How to set the app on Android?
gianvi97
Post by gianvi97 »
Hello everyone,
I can not set the app for android. Which parameters should I enter and where can I find them?
Thank you
whatisk
Domoticz version: 3.9224
Re: How to set the app on Android?
Post by whatisk »
When the app is open, tap on the 'hamburger' in the top left (three lines one above the other).
Scroll down to settings. When in settings go into Server settings and enter the IP and port for Domoticz in there. As well as username and password if required. This would be the ip address and port you use to access it in your browser.
gianvi97
Post by gianvi97 »
But which IP I have to insert? The address bar or the gateway bar? And the door from where I see it? I do not have any "three lines one above the other"
billouetaudrey
Post by billouetaudrey »
gianvi97 wrote:But which IP I have to insert? The address bar or the gateway bar? And the door from where I see it? I do not have any "three lines one above the other"
You need domoticz server... Windows / Linux /Raspberry
Envoyé de mon Redmi Note 4 en utilisant Tapatalk
