Running python scripts with external libraries
timberwolf
Post by timberwolf »
I have this strange situation that probably has a simple solution. I want to run the following script (script_time_alarm.py):
import DomoticzEvents as DE
import verisure
session = verisure.Session('email', 'password')
session.login()
armstate = session.get_arm_state()
session.logout()
print(armstate["statusType"])
DE.Log("Alarm status")
The problem is that Domoticz will not run the script with the verisure library included. If i remove DomoticzEvents i can run it from the command line without problem. If i remove the Verisure library domoticz runs it as it should every minute.
What have i done wrong?
febalci
Re: Running python scripts with external libraries
Post by febalci »
You can import python modules in plugin framework but not in events as far as i know.
moroen
Post by moroen »
timberwolf wrote: Wednesday 27 December 2017 20:58 I have this strange situation that probably has a simple solution. I want to run the following script (script_time_alarm.py):
import verisure
session.login()
session.logout()
The python-events struggles a bit with import-paths. Try saving the verisure module in the scripts/python-folder.
Regards,
M
miroslavpetrov
Post by miroslavpetrov »
Same problem here. The script works in the command line but when triggered with switch on action or from blockly event, the script doesn’t work. Is there a solution or I should integrate the external scripts in the main script?
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Itschi
Post by Itschi »
I had the same problem and finally got it working with the following code:
import sys
import importlib.util
MODULE_PATH = 'C:\Program Files (x86)\Python36-32\Lib\site-packages\modulename\__init__.py'
MODULE_NAME = 'modulename'
spec = importlib.util.spec_from_file_location(MODULE_NAME, MODULE_PATH)
module = importlib.util.module_from_spec(spec)
sys.modules[spec.name] = module
spec.loader.exec_module(module)
Regards, Itschi
Flopp
Post by Flopp »
Have a look at my plugin, more feature will come but I need help to test them.
https://github.com/flopp999/Verisure-Domoticz
