hi there
can someone give me some hint or already don this??
i would like to get a notification on my phone in the morning(for example 7 o clock) when is has frozen the night before.
so i would like to trigger outside temperatuur longer then for example 2 hours frost and not only at only 7 o clock...
coluld someone help me with this?
notification to defrost car window
astrapowerrr
- Target OS: -
DutchHans
Re: notification to defrost car window
Hi, I've done a similar thing:
It checks the outside temperature every hour and notifies me when its below zero. My notification is done by Autoremote.
Hope this helps
Cheers, Hans
sMinusZeroTemp = otherdevices_svalues['Temperature Outside']:match("([^;]+)")
sMinusZeroTemp = tonumber(sMinusZeroTemp)
MinusZeroAlarmText = "It is " .. sMinusZeroTemp .. " degrees, Dress warm if you have to go outside, and be careful."
MinusZeroAlarmURLtext = string.gsub( MinusZeroAlarmText, " ", "%%20")
local m = os.date('%M')
if (m % 60 == 0) then
if(tonumber(sMinusZeroTemp) < 0.0 ) then
os.execute("curl --connect-timeout 5 -s 'https://autoremotejoaomgcd.appspot.com/sendnotification?key=&title=Message%20of%20the%20house&text="..MinusZeroAlarmURLtext.."&url=http://xxxxxxxxxx.myfritz.net:2211/&icon=http://www.xxxxxxxxx.nl/domoticz_logo.png'&")
Hope this helps
Cheers, Hans
astrapowerrr
- Target OS: -
Hi hans,
But when I freezes all night you get every hour a notification?
DutchHans
Add a few lines of code to use this function.
I believe that Jos gets all the credits for the function.
If timebetween("06:00:00","08:00:00") then
Cheers,Hans
function timebetween(s,e)
timenow = os.date("*t")
year = timenow.year
month = timenow.month
day = timenow.day
s = s .. ":00" -- add seconds in case only hh:mm is supplied
e = e .. ":00"
shour = string.sub(s, 1, 2)
sminutes = string.sub(s, 4, 5)
sseconds = string.sub(s, 7, 8)
ehour = string.sub(e, 1, 2)
eminutes = string.sub(e, 4, 5)
eseconds = string.sub(e, 7, 8)
t1 = os.time()
t2 = os.time{year=year, month=month, day=day, hour=shour, min=sminutes, sec=sseconds}
t3 = os.time{year=year, month=month, day=day, hour=ehour, min=eminutes, sec=eseconds}
sdifference = os.difftime (t1, t2)
edifference = os.difftime (t1, t3)
isbetween = false
if sdifference >= 0 and edifference <= 0 then
isbetween = true
--~ print(" s:" .. s .. " e:" .. e .. " sdifference:" .. sdifference.. " edifference:" .. edifference)
return isbetween
Cheers,Hans
