No connection with Domoticz
Posted: Friday 22 December 2017 17:42
by Armand0
Today I downloaded and installed Domoticz on my Raspberry Pi.
Installation was done 'the easy way' using "curl -L install.domoticz.com | sudo bash".
After installation I can not connect to the webpage to configure Domoticz. The webpage is not found. Restarting did not help, network connection is not the problem because i am able to log in with Putty.
I have some basic Linus knowledge but I'm lost right now and don't know what to do to get things working.
Re: No connection with Domoticz
Posted: Friday 22 December 2017 17:55
by BakSeeDaa
Armand0 wrote: Friday 22 December 2017 17:42
1) What URL did you try to open?
2) What is the IP address of your Domoticz host?
Posted: Friday 22 December 2017 21:56
by Armand0
I did try both addresses
http://192.168.178.111:8080
https://192.168.178.111:443
Hence the IP address is 192.168.178.111
Posted: Saturday 23 December 2017 9:10
by BakSeeDaa
Is the Domoticz service up and running?
If not, try to start it
and check status again.
If it fails to start as a service, try to start it manually and see if you get any messages that might tell you why it isn't starting
Did that help?
Posted: Saturday 23 December 2017 9:25
by CaesarPL
I am 99% sure that it’s ssl issue and was described here 100 times...
Posted: Saturday 23 December 2017 13:50
by Armand0
BakSeeDaa wrote: Saturday 23 December 2017 9:10
Did that help?
I get an errormessage:
"Error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory"
So it seems to be the famous (but unknown to a newbe like me) ssl issue. Is there a link to a solution available?
::edit
Downloaded the .deb file and placed it on the sd-card. Installed it and can connect now!
Thanks for pointing me in the right direction...
::/edit
