3 buttons switch (chinese)
Posted: Sunday 17 December 2017 12:01
by Ouate
I bought the following 3 buttons chinese switch (below).
I have a RFcom working perfectly.
When I push a button of this switch, the RFcom LED is lighting.
That means the frequency is detected by RFcom.
Unfortunately I can not se a new device in the devices list even if the RFlink LED is lighting.
I think I tried every protocols, no success.
Does someone know how to make this switch work with Domoticz?
Anyone can help me ?
Link :
https://fr.aliexpress.com/item/86-Panne ... 14264.html
Picture :
Re: 3 buttons switch (chinese)
Posted: Sunday 17 December 2017 12:18
by Ouate
I tested every protocol one by one and I realized that only "undec on" is lighting the RFlink LED.
Does someone know how to make this switch working in this case ?
Is it possible ?
Thanks for your help
Posted: Sunday 17 December 2017 12:29
by SweetPants
You are talking about a RFcom and RFlink, what is it? Using 'undec' suspects you are using a RFXcom right? If that is true, it probably means it's not supported.
Posted: Sunday 17 December 2017 12:32
by Ouate
SweetPants wrote: Sunday 17 December 2017 12:29 You are talking about a RFcom and RFlink, what is it? Using 'undec' suspects you are using a RFXcom right? If that is true, it probably means it's not supported.
I'm sorry, it's RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (Version: Ext/1020)
Posted: Sunday 17 December 2017 12:42
by jvdz
Maybe a "stupid question", but you do have the "Accept new Hardware Devices " switched on during these tests?
Jos
Posted: Sunday 17 December 2017 12:55
by Ouate
jvdz wrote: Sunday 17 December 2017 12:42 Maybe a "stupid question", but you do have the "Accept new Hardware Devices " switched on during these tests?
Jos
Yes, new devices are already accepted.
This is not the cause.
Thanks for your help :)
Posted: Sunday 17 December 2017 18:04
by Lokonli
Jos
I've the single button version which is detected as EV1527 by RFlink.
Verstuurd vanaf mijn SM-G800F met Tapatalk
Posted: Sunday 17 December 2017 19:02
by Ouate
Lokonli wrote: Sunday 17 December 2017 18:04
Jos
Hi, can you tell me what is the protocol used by the device?
Posted: Sunday 17 December 2017 19:34
by Lokonli
Ouate wrote: Yes, new devices are already accepted.
I thought ev1527 is the protocol. Sorry, I don't have more information.
Posted: Monday 18 December 2017 9:27
by Ouate
Lokonli wrote: Sunday 17 December 2017 19:34
Ouate wrote:
Lokonli wrote: Sunday 17 December 2017 18:04 I've the single button version which is detected as EV1527 by RFlink.
Hik, the protocol is listed in the devices page. Beside the name of the device.
I will be helpful if you could let me know.
Posted: Monday 18 December 2017 13:41
by Ouate
I answer to myself because I found the answer.
This device (The 3 buttons switch) is detected using the protocol "Lightning 4" with a RFXcom
The problem is, when you activacted the protocal "Rubiscon" in the same time, the switch becomes not detected.
Impossible to detect it using the 2 protocols activated in the same time.
I have devices using Rubiscon protocol... I don't know how can I do to use the 2 kinds of devices in the same time.
Does someone has a solution ? :idea:
