Digoo DG-HOSA 433MHz PIR Sensor
Posted: Friday 29 December 2017 17:22
by lassehifi
Hi, I have this cheap PIR Sensor and would like to inform that it works OK with RFXCOM and Domoticz:
https://www.banggood.com/Digoo-DG-HOSA- ... rehouse=CN
(Look for the PIR sensor in the link above)
The protocol is Lightning 4 (PT2262) Motion Sensor and can be learned by Domoticz. The device seems to send with two codes but only one is required in Domoticz to make it work. It sends 28 frames(packets) when motion is detected and no OFF signal, so use the OFF function timer in Domoticz. I use a timer configured OFF after 60 sec.
Note that the sensor is sending MANY frames/packets so it should only be installed in rooms/area where you have very little (or no) movement normal movement. I have no information about battery life as I just installed the device (late dec. 2017).
Re: Digoo DG-HOSA 433MHz PIR Sensor
Posted: Thursday 20 December 2018 19:05
by Wilmar
How did you get it working and how did you configured OFF after 60 seconds. I only get it recognized by Domoticz, but no further reaction
Wilmar
Posted: Friday 21 December 2018 16:52
by lassehifi
Sorry, I do not use this sensor any more and I have no saved configurations from the setup. But the setup as I described above should work.
