JSON command for create virtual sensor - custom sensor?
Posted: Tuesday 12 December 2017 16:53
by sammyke007
Anyone who knows the JSON command for creating a virtual sensor - custom sensor?
It has to be
http://IPADRESS:8080/json.htm?type=createvirtualsensor&idx=1&sensorname=Test&sensortype=XYZ
where XYZ should be the number for a custom sensor.
Some sensortypes are wrote down here already:
https://www.domoticz.com/wiki/Domoticz_ ... ual_sensor
Any idea?
Tnx!
Re: JSON command for create virtual sensor - custom sensor?
Posted: Saturday 23 December 2017 22:27
by McMelloW
sammyke007 wrote: Tuesday 12 December 2017 16:53
It has to be
Any idea?
Tnx!
You need to add an extra parameter for the y-axis. But i don't know how to do this. Facing exact the same problem.
Posted: Sunday 14 July 2019 7:37
by Filnet
Hello
Have you solved this?
I have the same problem.
Thanks for your help.
Posted: Sunday 14 July 2019 8:24
by Tristan
http://IPADRESS:8080/json.htm?type=createvirtualsensor&idx=HARDWAREID&sensorname=NAME&sensortype=TYPEID&sensoroptions=1;AXUNIT
AXUNIT = Ax Unit
HARDWAREID = Hardware index of the Dummy Hardware you are using (
not a sensor index)
NAME = Name of the new sensor
TYPEID = See
https://github.com/domoticz/domoticz/bl ... aretypes.h
Posted: Sunday 14 July 2019 13:45
by Filnet
Thank you!
Posted: Friday 19 July 2019 19:35
by philchillbill
If you create a test device (of any type you like) in the Domoticz UI in a browser while you have developer tools enabled (ctrl-shift-i in Chrome), under the network tab you'll see the JSON that the UI sends back to the Domoticz engine when you create or change something. From this, you can figure out the correct JSON to use for any command !
Posted: Monday 11 October 2021 11:30
by willem9136
Question, can I create any type of sensor?
I need a kind of custom sensor with 3 inputs
I need to see the output of 3 separate thermometers in 1 graph on the dashboard of Domoticz.
Is this possible?
Posted: Monday 11 October 2021 13:11
willem9136 wrote: Monday 11 October 2021 11:30
Is this possible?
No this is not possible. A Custom Sensor can only store and display 1 value. Also it is not possible to view graphs on the default dashboard of Domoticz.
If you want to graph multiple values on a dashboard you need something like dashticz extension or make your own graphing with grafana.
Posted: Sunday 16 April 2023 20:06
by henkkoorn
philchillbill wrote: Friday 19 July 2019 19:35
any command !
I have something here
