Use these; I cannot test it since my dumb old avr is only one Zone (or at least i am using only 1); But you can test and send me the results to solve it.
So, what i changed there is; use INPUT_MODES instead of Z2_INPUT_MODES since you did not defined Z2_INPUT_MODES and it is simply the same with INPUT_MODES content, so you can use it.
<plugin key="PioneerAVR" name="Pioneer AVR" author="febalci" version="0.9.0">
<params>
<param field="Address" label="IP Address" width="250px" required="true" default="192.168.1.60"/>
<param field="Port" label="Port" width="50px" required="true" default="8102"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import pioneerapi
class BasePlugin:
nextConnect = 3
oustandingPings = 0
UNITS = {
'power': 1,
'input': 2,
'display': 3,
'listening_mode': 4,
'playing_mode': 5,
'main_volume': 6,
'z2_power': 7,
'z2_input': 8,
'z2_volume': 9
PioneerConn = None
power_on = False
volume_level = None
mute = None
input_rgb_name = None
input_mode = "0"
listening_mode = None
playing_mode = None
display_text = None
InputIdx = ("01","02","03","04","05","10","14","15","17","25","26")
#Zone 2
Z2_power_on = False
Z2_volume_level = None
Z2_mute = None
Z2_input_rgb_name = None
Z2_input_mode = "0"
Z2_InputIdx = ("01","02","03","04","05","10","14","15","17","25","26")
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Debug("onStart called")
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
InputSelections = 'Off'
for a in self.InputIdx:
InputSelections = InputSelections+'|'+pioneerapi.INPUT_MODES[a]
Domoticz.Debug('LIST:'+InputSelections)
SourceOptions = {'LevelActions': '|'*InputSelections.count('|'),
'LevelNames': InputSelections,
'LevelOffHidden': 'false',
'SelectorStyle': '1'}
if self.UNITS['power'] not in Devices:
Domoticz.Device(Name="Power", Unit=self.UNITS['power'], TypeName="Switch", Image=5, Used=1).Create()
if self.UNITS['input'] not in Devices:
Domoticz.Device(Name="Input", Unit=self.UNITS['input'], TypeName="Selector Switch", Switchtype=18, Image=5, Options=SourceOptions, Used=1).Create()
if self.UNITS['display'] not in Devices:
Domoticz.Device(Name="Display", Unit=self.UNITS['display'], TypeName="Text", Image=5, Used=1).Create()
if self.UNITS['listening_mode'] not in Devices:
Domoticz.Device(Name="Listening Mode", Unit=self.UNITS['listening_mode'], TypeName="Text", Used=1).Create()
if self.UNITS['playing_mode'] not in Devices:
Domoticz.Device(Name="Playing Mode", Unit=self.UNITS['playing_mode'], TypeName="Text", Used=1).Create()
if self.UNITS['main_volume'] not in Devices:
Domoticz.Device(Name="Volume Main Zone", Unit=self.UNITS['main_volume'], Type=244, Subtype=73, Switchtype=7, Image=8, Used=1).Create()
#Zone 2
Z2InputSelections = 'Off'
for a in self.Z2_InputIdx:
Z2InputSelections = Z2InputSelections+'|'+pioneerapi.INPUT_MODES[a]
Domoticz.Debug('LIST:'+Z2InputSelections)
Z2SourceOptions = {'LevelActions': '|'*Z2InputSelections.count('|'),
'LevelNames': Z2InputSelections,
if self.UNITS['z2_power'] not in Devices:
Domoticz.Device(Name="Zone 2 Power", Unit=self.UNITS['z2_power'], TypeName="Switch", Image=5, Used=1).Create()
if self.UNITS['z2_input'] not in Devices:
Domoticz.Device(Name="Zone 2 Input", Unit=self.UNITS['z2_input'], TypeName="Selector Switch", Switchtype=18, Image=5, Options=Z2SourceOptions, Used=1).Create()
if self.UNITS['z2_volume'] not in Devices:
Domoticz.Device(Name="Volume Zone 2", Unit=self.UNITS['z2_volume'], Type=244, Subtype=73, Switchtype=7, Image=8, Used=1).Create()
DumpConfigToLog()
self.SyncDevices(1)
self.PioneerConn = Domoticz.Connection(Name="Telnet", Transport="TCP/IP", Protocol="Line", Address=Parameters["Address"], Port=Parameters["Port"])
self.PioneerConn.Connect()
Domoticz.Heartbeat(30)
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
global api
Domoticz.Debug("onConnect called")
if Status == 0:
self.isConnected = True
Domoticz.Debug("Connected successfully to: "+Parameters["Address"]+":"+Parameters["Port"])
api = pioneerapi.pioneerapi()
self.PioneerConn.Send('\r') #Send <CR> to wake unit from stanby
self.PioneerConn.Send(api.qry_PowerStatus, Delay=1)
self.PioneerConn.Send(api.qry_InputStatus, Delay=2)
self.PioneerConn.Send(api.qry_VolumeStatus, Delay=3)
self.PioneerConn.Send(api.qry_ListeningModeStatus, Delay=4)
self.PioneerConn.Send(api.qry_Z2_PowerStatus, Delay=5)
self.PioneerConn.Send(api.qry_Z2_InputStatus, Delay=6)
self.PioneerConn.Send(api.qry_Z2_VolumeStatus, Delay=7)
wait=8
for key in self.InputIdx:
wait += 1
self.PioneerConn.Send("?RGB"+str(key)+"\r", Delay=wait)
else:
self.isConnected = False
self.power_on = False
self.SyncDevices(1)
Domoticz.Debug("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"]+" with error: "+Description)
return
def onMessage(self, Connection, Data):
Domoticz.Debug("onMessage called")
self.oustandingPings = self.oustandingPings - 1
strData = Data.decode("utf-8", "ignore")
Domoticz.Debug("onMessage called with Data: '"+str(strData)+"'")
strData = strData.strip()
shaction = strData[0:2]
shdetail = strData[2:]
loaction = strData[0:3]
lodetail = strData[3:]
if loaction == 'PWR': #POWER
if lodetail == '0': #PWR0
self.power_on = True
self.PioneerConn.Send(api.qry_VolumeStatus, Delay=0)
else: #PWR1
elif loaction == 'VOL': #VOLUME
self.volume_level = str(round((int(str(lodetail))*100)/185))
elif loaction == 'MUT': #MUTE
if lodetail == '0': #MUT0
self.mute = 'On'
else: #MUT1
self.mute = 'Off'
elif loaction == 'RGB': #INPUT NAME
self.input_rgb_name = api.RGB_decode(str(lodetail))
if self.input_rgb_name != None:
Domoticz.Debug('RGB:'+self.input_rgb_name)
Devices[self.UNITS['input']].Update(nValue = 0, sValue = "Off", Options = SourceOptions)
elif shaction == 'FN': #INPUT
self.input_mode = self.selector_find(str(shdetail), 0)
Domoticz.Debug('FN:'+str(self.input_mode))
elif shaction == 'Z2F': #Zone 2 INPUT
Domoticz.Debug('Z2F:'+str(self.input_mode))
elif shaction == 'SR': #LISTENING MODE
self.listening_mode = api.SR_decode(str(shdetail))
Domoticz.Debug('SR:'+self.listening_mode)
elif shaction == 'LM': #PLAYING LISTENING MODE
self.playing_mode = api.LM_decode(str(shdetail))
Domoticz.Debug('LM:'+self.playing_mode)
elif shaction == 'FL': #DISPLAY TEXT
self.display_text = api.FL_decode(str(shdetail))
Domoticz.Debug('FL:'+self.display_text)
self.SyncDevices(0)
return
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
action, sep, params = Command.partition(' ')
action = action.capitalize()
params = params.capitalize()
if Unit == self.UNITS['power']:
if Command=='Off':
Domoticz.Debug("Unit Power Off")
self.PioneerConn.Send(Message=api.cmd_PowerOff, Delay=0)
elif Command=='On':
Domoticz.Debug("Unit Power On")
self.PioneerConn.Send(Message=api.cmd_PowerOn, Delay=0)
elif Unit == self.UNITS['main_volume']:
if (action == "On"):
self.PioneerConn.Send(Message='MF\r', Delay=0)
elif (action == "Set"):
self.volume_level = str(round((int(Level)*185)/100)).rjust(3,'0')
self.PioneerConn.Send(Message=self.volume_level+'VL\r', Delay=0)
elif (action == "Off"):
self.PioneerConn.Send(Message='MO\r', Delay=0)
Domoticz.Debug('Level:'+str(Level))
elif Unit == self.UNITS['input']:
if Level != "0":
self.input_mode = self.selector_find(Level,1)
self.PioneerConn.Send(Message=self.input_mode+'FN\r', Delay=0)
else:
#Zone 2
if Unit == self.UNITS['z2_power']:
if Command=='Off':
self.PioneerConn.Send(Message=api.cmd_Z2_PowerOff, Delay=0)
elif Command=='On':
self.PioneerConn.Send(Message=api.cmd_Z2_PowerOn, Delay=0)
elif Unit == self.UNITS['z2_volume']:
self.PioneerConn.Send(Message='Z2MF\r', Delay=0) #mute on function
self.PioneerConn.Send(Message=self.volume_level+'ZV\r', Delay=0)
self.PioneerConn.Send(Message='Z2MO\r', Delay=0) #mute off function
elif Unit == self.UNITS['z2_input']:
if Level != "0":
self.PioneerConn.Send(Message=self.z2_input_mode+'ZS\r', Delay=0)
else:
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
def onHeartbeat(self):
if (self.PioneerConn.Connected() == True):
if (self.oustandingPings > 3):
Domoticz.Debug("Ping Timeout, Disconnect")
self.PioneerConn.Disconnect()
self.nextConnect = 0
else:
self.PioneerConn.Send(Message=api.qry_PowerStatus,Delay=0)
Domoticz.Debug("POWER STATUS Message Sent")
self.oustandingPings = self.oustandingPings + 1
else:
# if not connected try and reconnected every 2 heartbeats
self.oustandingPings = 0
self.nextConnect = self.nextConnect - 1
if (self.nextConnect <= 0):
self.nextConnect = 3
return
def SyncDevices(self, TimedOut):
if (self.power_on == False):
UpdateDevice(self.UNITS['power'], 0, "Off", TimedOut)
UpdateDevice(self.UNITS['input'], 0, "0", TimedOut)
UpdateDevice(self.UNITS['display'], 0, "", TimedOut)
UpdateDevice(self.UNITS['listening_mode'], 0, "", TimedOut)
UpdateDevice(self.UNITS['playing_mode'], 0, "", TimedOut)
UpdateDevice(self.UNITS['main_volume'], 0, self.volume_level, TimedOut)
else:
UpdateDevice(self.UNITS['power'], 1 , "On", TimedOut)
UpdateDevice(self.UNITS['input'], int(self.input_mode), str(self.input_mode), TimedOut)
UpdateDevice(self.UNITS['display'], 0, self.display_text, TimedOut)
UpdateDevice(self.UNITS['listening_mode'], 0, self.listening_mode, TimedOut)
UpdateDevice(self.UNITS['playing_mode'], 0, self.playing_mode, TimedOut)
UpdateDevice(self.UNITS['main_volume'],2,self.volume_level, TimedOut)
return
def selector_find(self, query, ctype):
if ctype == 0:
sel = (self.InputIdx.index(str(query))+1)*10 #Off olduğu için +1 var
Domoticz.Debug('INDEX:'+str(sel))
else:
sel = self.InputIdx[int((query/10)-1)] #Off olduğu için -1 var
return sel
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def UpdateDevice(Unit, nValue, sValue, TimedOut):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if (Unit in Devices):
if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue) or (Devices[Unit].TimedOut != TimedOut):
Devices[Unit].Update(nValue=nValue, sValue=str(sValue), TimedOut=TimedOut)
Domoticz.Log("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
return
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
I highly doubt that this will work flawlessly since i did not checked all, but at least it creates the devicesİ i i find some free time in the weekend i might check it out...
