How do i check for days in an IF statement?
rizzah
Post by rizzah »
I got this script which which works fine, cept that i only want it to check certain if statement on monday till friday.
Right now my if statement looks like this:
if (domoticz.devices('Sensor_SK_PenM').state == 'On') and (domoticz.devices('Lamp_SK_PenM').state == 'Off') and (domoticz.devices('Lux_SK_PenM').lux <= 20) then
But i would like to add something like "and days between mon-fri" but i dont know what the right syntax is for this.
Any help would be appriciated!
SweetPants
Re: How do i check for days in an IF statement?
Post by SweetPants »
use dzVentz, very easy with:
timer = { mon, thu, wed, thu, fri }
check the Wiki https://www.domoticz.com/wiki/DzVents:_ ... _scripting
rizzah
Post by rizzah »
I saw it could be done with a timer, however, this is my code now:
                domoticz.log(domoticz.time.rawTime)
                if (domoticz.time.hour >= 8) and (domoticz.time.hour <= 21) then
                    domoticz.scenes('Lamp_SK_PenM_Overdag').switchOn()
                    domoticz.data.counter = 0
                    domoticz.log('<font color="purple"> [DEVICE] Motion sensor Kamer PenM is aan, Lamp is aangezet (routine 8-20)')
                elseif (domoticz.time.hour >= 22) and (domoticz.time.hour <= 22) and (domoticz.time.min <= 30) then
                    domoticz.scenes('Lamp_SK_PenM_Avond').switchOn()
                    domoticz.log('<font color="purple"> [DEVICE] Motion sensor Kamer PenM is aan, Lamp is aangezet  (routine 22-23)')
I want to split this code up so the "on" switch from 8 till 21 will happen only on mon-fri and i want to create a different one for example 10-21 on sat-sun.
SweetPants
You can have multiple 'on timer' events and select them using triggerinfo.trigger
https://www.domoticz.com/wiki/DzVents:_ ... 29_..._end
dannybloe
Post by dannybloe »
You can check for a day by using the matchesRule function on a Time object:
if (
	domoticz.devices('Sensor_SK_PenM').state == 'On' and
	domoticz.devices('Lamp_SK_PenM').state == 'Off' and
	domoticz.devices('Lux_SK_PenM').lux <= 20 and
	domoticz.time.matchesRule('on mon,fri,sat,sun')) then -- doesn't work with 'between'
You can use the same time rules as you can with the timer trigger.
rizzah
Post by rizzah »
Awesome, thanks!
rizzah
Post by rizzah »
@dannybloe
i have this code now:
    active = true,
        devices = {
            'Sensor_SK_PenM'
        timer = {
            'every minute on mon,tue,wed,thu,fri'
    data = {
        counter = { initial = 0 }
                    domoticz.log('<font color="purple"> [DEVICE] Motion sensor Kamer PenM is aan, Lamp is aangezet (routine 8-21)')
But i notice the lights also go on saturday and sunday. Is that correct? since i use only weekdays in the timer?
Regards,
Peter
dannybloe
Post by dannybloe »
Well, you can check the trigger info (third parameter to the execute function) and see if the reason was timer or a device. See documentation. Thing is that in your script when Sensor_SK_PenM changes, your script is triggered as well. So if your if-statement renders true then you have things happening on every day.
So, there are several things you can do. You can check the triggerInfo parameter as mentioned above or you can put a day-check in your execute function or add a rule to the device trigger:
    active = true,
        devices = {
            'Sensor_SK_PenM' = { 'on mon, tue, wed, thu, fri' }
        timer = {
Now changes in Sensor_SK_PenM will only trigger the execute function on weekdays.
Unless of course there's a bug in the timer rule code but first check if anything mentioned above is going on.
rizzah
Post by rizzah »
I will try the above method with the devices = first.
Could it be it has to be : 'Sensor_SK_PenM' == { 'on mon, tue, wed, thu, fri' } instead of a single = ? I got an error when i tried to use a single = sign.
Thank you for your responce!
dannybloe
Post by dannybloe »
No, it is not a comparision but a declaration. 'devices' inside the 'on'-section is a Lua table where each member is either a singleton (device name or id) or a key/value item (where in this case key is 'Sensor_SK_PenM' and value is again a Lua table (array) with timer rules. There can be more rules in that table.
rizzah
Post by rizzah »
Would you help me with the error im getting when using a single sign?
    active = true,
        devices = {
        timer = {
    data = {
Im getting the following error on line 9: '}' expected near '='
Regards,
dannybloe
Post by dannybloe »
Ow crap, I always forget those nasty [ ]:
devices = {
           ['Sensor_SK_PenM'] = { 'on mon, tue, wed, thu, fri' }
Lua is weird.
rizzah
Post by rizzah »
Im trying to learn python atm to get a better feeling with things. Lua did not have much good teaching on udemy :-)
Thanks alot for your help!
dannybloe
Post by dannybloe »
Ah, it's easy to learn and very similar to javascript. You just have to learn a couple of syntactic difference and read about Lua tables. Not so hard. There's no dzVents data model in python though.
