IF Button is pressed on (even if on already) do somthing
Posted: Saturday 30 December 2017 3:34
by Evelen
Hi.
I have these wall switches that can be set to "on" or "off".
Now I just have JSON inside the device on "response by on" and "response by off", but this just works if I want to change one device, since that is what JSON supports.
I want in LUA:
IF "Button is pressed on (even if on already)"
DO: somthing
how do I write this?
Re: IF Button is pressed on (even if on already) do somthing
Posted: Saturday 30 December 2017 9:57
by SweetPants
Try a 'device' triggered dzVentz event like this
devices = {
'Button'
logging = {
level = domoticz.LOG_INFO,
marker = "dz_Test"
domoticz.log('Device ' .. device.name .. ' was triggered', domoticz.LOG_INFO)
It will be launced every time you push the button even if it is already in the selected state
Posted: Saturday 30 December 2017 15:20
by Evelen
SweetPants wrote: Saturday 30 December 2017 9:57
devices = {
'Button'
logging = {
marker = "dz_Test"
Thanks, it works, changed the code a little:
devices = {
266
-- if (device.state == 'On') then
-- domoticz.log('It is On')
-- if (device.state == 'Off') then
-- domoticz.log('It is Off')
-- end
This part it what is not working (if activated):
-- end
It gives the following error:
2017-12-30 15:17:56.918 Error: dzVents: Error: error loading module 'test' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/test.lua':
...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:18: unexpected symbol near '}'
Can't really se why
Posted: Saturday 30 December 2017 16:31
by waaren
Try this:
devices = {
266
-- Added the missing end
-- Should also give the desired result.
domoticz.log('Device ' .. device.name .. ' state: ' .. device.state , domoticz.LOG_INFO)
Posted: Saturday 30 December 2017 16:56
by SweetPants
Posted: Saturday 30 December 2017 19:06
by Evelen
It works
