Xiaomi Thermostat (with display)
Posted: Saturday 16 December 2017 8:46
Is there support for this device in domoticz?
https://m.gearbest.com/robot-vacuum-acc ... 06883.html
Open source Home Automation System
https://forum.domoticz.com/
had a closer look, and yes, you're right!mayyam wrote: Saturday 16 December 2017 20:59 I don't think, that's thermostat. It is just thermometer and humi with display and BT.
____
may
Can we use it via Bluetooth in domoticz?Slokoavac wrote:It is def not a thermostat. It is plain thermometer and humidity meter sending data over Bluetooth (no wifi! it's a reseller typo) to mobile phone to Mi Home app. Using single AAA battery with a nice large display (lasting up to a year).
When the price hits <10$ i wouldn't mind buying it then use it in Domoticz via BT. Much easier to replace AAA battery than button one on Xiaomi zigbee devices (thermometer, PIR, etc).
Yes, and it a pretty neat device! Very accurate and sensitive. However, I haven't been able to connect it to Domoticz (either through Mijia Bedside Lamp as gateway or directly by BT).Slokoavac wrote: Wednesday 20 December 2017 0:03 i hope so. Has anyone purchased it yet? Price is a bit high at the moment imho...
The new bedside lamp has Wifi+BT. You connect with Wi-Fi the new bedside lamp in the mi-home app(for full ecosystem integration) or yeelight app (for only lightning option). This lamp is a BT Gateway for all your Xiaomi BT sensors (flower sensor and this new display sensors for temp/humi)I have also this new lamp version but waiting for the new BT sensors with display. The lamp is nice. For more Infos look at this "promo" video:Slokoavac wrote:How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
I will order one when price hits 10$
So I've tried, however due to lacking bluetooth + Python skills, I haven't got it working yet.micontije wrote: Friday 12 January 2018 12:39 I have only xiaomi mi hygrothermograph (that is the name of the product) sensor with LCD. It works only with mi home app over bluetooth, but I havn't trends and any log. Just shows values of temp and hum.
Is it possible to connect with Domoticz just over bluetooth and achieve that function?
Oh cool, i thought it only had WiFi. Does miio lib supports it? You can check miio here:Eligos wrote: Friday 12 January 2018 11:12The new bedside lamp has Wifi+BT. You connect with Wi-Fi the new bedside lamp in the mi-home app(for full ecosystem integration) or yeelight app (for only lightning option). This lamp is a BT Gateway for all your Xiaomi BT sensors (flower sensor and this new display sensors for temp/humi)I have also this new lamp version but waiting for the new BT sensors with display. The lamp is nice. For more Infos look at this "promo" video:Slokoavac wrote:How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
https://youtu.be/rKK-hF64IHE
Thanks for sharing! Did something very similar (see viewtopic.php?f=56&t=21904), unfortunately with my script values aren´t displayed on the sensors themselfs in Domoticz although the URL I´m calling is the same (even if I add the comfort part) - crazy!PaulFen wrote: Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
You're welcome.freibeuter wrote: Tuesday 30 January 2018 17:36Thanks for sharing! Did something very similar (see viewtopic.php?f=56&t=21904), unfortunately with my script values aren´t displayed on the sensors themselfs in Domoticz although the URL I´m calling is the same (even if I add the comfort part) - crazy!PaulFen wrote: Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
gosh - you were right about this - totally missed the hex 00 in ascii string. Added fix to my script, too.
Works pretty well, however I need to set my Mijia BLE Temp + Humidity sensor in 'pairing' (flasing BT icon) mode before I get any readouts. When the RPI sets up the connection, the script updates Domoticz flawless though...PaulFen wrote: Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
I got my 3 Xiaomi Mijia Bluetooth Temperature Humidity Sensors linked up to Domoticz using the built-in bluetooth on Raspberry Pi3
