start a notify after afterSec / forMin
acaonweb
Post by acaonweb »
hi guys i'm learning dzevents.
im writing a simple scripts that sends a sounds through xiaomi gateway after
	-- 'active' controls if this entire script is considered or not
	-- trigger
	-- can be a combination:
		devices = {
		    'test'
	-- actual event code
	-- in case of a timer event or security event, device == nil
	    if(domoticz.devices('test').state == 'On') then
	        domoticz.log('triggered')
	        domoticz.devices('test').switchOff()
	        domoticz.devices('GatewayMP3').switchOn().afterSec(20).forMin(1)
	        domoticz.notify('DZ test','test è on',PRIORITY_NORMAL,0,'iPhone6S',domoticz.NSS_PUSHOVER)
	        domoticz.log('mp3 '..domoticz.devices('GatewayMP3').state)
the script works fine except the notify: i'm not able to send the notification AFTER THE SWITCH OFF.
how can I resolve that?
thanx in advance
Fabrizio
dannybloe
Re: start a notify after afterSec / forMin
Post by dannybloe »
What do you mean exactly?
acaonweb
Post by acaonweb »
I mean the notification is sent in the same time of the switchon(): but then switch on starts n seconds later
I would like the notification starts n seconds later too
dannybloe
Post by dannybloe »
Sending notifications doesn't support delays as far as I know. What you can do is:
		devices = {
		    'test',
		    'GatewayMP3'
		if (device.name == 'test' and device.active) then
		elseif (device.name == 'GatewayMP3' and device.active) then
You create two triggers, one for the test switch and one for your gateway. When the gateway is turned on your script is triggered again and the elseif part will be executed.
acaonweb
Post by acaonweb »
great!!!
you make me understand everything
now the last question is why forSec doesn't work
thnx for now
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
