How to get a password reset for Domoticz
Posted: Monday 11 December 2017 18:54
by pbakkers
Hi.
I'am new on this forum and a starting user with a raspberry PI with Domoticz and RFXcom.
A got everything running and want to use Domoticz from an other location and then it went wrong.
And now I cannot login on my.domoticz. I have everyting
He asks me a username and password. What I enter its not accepted but I am shure it is right.
How can I get a reset.
2017-12-11 (4).png (298.55 KiB) Viewed 16712 times
(screen print)
Who can help me??
Kind regards,
Peter Bakkers
Re: How to get a password reset for Domoticz
Posted: Monday 11 December 2017 19:17
by jvdz
Posted: Monday 11 December 2017 20:32
by pbakkers
cd to domoticz works.
after the command : sudo service domoticz.sh stop >
answer: unable to resolve host raspberrypiPeter
sudo service domoticz.sh stop : na het status commando zegt hij Domoticz stopped.
How do I do this : Start domoticz by hand (as root) with the command line argument:
In the same dir?
then Error: webserver (HTTP) startup failed on address 0.0.0.0 with port 8080 bind :address already in use
check if no other application is using port :8080
the same error for port 443
regards Peter
Posted: Tuesday 30 October 2018 16:08
by walberg
Yesterday i got the same, I made a user and Password for controllicz and i am very shure i type in the exact phrase. I also got not started with 0.0.0
2018-10-29 21:49:33.991 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8080: bind: Address already in use
2018-10-29 21:49:33.991 Error: WebServer(HTTP) check if no other application is using port: 8080
2018-10-29 21:49:33.999 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2018-10-29 21:49:33.999 Error: WebServer(SSL) check privileges for opening ports below 1024
2018-10-29 21:49:34.000 Error: No servers are configured. Hence mydomoticz will not be started either.
2018-10-29 21:49:34.000 Status: Proxymanager started.
My Domoticz runs on 8081 not on 8080 as it has been installed with Homebridge which wil use 8080 for the screen.
Posted: Thursday 27 December 2018 10:12
by mastahb
I have the same problem. When setting my password it does not seem to work. If i enter the exact credentials i have setup in my domoticz settings it won't login.
I tried both login methods (webpage and popup). I have reset my password a dozen of times and tried it all but it does not seem to work. Anyone has a solution for this?
Or is it possible to set the password via the console?
Posted: Thursday 27 December 2018 11:14
by mastahb
This is what helped me.
The login was not working when using http. When I switched to using https it worked.
