RFLink R46 synology DS214play
htca
Post by htca »
I installed domoticz stable version for DSM6.1 on my synology and connected my RFLink R46 to it.
The RFLink is found and initialised, but I do not get any data in.
2017-12-29 10:02:07.253 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-12-29 10:02:07.254 Build Hash: 494fff7-modified, Date: 2017-07-30 12:19:41
2017-12-29 10:02:07.254 Startup Path: /usr/local/domoticz/
2017-12-29 10:02:08.899 PluginSystem: Started, Python version '3.5.1'.
2017-12-29 10:02:08.909 Active notification Subsystems: gcm, http (2/12)
2017-12-29 10:02:09.008 WebServer(HTTP) started on address: :: with port 8084
2017-12-29 10:02:09.080 WebServer(SSL) started on address: :: with port 8443
2017-12-29 10:02:09.082 Proxymanager started.
2017-12-29 10:02:09.084 Starting shared server on: :::6144
2017-12-29 10:02:09.085 TCPServer: shared server started...
2017-12-29 10:02:09.085 RxQueue: queue worker started...
2017-12-29 10:02:11.101 EventSystem: reset all events...
2017-12-29 10:02:11.197 EventSystem: reset all device statuses...
2017-12-29 10:02:11.314 RFLink: Using serial port: /dev/ttyACM0
2017-12-29 10:02:11.410 Python EventSystem: Module not found - Trying to initialize.
2017-12-29 10:02:11.413 Python EventSystem: Initalizing event module.
2017-12-29 10:02:11.413 EventSystem: Started
2017-12-29 10:02:11.424 PluginSystem: Entering work loop.
2017-12-29 10:02:12.228 RFLink: Controller Initialized!...
2017-12-29 10:02:12.308 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-12-29 14:40:08.992 Incoming connection from: 10.8.0.6
Anyone any idea?
htca
Re: RFLink R46 synology DS214play
Post by htca »
Update: somehow the application of the mysensors gw and the rflink together created that no information was parsed. I uncoupled the mysensors gw and it now works... next issue...
