Aeon Led Bulb functionning
Posted: Tuesday 19 December 2017 18:28
Hello Domoticz community,
I have successfully included a new Aeotec Led Bulb Gen5 to my domestic Z-Wave network controlled through an Aeotec Z-stick S2 by Domoticz v3.8153 installed on a Raspberry 3.
I want the Led Bulb blink in single blue color when I switch it on using a Domoticz control.
With the very kind help of an Aeon Lab engineer I managed to configure the bulb to get it blink in blue with the following parameter values (in case it would help somebody) :
Parameter 36: "Reboot Colorfull mode"
Parameter 37: dec.1113784384 (hex.42630040)
Parameter 38: dec.50530826 (hex.03030A0A)
Parameter 39: dec.1717986918 (hex.66666666)
I checked that this configuration is correctly saved and stored by the Led Bulb.
The problem I have is that if I command the Led Bulb off/on through the Domoticz control "Light/Switch", it does not take into consideration the saved configuration and goes back to standard lighting (in fact it goes back to the color last defined with the other Domoticz control "RGBW Switch")
What I want is to get my saved configuration (the blinking blue) on/off through the simple Domoticz switch control. This would appear to me as the most logical behavior.
Can somebody help me to get this ?
Many thanks !
Many thanks !
