Razberry daughter card
Posted: Wednesday 27 December 2017 13:50
Hi ,
I am a little bit stuck on a problem...
I have set up Domoticz on a Raspberry Pi Model 2B with a Razberry daughter card.
I did the installation process as described in the forum:
https://www.domoticz.com/forum/viewtopi ... =20#p89074
https://www.domoticz.com/forum/viewtopi ... 55#p117527
Now, I'm not quite sure how to add the card to the domoticz system. I tried Hardware -> Add -> Type: OpenZWave USB and Serial Port: /dev/serial0. The Setup-Button is blue. So far so good. But when I want to add a Device, the LED which should light up on the daughter card remains dark
Is the Razberry card setup in domoticz correct? Is there anything missing? How can I check if all necesarry services are up and running?
Thanks a lot!
Thanks a lot!
