Thermostat command classes
Ittiz
Domoticz version: 13939
Post by Ittiz »
There are some command classes that are in Open-z-wave but not in Domoticz. I'm able to pass them to a dummy switch using a back door lua parser route, but it'd be nice if these worked. On a side note, I don't have a compiler so I can't add these myself. These are the command classes:
0x42 (THERMOSTAT OPERATING STATE) -- Basically whether the the thermostat is calling for heat, cool or just Idle
0x45 (THERMOSTAT FAN STATE) -- If the central air fan is running or not
0x87 (INDICATOR) -- I'm actually not quite sure what this does, but Domoticz doesn't know either.
JCLB
Re: Thermostat command classes
Post by JCLB »
I would be glad to see your LUA, if possible ;)
I would like to survey this state too.
mooninite
Domoticz version: 4.9700
Post by mooninite »
I have added support for reading these two states. The code has been merged.
https://github.com/domoticz/domoticz/pull/3614
