Python Plugin : HTTP Listener example question
gerardwr
Post by gerardwr »
I am looking for a way to add a Python Plugin thats acts like a webserver, that can be called by a webclient on antoher computer.
Running Domotizc Version: 3.8755 on RPi-1-Jessie.
I did not find much information on the HTTP Listener Python Plugin example, but I THINK it:
- adds a webserver waiting for connections from webclients
- starts a webclient on every "heartbeat" and connects to the plugin-webserver
Running the plugin the Log shows that the heartbeat-client connects to the server and responds to the client. Works!
BUT if I try to connect a client on an different machine to the plugin-server I get no response from the server, and no info in the Domoticz Log.
My Domoticz is on 192.168.0.28, and is UP:
pi@raspberrypiZolder:~/domoticz/plugins/HTTPListener $ curl 192.168.0.28:8080/log
<html><head><title>Not Found</title></head><body><h1>404 Not Found</h1></body></html>
The HTTP Listener Plugin listens on the default port 127.0.0.1:8008. When I try to connect, no response:
pi@raspberrypiZolder:~/domoticz/plugins/HTTPListener $ curl 192.168.0.28:8008
I would expect the client to be connected to the plugin-webserver, but that does not happen.
Stupid mistake on my part, or am I missing something?
Dnpwwo
Re: Python Plugin : HTTP Listener example question
Post by Dnpwwo »
@gerardwr,
Your summary of the example's functionality is pretty accurate. I figured there was no point in a sample that just listened without any activity.
I never tested with Curl but would expect it to work. I connected from a web browser which from memory opens a connection then issues an HTTP GET. The example returns a 200 response and
<!doctype html><html><head></head><body><h1>Successful GET!!!</h1><body></html>
I would suggest:
  • try from a web browser
  • turning debug on and looking at the Domoticz log I would expect to see a connection message at a minimum. I would recommend running Domoticz from the command line to do that because HTML response don't format very well in the Web UI log
gerardwr
Post by gerardwr »
Dnpwwo wrote: Thursday 21 December 2017 6:38 @gerardwr,
Thanks for the heads up. Took me a while before I got it. Excellent "turn key" example, once you "get it" !
Tested in a browser ( on Mac with both Safari and Chrome ) but no response, the browser is, just like Curl, "waiting" :(
I would suggest:
[/quote]
Looked at the log, it is flooded with numerous debugmessages from Heartbeat, but I did not spot a connection message from the brwoser-use yet. Will try later witch Domticz in the command-line, gives me more time to check the messages :)
Thx so far!
gerardwr
Post by gerardwr »
Dnpwwo wrote: Thursday 21 December 2017 6:38 I would suggest:
Had a better look. Started domoticz on commandline and browsed from Mac on 192.168.0.81 to the Domoticz URL defined in the plugin (192.168.0.28:8008)
In the Domicz output I see that the GET from the browser is received:
- onConnect handler is called
- onMessage handler is called
=== "succesfull get" page is sent
=== and "succesfull get" page is received again, huh!?
But the "succesfull get" page is not shown in the browser.
Could it be that the page is returned to the IP of the Domticz server instead of the Ip of the requesting browser?
Detailed output is:
pi@raspberrypiZolder:~/domoticz $ ./domoticz | grep httplist
2017-12-21 11:29:04.723 (httplistener) Started.
2017-12-21 11:29:11.388 (httplistener) Initialized version 1.0.0, author 'dnpwwo'
2017-12-21 11:29:11.391 (httplistener) Entering work loop.
2017-12-21 11:29:11.921 (httplistener) Debug log level set to: 'true'.
2017-12-21 11:29:11.925 (httplistener) 'Version':'1.0.0'
2017-12-21 11:29:11.928 (httplistener) 'Author':'dnpwwo'
2017-12-21 11:29:11.931 (httplistener) 'Name':'httplistener'
2017-12-21 11:29:11.939 (httplistener) 'Mode6':'Debug'
2017-12-21 11:29:11.942 (httplistener) 'HomeFolder':'/home/pi/domoticz/plugins/HTTPListener/'
2017-12-21 11:29:11.960 (httplistener) 'Key':'HTTPListen'
2017-12-21 11:29:11.963 (httplistener) 'HardwareID':'27'
2017-12-21 11:29:11.966 (httplistener) 'Port':'8008'
2017-12-21 11:29:11.969 (httplistener) Device count: 0
2017-12-21 11:29:11.972 (httplistener) Leaving on start
2017-12-21 11:29:12.002 (httplistener) Protocol set to: 'HTTP'.
2017-12-21 11:29:12.006 (httplistener) Transport set to: 'TCP/IP', :8008.
2017-12-21 11:29:12.010 (httplistener) Listen directive received, action initiated successfully.
===============> browse to url : 192.168.0.28:8008/page.html =================================
2017-12-21 11:29:27.470 (httplistener) Protocol set to: 'HTTP'.
2017-12-21 11:29:27.471 (httplistener) Calling message handler 'onConnect'.
2017-12-21 11:29:27.474 (httplistener) Connected successfully to: 192.168.0.81:49219
2017-12-21 11:29:27.476 (httplistener) Name: '192.168.0.81:49219', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '192.168.0.81', Port: '49219', Baud: 0, Bytes: 366, Connected: True, Last Seen: 2017-12-21 11:29:27
2017-12-21 11:29:27.481 (httplistener) Received 366 bytes of data:
2017-12-21 11:29:27.483 (httplistener) 47 45 54 20 2f 70 61 67 65 2e 68 74 6d 6c 20 48 54 54 50 2f GET./page.html.HTTP/
2017-12-21 11:29:27.485 (httplistener) 31 2e 31 0d 0a 48 6f 73 74 3a 20 31 39 32 2e 31 36 38 2e 30 1.1..Host:.192.168.0
2017-12-21 11:29:27.491 (httplistener) 2e 32 38 3a 38 30 30 38 0d 0a 55 70 67 72 61 64 65 2d 49 6e .28:8008..Upgrade-In
2017-12-21 11:29:27.492 (httplistener) 73 65 63 75 72 65 2d 52 65 71 75 65 73 74 73 3a 20 31 0d 0a secure-Requests:.1..
2017-12-21 11:29:27.495 (httplistener) 41 63 63 65 70 74 3a 20 74 65 78 74 2f 68 74 6d 6c 2c 61 70 Accept:.text/html,ap
2017-12-21 11:29:27.500 (httplistener) 70 6c 69 63 61 74 69 6f 6e 2f 78 68 74 6d 6c 2b 78 6d 6c 2c plication/xhtml+xml,
2017-12-21 11:29:27.501 (httplistener) 61 70 70 6c 69 63 61 74 69 6f 6e 2f 78 6d 6c 3b 71 3d 30 2e application/xml;q=0.
2017-12-21 11:29:27.501 (httplistener) 39 2c 2a 2f 2a 3b 71 3d 30 2e 38 0d 0a 55 73 65 72 2d 41 67 9,*/*;q=0.8..User-Ag
2017-12-21 11:29:27.501 (httplistener) 65 6e 74 3a 20 4d 6f 7a 69 6c 6c 61 2f 35 2e 30 20 28 4d 61 ent:.Mozilla/5.0.(Ma
2017-12-21 11:29:27.501 (httplistener) 63 69 6e 74 6f 73 68 3b 20 49 6e 74 65 6c 20 4d 61 63 20 4f cintosh;.Intel.Mac.O
2017-12-21 11:29:27.502 (httplistener) 53 20 58 20 31 30 5f 31 31 5f 36 29 20 41 70 70 6c 65 57 65 S.X.10_11_6).AppleWe
2017-12-21 11:29:27.502 (httplistener) 62 4b 69 74 2f 36 30 34 2e 34 2e 37 20 28 4b 48 54 4d 4c 2c bKit/604.4.7.(KHTML,
2017-12-21 11:29:27.502 (httplistener) 20 6c 69 6b 65 20 47 65 63 6b 6f 29 20 56 65 72 73 69 6f 6e .like.Gecko).Version
2017-12-21 11:29:27.502 (httplistener) 2f 31 31 2e 30 2e 32 20 53 61 66 61 72 69 2f 36 30 34 2e 34 /11.0.2.Safari/604.4
2017-12-21 11:29:27.503 (httplistener) 2e 37 0d 0a 41 63 63 65 70 74 2d 4c 61 6e 67 75 61 67 65 3a .7..Accept-Language:
2017-12-21 11:29:27.503 (httplistener) 20 6e 6c 2d 6e 6c 0d 0a 41 63 63 65 70 74 2d 45 6e 63 6f 64 .nl-nl..Accept-Encod
2017-12-21 11:29:27.503 (httplistener) 69 6e 67 3a 20 67 7a 69 70 2c 20 64 65 66 6c 61 74 65 0d 0a ing:.gzip,.deflate..
2017-12-21 11:29:27.504 (httplistener) 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 Connection:.keep-ali
2017-12-21 11:29:27.504 (httplistener) 76 65 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. ve....
2017-12-21 11:29:27.505 (httplistener) Calling message handler 'onMessage'.
2017-12-21 11:29:27.505 (httplistener) onMessage called for connection: 192.168.0.81:49219
2017-12-21 11:29:27.505 (httplistener) HTTP Details (3):
2017-12-21 11:29:27.506 (httplistener) --->'URL':'/page.html'
2017-12-21 11:29:27.506 (httplistener) --->'Verb':'GET'
2017-12-21 11:29:27.506 (httplistener) --->'Headers (7):
2017-12-21 11:29:27.507 (httplistener) ------->'Connection':'keep-alive'
2017-12-21 11:29:27.507 (httplistener) ------->'Accept':'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
2017-12-21 11:29:27.507 (httplistener) ------->'Accept-Language':'nl-nl'
2017-12-21 11:29:27.508 (httplistener) ------->'User-Agent':'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/604.4.7 (KHTML, like Gecko) Version/11.0.2 Safari/604.4.7'
2017-12-21 11:29:27.508 (httplistener) ------->'Accept-Encoding':'gzip, deflate'
2017-12-21 11:29:27.508 (httplistener) ------->'Host':'192.168.0.28:8008'
2017-12-21 11:29:27.509 (httplistener) ------->'Upgrade-Insecure-Requests':'1'
2017-12-21 11:29:27.509 (httplistener) GET request received.
2017-12-21 11:29:27.552 (httplistener) Sending 249 bytes of data:
2017-12-21 11:29:27.554 (httplistener) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 HTTP/1.1.200.OK..Dat
2017-12-21 11:29:27.557 (httplistener) 65 3a 20 54 68 75 2c 20 32 31 20 44 65 63 20 32 30 31 37 20 e:.Thu,.21.Dec.2017.
2017-12-21 11:29:27.559 (httplistener) 31 30 3a 32 39 3a 32 37 20 47 4d 54 0d 0a 53 65 72 76 65 72 10:29:27.GMT..Server
2017-12-21 11:29:27.571 (httplistener) 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 41 63 63 65 :.Domoticz/1.0..Acce
2017-12-21 11:29:27.573 (httplistener) 70 74 3a 20 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 pt:.Content-Type:.te
2017-12-21 11:29:27.575 (httplistener) 78 74 2f 68 74 6d 6c 3b 20 63 68 61 72 73 65 74 3d 55 54 46 xt/html;.charset=UTF
2017-12-21 11:29:27.577 (httplistener) 2d 38 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 -8..Connection:.keep
2017-12-21 11:29:27.579 (httplistener) 2d 61 6c 69 76 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 -alive..Content-Leng
2017-12-21 11:29:27.582 (httplistener) 74 68 3a 20 37 39 0d 0a 0d 0a 3c 21 64 6f 63 74 79 70 65 20 th:.79....<!doctype.
2017-12-21 11:29:27.584 (httplistener) 68 74 6d 6c 3e 3c 68 74 6d 6c 3e 3c 68 65 61 64 3e 3c 2f 68 html><html><head></h
2017-12-21 11:29:27.586 (httplistener) 65 61 64 3e 3c 62 6f 64 79 3e 3c 68 31 3e 53 75 63 63 65 73 ead><body><h1>Succes
2017-12-21 11:29:27.588 (httplistener) 73 66 75 6c 20 47 45 54 21 21 21 3c 2f 68 31 3e 3c 62 6f 64 sful.GET!!!</h1><bod
2017-12-21 11:29:27.590 (httplistener) 79 3e 3c 2f 68 74 6d 6c 3e .. .. .. .. .. .. .. .. .. .. .. y></html>
2017-12-21 11:29:27.594 (httplistener) Received 249 bytes of data:
2017-12-21 11:29:27.603 (httplistener) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 HTTP/1.1.200.OK..Dat
2017-12-21 11:29:27.605 (httplistener) 65 3a 20 54 68 75 2c 20 32 31 20 44 65 63 20 32 30 31 37 20 e:.Thu,.21.Dec.2017.
2017-12-21 11:29:27.607 (httplistener) 31 30 3a 32 39 3a 32 37 20 47 4d 54 0d 0a 53 65 72 76 65 72 10:29:27.GMT..Server
2017-12-21 11:29:27.609 (httplistener) 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 41 63 63 65 :.Domoticz/1.0..Acce
2017-12-21 11:29:27.611 (httplistener) 70 74 3a 20 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 pt:.Content-Type:.te
2017-12-21 11:29:27.616 (httplistener) 78 74 2f 68 74 6d 6c 3b 20 63 68 61 72 73 65 74 3d 55 54 46 xt/html;.charset=UTF
2017-12-21 11:29:27.618 (httplistener) 2d 38 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 -8..Connection:.keep
2017-12-21 11:29:27.620 (httplistener) 2d 61 6c 69 76 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 -alive..Content-Leng
2017-12-21 11:29:27.631 (httplistener) 74 68 3a 20 37 39 0d 0a 0d 0a 3c 21 64 6f 63 74 79 70 65 20 th:.79....<!doctype.
2017-12-21 11:29:27.634 (httplistener) 68 74 6d 6c 3e 3c 68 74 6d 6c 3e 3c 68 65 61 64 3e 3c 2f 68 html><html><head></h
2017-12-21 11:29:27.636 (httplistener) 65 61 64 3e 3c 62 6f 64 79 3e 3c 68 31 3e 53 75 63 63 65 73 ead><body><h1>Succes
2017-12-21 11:29:27.638 (httplistener) 73 66 75 6c 20 47 45 54 21 21 21 3c 2f 68 31 3e 3c 62 6f 64 sful.GET!!!</h1><bod
2017-12-21 11:29:27.641 (httplistener) 79 3e 3c 2f 68 74 6d 6c 3e .. .. .. .. .. .. .. .. .. .. .. y></html>
===============> browse to url : 192.168.0.28:8008/testgwr.html =================================
2017-12-21 11:29:41.476 (httplistener) Calling message handler 'onConnect'.
2017-12-21 11:29:41.477 (httplistener) Connected successfully to: 192.168.0.81:49222
2017-12-21 11:29:41.477 (httplistener) Name: '192.168.0.81:49222', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '192.168.0.81', Port: '49222', Baud: 0, Bytes: 369, Connected: True, Last Seen: 2017-12-21 11:29:41
2017-12-21 11:29:41.477 (httplistener) Received 369 bytes of data:
2017-12-21 11:29:41.478 (httplistener) 47 45 54 20 2f 74 65 73 74 67 77 72 2e 68 74 6d 6c 20 48 54 GET./testgwr.html.HT
2017-12-21 11:29:41.478 (httplistener) 54 50 2f 31 2e 31 0d 0a 48 6f 73 74 3a 20 31 39 32 2e 31 36 TP/1.1..Host:.192.16
2017-12-21 11:29:41.478 (httplistener) 38 2e 30 2e 32 38 3a 38 30 30 38 0d 0a 55 70 67 72 61 64 65 8.0.28:8008..Upgrade
2017-12-21 11:29:41.478 (httplistener) 2d 49 6e 73 65 63 75 72 65 2d 52 65 71 75 65 73 74 73 3a 20 -Insecure-Requests:.
2017-12-21 11:29:41.479 (httplistener) 31 0d 0a 41 63 63 65 70 74 3a 20 74 65 78 74 2f 68 74 6d 6c 1..Accept:.text/html
2017-12-21 11:29:41.479 (httplistener) 2c 61 70 70 6c 69 63 61 74 69 6f 6e 2f 78 68 74 6d 6c 2b 78 ,application/xhtml+x
2017-12-21 11:29:41.479 (httplistener) 6d 6c 2c 61 70 70 6c 69 63 61 74 69 6f 6e 2f 78 6d 6c 3b 71 ml,application/xml;q
2017-12-21 11:29:41.479 (httplistener) 3d 30 2e 39 2c 2a 2f 2a 3b 71 3d 30 2e 38 0d 0a 55 73 65 72 =0.9,*/*;q=0.8..User
2017-12-21 11:29:41.480 (httplistener) 2d 41 67 65 6e 74 3a 20 4d 6f 7a 69 6c 6c 61 2f 35 2e 30 20 -Agent:.Mozilla/5.0.
2017-12-21 11:29:41.494 (httplistener) 28 4d 61 63 69 6e 74 6f 73 68 3b 20 49 6e 74 65 6c 20 4d 61 (Macintosh;.Intel.Ma
2017-12-21 11:29:41.495 (httplistener) 63 20 4f 53 20 58 20 31 30 5f 31 31 5f 36 29 20 41 70 70 6c c.OS.X.10_11_6).Appl
2017-12-21 11:29:41.495 (httplistener) 65 57 65 62 4b 69 74 2f 36 30 34 2e 34 2e 37 20 28 4b 48 54 eWebKit/604.4.7.(KHT
2017-12-21 11:29:41.495 (httplistener) 4d 4c 2c 20 6c 69 6b 65 20 47 65 63 6b 6f 29 20 56 65 72 73 ML,.like.Gecko).Vers
2017-12-21 11:29:41.495 (httplistener) 69 6f 6e 2f 31 31 2e 30 2e 32 20 53 61 66 61 72 69 2f 36 30 ion/11.0.2.Safari/60
2017-12-21 11:29:41.496 (httplistener) 34 2e 34 2e 37 0d 0a 41 63 63 65 70 74 2d 4c 61 6e 67 75 61 4.4.7..Accept-Langua
2017-12-21 11:29:41.496 (httplistener) 67 65 3a 20 6e 6c 2d 6e 6c 0d 0a 41 63 63 65 70 74 2d 45 6e ge:.nl-nl..Accept-En
2017-12-21 11:29:41.496 (httplistener) 63 6f 64 69 6e 67 3a 20 67 7a 69 70 2c 20 64 65 66 6c 61 74 coding:.gzip,.deflat
2017-12-21 11:29:41.497 (httplistener) 65 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 2d e..Connection:.keep-
2017-12-21 11:29:41.497 (httplistener) 61 6c 69 76 65 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. alive....
2017-12-21 11:29:41.497 (httplistener) Calling message handler 'onMessage'.
2017-12-21 11:29:41.498 (httplistener) onMessage called for connection: 192.168.0.81:49222
2017-12-21 11:29:41.498 (httplistener) HTTP Details (3):
2017-12-21 11:29:41.499 (httplistener) --->'URL':'/testgwr.html'
2017-12-21 11:29:41.499 (httplistener) --->'Verb':'GET'
2017-12-21 11:29:41.499 (httplistener) --->'Headers (7):
2017-12-21 11:29:41.500 (httplistener) ------->'Connection':'keep-alive'
2017-12-21 11:29:41.500 (httplistener) ------->'Accept':'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
2017-12-21 11:29:41.518 (httplistener) ------->'Accept-Language':'nl-nl'
2017-12-21 11:29:41.520 (httplistener) ------->'User-Agent':'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/604.4.7 (KHTML, like Gecko) Version/11.0.2 Safari/604.4.7'
2017-12-21 11:29:41.523 (httplistener) ------->'Accept-Encoding':'gzip, deflate'
2017-12-21 11:29:41.526 (httplistener) ------->'Host':'192.168.0.28:8008'
2017-12-21 11:29:41.528 (httplistener) ------->'Upgrade-Insecure-Requests':'1'
2017-12-21 11:29:41.530 (httplistener) GET request received.
2017-12-21 11:29:41.532 (httplistener) Sending 249 bytes of data:
2017-12-21 11:29:41.534 (httplistener) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 HTTP/1.1.200.OK..Dat
2017-12-21 11:29:41.536 (httplistener) 65 3a 20 54 68 75 2c 20 32 31 20 44 65 63 20 32 30 31 37 20 e:.Thu,.21.Dec.2017.
2017-12-21 11:29:41.538 (httplistener) 31 30 3a 32 39 3a 34 31 20 47 4d 54 0d 0a 53 65 72 76 65 72 10:29:41.GMT..Server
2017-12-21 11:29:41.540 (httplistener) 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 41 63 63 65 :.Domoticz/1.0..Acce
2017-12-21 11:29:41.542 (httplistener) 70 74 3a 20 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 pt:.Content-Type:.te
2017-12-21 11:29:41.544 (httplistener) 78 74 2f 68 74 6d 6c 3b 20 63 68 61 72 73 65 74 3d 55 54 46 xt/html;.charset=UTF
2017-12-21 11:29:41.547 (httplistener) 2d 38 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 -8..Connection:.keep
2017-12-21 11:29:41.549 (httplistener) 2d 61 6c 69 76 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 -alive..Content-Leng
2017-12-21 11:29:41.551 (httplistener) 74 68 3a 20 37 39 0d 0a 0d 0a 3c 21 64 6f 63 74 79 70 65 20 th:.79....<!doctype.
2017-12-21 11:29:41.552 (httplistener) 68 74 6d 6c 3e 3c 68 74 6d 6c 3e 3c 68 65 61 64 3e 3c 2f 68 html><html><head></h
2017-12-21 11:29:41.552 (httplistener) 65 61 64 3e 3c 62 6f 64 79 3e 3c 68 31 3e 53 75 63 63 65 73 ead><body><h1>Succes
2017-12-21 11:29:41.552 (httplistener) 73 66 75 6c 20 47 45 54 21 21 21 3c 2f 68 31 3e 3c 62 6f 64 sful.GET!!!</h1><bod
2017-12-21 11:29:41.553 (httplistener) 79 3e 3c 2f 68 74 6d 6c 3e .. .. .. .. .. .. .. .. .. .. .. y></html>
2017-12-21 11:29:41.561 (httplistener) Received 249 bytes of data:
2017-12-21 11:29:41.561 (httplistener) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 HTTP/1.1.200.OK..Dat
2017-12-21 11:29:41.562 (httplistener) 65 3a 20 54 68 75 2c 20 32 31 20 44 65 63 20 32 30 31 37 20 e:.Thu,.21.Dec.2017.
2017-12-21 11:29:41.562 (httplistener) 31 30 3a 32 39 3a 34 31 20 47 4d 54 0d 0a 53 65 72 76 65 72 10:29:41.GMT..Server
2017-12-21 11:29:41.562 (httplistener) 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 41 63 63 65 :.Domoticz/1.0..Acce
2017-12-21 11:29:41.568 (httplistener) 70 74 3a 20 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 pt:.Content-Type:.te
2017-12-21 11:29:41.569 (httplistener) 78 74 2f 68 74 6d 6c 3b 20 63 68 61 72 73 65 74 3d 55 54 46 xt/html;.charset=UTF
2017-12-21 11:29:41.569 (httplistener) 2d 38 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 -8..Connection:.keep
2017-12-21 11:29:41.569 (httplistener) 2d 61 6c 69 76 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 -alive..Content-Leng
2017-12-21 11:29:41.569 (httplistener) 74 68 3a 20 37 39 0d 0a 0d 0a 3c 21 64 6f 63 74 79 70 65 20 th:.79....<!doctype.
2017-12-21 11:29:41.570 (httplistener) 68 74 6d 6c 3e 3c 68 74 6d 6c 3e 3c 68 65 61 64 3e 3c 2f 68 html><html><head></h
2017-12-21 11:29:41.578 (httplistener) 65 61 64 3e 3c 62 6f 64 79 3e 3c 68 31 3e 53 75 63 63 65 73 ead><body><h1>Succes
2017-12-21 11:29:41.578 (httplistener) 73 66 75 6c 20 47 45 54 21 21 21 3c 2f 68 31 3e 3c 62 6f 64 sful.GET!!!</h1><bod
2017-12-21 11:29:41.579 (httplistener) 79 3e 3c 2f 68 74 6d 6c 3e .. .. .. .. .. .. .. .. .. .. .. y></html>
zak45
Domoticz version: V2024.4
Post by zak45 »
Maybe this could provide some help.
Attached plugin that implement Server/client communication.
plugin.py ==> execute the Server part and wait for client connection
btle.py ==> client connecting to the server and sending information.
if you connect to the Server using browser, you get Successful GET!!! message
BTLeScanr.zip
(22.36 KiB) Downloaded 98 times
gerardwr
Post by gerardwr »
zak45 wrote: Thursday 21 December 2017 12:58 Maybe this could provide some help.
Thanks @zak45,
Will try that later today.
zak45
Post by zak45 »
@gerardwr
take care : there is a problem in Domoticz/Python and the Tcp connection
if you reload the plugin, tcp connection is not closed and reopen.. but remain opened.
you need to change the Port number every time.
Dnpwwo know that and I think he or someonelse work on it...
https://www.domoticz.com/forum/viewtopi ... ed#p155902
gerardwr
Post by gerardwr »
@zak54
Just tested yor BTLEscan plugin, and I can connect to the server part:
Schermafbeelding 2017-12-21 om 13.27.41.png (35.47 KiB) Viewed 2361 times
At least I know now that the problem is not in my setup, but in the HTTP Listener example.
@Dnpwwo can probably help there.
For the time being I will have a more detailed look at the server part of your plugin and use this as a foundation for my own server plugin.
Thanks, you saved me many hours!
gerardwr
Post by gerardwr »
I compared the code from "HTTP Listener" and "BTLE Scanner" for a clue why a client did not get a response from the HTTP Listener, while it does get a response from BTLE Scanner.
The onConnect code from HTT Listener is:
    def onConnect(self, Connection, Status, Description):
        if (Status == 0):
            Domoticz.Log("Connected successfully to: "+Connection.Address+":"+Connection.Port)
        else:
            Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Connection.Address+":"+Connection.Port+" with error: "+Description)
        Domoticz.Log(str(Connection))
        if (Connection != self.httpClientConn):
            self.httpServerConns[Connection.Name] = Connection
The onConnectcode from BTLE Scanner is:
def onConnect(Connection, Status, Description):
    global httpServerConn , httpServerConns , httpClientConn
    if (Status == 0):
    else:
    if (Connection != httpClientConn):
            httpClientConn = Connection
    return
The only difference is the line:
After adding this line to the HTPP Listener example now the clients get a response! Buy I guess the onHeartbeat will now not get a response anymore.
I think it's best that @Dnwppo evaluates what changes would be required to the HTTListener example.
Thanks to @Dnwppo and @zak54 for their assistence :D
