMER then -- cycle Monitor
dz.log('Monitoraggio attuale: '..cycleMonit.value..'/'..cycleMonit.lastUpdate.minutesAgo, dz.LOG_FORCE)
if cycleMonit.value == 2 and cycleMonit.lastUpdate.minutesAgo >= delay then
cycleMonit.set(0)
dz.notify('Fine ciclo Lavatrice', 'Credo che la lavatrice possa avere finito il proprio ciclo di lavoro')
elseif tgInfo.type == dz.EVENT_TYPE_DEVICE then -- WATT updater
if devWat.WhActual > trig and cycleMonit.value ~= 1 then
cycleMonit.set(1)
elseif devWat.WhActual < trig and cycleMonit.value == 1 then
cycleMonit.set(2)
based on the script... after 20 minutes of consumption under 80Watt, it consider the cycle ended
Posted: Thursday 04 January 2018 10:58
by acaonweb
great i'll study it because i don't know so much about functions
Thanx for now
Posted: Thursday 04 January 2018 11:05
by acaonweb
this is a function... the main script is this?
Posted: Thursday 04 January 2018 11:06
by emme
acaonweb wrote: Thursday 04 January 2018 11:05
everything you need is there... I do not understand what you mean
Posted: Thursday 04 January 2018 13:35
by acaonweb
ok, first i have to study functions
Posted: Thursday 04 January 2018 13:45
by acaonweb
emme wrote: Thursday 04 January 2018 11:06
yes... i have just a dubt,
1) in device u trigger WAT_lavatrice i think is the seat plug you have in the function doesn't appears something like
but
i can't understand that.. what are devWat and tginfo?
Posted: Thursday 04 January 2018 13:59
by jannl
Basically the same as I do with my PC. When the power is below 30watts for about 15 minutes, I switch off the zwave (in this case) switch. (Without dzvents btw)
Posted: Thursday 04 January 2018 14:10
by emme
but
ok... You have to understand the dzVents framework structure then...
the trigger of the script is based on 2 separates events:
a DEVICE info based on the update coming from the device WAT_Lavatrice (which is in my case the power consumption on the plug attached to the washingmachine)
a TIMER eventi that triggers every minute.
Why? because the device trigger must do some stuff (compare values and act by consequences) while the timer function have to count (if necessary) the minutes passed
dz, devWat,tgInfo are simple names... they could be even named domoticz, device, triggerinfo or foo, bar, zoo.... you just have to respect them in the code
dz (or domoticz) = the entire Domoticz table containing all the nodes, variables and other useful stuff
devWat( or device) = contain ONLY the information about the device/variable that trigger the event, in case of timer info the table in null
tgInfo = the trigger information. this is a special table that contains information about why the scripts have been triggered
hope this will helps you to better understand it
ciao
M
Posted: Friday 05 January 2018 14:07
by acaonweb
yesss, now is clear...
i'm just starting with dzevents
thanx for now
ciao
Fabrizio
