dzVents not running/executing scripts
Posted: Wednesday 27 December 2017 20:28
by lumjajo
I am currently on 3.8771 beta and just created my first dzVent script. My LUA script is running perfectly with my Solar Inverter.
However, I enabled everything and just used the example script of writing in the log file and nothing happens.
this is the script, the switch is valid of course.
devices = {
'Sonoff_02'
domoticz.log('switched')
I do not think there is anything wrong with the script, but can it be that the dzVents just does not work in my Domoticz installation?
Thanks a lot...
Re: dzVents not running/executing scripts
Posted: Wednesday 27 December 2017 20:50
by SweetPants
Pleas use code blocks when posting code
Posted: Wednesday 27 December 2017 21:01
by SweetPants
Try this:
devices = {
'Sonoff_02'
logging = {
level = domoticz.LOG_INFO,
marker = "dz_Test"
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
and select the right log level in Setup->Settings->Other dzVentz Log Level
Posted: Wednesday 27 December 2017 22:46
by lumjajo
Thanks for this, the log level is: debugging, but I tested with every other level as well.
This is the log file:
2017-12-27 22:40:54.329 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/test.lua
2017-12-27 22:41:13.325 User: Admin initiated a switch command (301/Sonoff_02/Off)
2017-12-27 22:41:13.329 (Sonoff_02) Light/Switch (Sonoff_02)
2017-12-27 22:41:13.617 User: Admin initiated a switch command (301/Sonoff_02/Off)
2017-12-27 22:41:13.621 (Sonoff_02) Light/Switch (Sonoff_02)
the switch is correct, as you see, but I also tried with other switches (wirtual etc).
Its as if the dzVents is just ignoring the script.I am currently not updating the beta version due to the timer issue, so I cannot test it, although I think it should work...
Sorry for the quick quoting...next time in code blocks..
Posted: Thursday 28 December 2017 9:11
by lumjajo
Ok, and meanwhile I found out, that Blockly does not work either.
anything I can do about it? Both, Blockl and dzVents does not work, Lua Scripts work...
Posted: Thursday 28 December 2017 10:20
by Plips
Is downgrading to the stable build an option for you?
Posted: Thursday 28 December 2017 10:23
by SweetPants
Plips wrote: Thursday 28 December 2017 10:20
He is on v3.8771, so is not affected by the recent 'timer' bug, this should work.
Posted: Thursday 28 December 2017 20:10
by lumjajo
I did a new stable install on another sd and just copied the database. Now it works but with the following messages:
1) in the setup, there is the checkup for dzVents and i cannot change it. Everytime I look in the setup its checkmarked again (I did a save of course), however, dzVents is running regardless of the checkmark. This is strange.
2) in the log it says: dzVents: Fronius script running!! but Fronius is a LUA script. It works fine, but why this message?
3) in the log error messages it says: Error: EventSystem: in dzVents.lua: cannot open dzVents.lua: No such file or director
What does this mean?
Thanks for some light in the dark..
