Hi.
I Am running Domoticz on Ubuntu server, and it worked perfect, but due to mess on the ubuntu server I just wanted to do a clean install.
Så this is what i did:
- created a database backup "domoticz.db"
- Reinstalled Ubuntu Server
- Installed Domoticz
- Started Domoticz, imported domoticz.db
- All devices are presented in devices, and all my RFXCOM devices work, but not the Z-wave devices. I use UZB1
- Also noted that the login to Domoticz webpage changed to the same username as on last installation (not really a problem)
Any solution?
PS: This is a VM in ESXI, and I have a backup of the old VM, so if i need some files or something I a amble to get that.
All Z-wave nodes gone after server reinstall Topic is solved
Evelen
- Domoticz version: 2.4538
- 3.png (156.38 KiB) Viewed 2232 times
- 2.png (261.91 KiB) Viewed 2232 times
- 1.png (135.7 KiB) Viewed 2232 times
Quax1507
Re: All Z-wave nodes gone after server reinstall
I normally make a backup of the whole /.../domoticz directory which can be copied over the new installation.
This worked fine so far...
Clemen
The z-wave configuration are stored on the z-wave stick.
What type of z-wave stick are you using?
Is it connected, it seems to that your domoticz can't see the stick
Evelen
Got ut to work by re-insetting it in the ESXI host
thanks for help
thanks for help
lost
Another tip was given here:Evelen wrote: Friday 22 December 2017 17:56 Got ut to work by re-insetting it in the ESXI host
thanks for help
http://www.domoticz.com/forum/viewtopic ... 59#p156459
But didn't tried as after my reinstall that lead to same zeroed IDs, never runned again in this problem.
