Evohome with webapi no blocky control possible?
Posted: Saturday 09 December 2017 21:50
by aschaake
Hello all,
I have my evohome system from honeywell available in my domoticz. I use it with WEB API conenction. It works like a charm! Unfortunately there is one problem. Although I can set the setpoints from the gui, I would also like to influence the setpoints or the setting of my controller by blocky events.
The problem is that I don't know how to do this. There is an option to use setpoints in blocky events but domoticz says "no setpoints found". This seems strange because I can set these from the gui and the controller in my room shows the change initiatied by my manual domoticz action.
For what it's worth: I am running domoticz on my synology NAS, using an rfxcom344e device to control my KAKU devices.
The sitiuation I want to accomplish is: When all phones left the house I want to lower the setpoint temperatures of all zones to 15 degrees. Or when my son is home I want to lower all but his room.
Anyone accomplished the event controlled setpoint with evohome that is connected with WEB-API
Re: Evohome with webapi no blocky control possible?
Posted: Tuesday 12 December 2017 16:22
by digital
This would be a really good feature.
I am a very new user of Domoticz and finding my feet. I tried a similar thing with Evohome to change from Auto to Custom when outside temperature recorded from a sensor drops below a certain point. Not able to find a way using Blocky or Lua.
So I look forward to the feature being added in the future.
Posted: Wednesday 13 December 2017 12:05
by digital
Thank you for your reply.
What I am trying to do is this..........
I have a temperature sensor in the garage called Garage which reports fine into Domoticz.
When the temperature drops below a set level say 4 Degrees I would like EvoTouch to switch from Auto to Custom.
I have tried several ways but nothing seems to get through to EvoTouch.
Posted: Thursday 14 December 2017 11:35
by digital
Thank you for your replies.
This would be a really great feature for all Evohome owners if it could work again.
Posted: Sunday 17 December 2017 14:09
by digital
I have had a really good look around the forum etc and not able to see what you mean by call to curl.
If you have time please could you give me an example of how this is done.
I have made a dummy switch called "Froststat" and have been experimenting but still no luck.
Posted: Thursday 29 March 2018 23:04
by aschaake
anyone already found a way to use blocky?
Posted: Sunday 12 January 2020 19:21
by knireis
anyone with a solution?
Posted: Monday 13 January 2020 15:31
by JuanUil
When you use LUA instead of blocky you can send a command to Evohome
works perfect with me.
Posted: Thursday 02 December 2021 12:11
by Jeakes
Hello JuanUil
I've been working on it for a while but miss the stepping stone for a working LUA script.
Would you like to share your script so that we can use it and possibly adapt it for our own application. With this you would make a great contribution for us to get something like this working as well. Thanks in advance
