How to configure ICY E-Thermostat
g00fy
Domoticz version: 3.8153
Post by g00fy »
Hi Forum,
I bought a ICY E-Thermostat (Essent), because this device should be working native in Domoticz.
So, after registering it, I added it in the hardware settings, hoping I would find some devices under Settings..Devices or under the Temperature tab. But, unfortunately, nothing is there.
In the log I see:
2017-12-11 18:52:23.076  ICYThermostat: Worker started...
but nothing seems to happen afterwards.
How can I troubleshoot this further? Are there any other logs or connections I can check?
jvdz
Domoticz version: 4.107
Re: How to configure ICY E-Thermostat
Post by jvdz »
When you added the HArdware, 2 devices should appear in the Devicelist with the same name as defined in the Hardware tab.
Do you have "Accept new Hardware Devices " swicthed on ?
Jos
g00fy
Post by g00fy »
jvdz wrote: Monday 11 December 2017 19:14 Do you have "Accept new Hardware Devices " swicthed on ?
:shock: Off coarse. That was the problem. I am such a beginner... ;)
jmartinr64
Domoticz version: 4.10.419
Post by jmartinr64 »
Dear.
I know that this message isn't post in the correct place. But somebody can told me if this device has been discontinued? Or where can I purchase it?
Thank you very much
Sent from my SM-G928F using Tapatalk
g00fy
Post by g00fy »
It's in several shops (bol.com for example) for around €250. I bought mine secondhanded from Marktplaats. There ate plenty to buy from there.
Beware that you have to unregister the device on e-thermostaat.nl before you can register it under your own name. This process will cost €15.
