Dear team, hope you all had a good Xmas.
Can someone tell us when this 868Mhz version will be available? Will it be possible to use both 433Mhz and 868Mhz version simultaniously with Domoticz?
Have a great New Year!
DD
RFXCom 868Mhz Launch
Docdigit
- Domoticz version: 2020.2
With both feet on the ground you can't make any step forward...
SweetPants
Re: RFXCom 868Mhz Launch
Don't know when available, you have to check with RFXcom. Both work on different frequencies, so should work simultaniously
Docdigit
Thanks - I asked because the original RFXCom seller is not responding on any email (must have moved to the Cariben after the success of the 433Mhz version
