Qubino Flush 2 relay with push button controll
Posted: Saturday 23 December 2017 14:45
by dagger38
I have got 2 flush 2 relay switches from qubino.
I want to switch these on and off with a push button.
Push button is connected to I1.
the Q1 output is set to mono stable switch type (push button)
Problem , when i press the button the light go's on , if i release it , the light go's off??
Shoudln't the light stay ON untill i push the button one's again??
Or what am i douing wroung??
Re: Qubino Flush 2 relay with push button controll
Posted: Sunday 24 December 2017 18:02
by Denny64
I also have some Qubino switches and they work properly with Domoticz. The only flaw I found is a very frequent latency, and it's not possible to put them inside a scene..
For your problem, try to exclude them from the network and reassociate them by changing parameters 1 and 2 again.
Do not forget to save the configuration, press update and select the Qubino switch again to see if the parameters have been correctly saved.
Posted: Sunday 24 December 2017 18:08
by dagger38
going to try that
Posted: Tuesday 03 August 2021 7:54
by akamming
i installed this device, including the temperature sensor (ZMNHEA1 according to docs). The connector of the sensor fits nicely into the device. However i don't see any temperature readings.
I already enabled polling and set configuration param 120 (Digital sensor reporting) to 1. Do I have a faulty device or am i doing something wrong?
UPDATE: fixed it. I did a factory reset, and then re-included the device with the temperature sensor attached during inclusion. This did the trick. Temperature is now reported!
